READING ERROR CODES:
No fault codes
READ PARAMETERS:
Odometer: 43231,1 km
Engine speed: 854 rpm
Engine temperature: 91,5 °C
Air temperature: 30,8 °C
Spark advance: 0,0 deg.
Injection time: 0,998 ms
Engine load: 33,56 %
Throttle angle: 2,64 deg.
Air quantity: 17,2 Kg/h
Mass air flow (throttle closed): 5,8 Kg/h
Battery voltage: 13,55 V
Vehicle speed: 0,0 km/h
Idle RPM desired: 850 rpm
Canister purge valve: 22,66 %
Lambda sensor 1 integrator: 1,00000
Lambda sensor 2 integrator: 1,00000
Adaptation bank 1 (mul) (FRA Factor 1): 0,99478
Adaptation bank 2 (mul) (FRA Factor 2): 0,99365
Adaptation bank 1 (add) (DTV Factor 1): -0,70
Adaptation bank 2 (add) (DTV Factor 2): -0,84
Throttle learn status: 11
Engine status: Idle
Engine warmed up: DONE
Catalytic converter: Present
Catalytic converter heating: Not active
Lambda 1 status (Pre-Cat.): Open loop
Lambda 1 status (After-Cat.): Open loop
Lambda 2 Status (Pre-Cat.): Open loop
Lambda 2 status (After-Cat.): Open loop
Throttle position learning: In progress
Throttle learn results: Correct
