tutaj lista modeli, numery ECU, eppromy.
http://www.peacockandpurvey.co.uk/alfa_ecu_list.html
Kod:
155 1.7TS/155 1.8TS/155 2.0TS 46422622 / 00464226220 0 261 203 846
tak wogóle to spotkałem tylko dwa pliki do alfy 155, wiecej jest do 156 TS.
kody błedów w AirBag
Kod:
1 Airbag control unit
2 Airbag control unit supply voltage
3 Control light for airbag system
4 Earth connection to control unit housing
5 Display for deactivation of airbag, passenger side
6 Crash Signal
7 Crash Signal
8 Airbag ignition circuit, driver side
9 Airbag ignition circuit, passenger side
0B Seat belt tension ignition circuit, driver side
0C Seat belt tension ignition circuit, passenger side
0E Sidebag ignition circuit, driver side
0F Sidebag ignition circuit, passenger side
12 Resistance seat-occupied sensor, passenger side
14 Keylock switch for disabling passenger airbag
15 Driver side front side impact sensor
17 Passenger side front side impact sensor
19 Cable configuration
21 Ignition circuit, window bag, driver side
22 Ignition circuit, window bag, passenger side
28 Power supply
1A Warning lamp circuit
brakuje numeru 018, nic nie znalazłem na ten temat.
Alfadiag-a w pełnej wersji nie ma na sieci.
Komunikaty diagnostyki Air Baga nie są opisane na sieci, chyba trzeba tylko tłumaczyc te komunikaty.
