Page 1 with 10 12345678910 LastLast
Show results from 1 to 10 with 94
    The user Maniac resoraków
    He joined the
    01 2013
    Lives in
    Słopnice
    Alfa Romeo 159 2.4 JTDm 200KM EGR and DPF off
    Posts
    791
    Domyślnie Cracked head, 2.4 JTDM
    Hello
    as it turned out, I-koilNYM over who has to settle scores with the severed head. It turned out to be day based. symptoms: increased pressure in the system, another temperature immediately to 130 and drop to 70. I thought it was the temp sensor and nothing, then it's the thermostat until mechanic I decided that this gasket under the head. After analysis it turned out that there is no damage and the gasket sits perfectly, so what is it ??? Head to check and the verdict: the head is cracked and is only suitable for scrap.
    Now I have a question: what would you recommend to open the stimulator (if there is) or buy a new one??? Of course the cost of they will be held in thousand PLN.
    Maybe someone already drilled this subject and knows something, which is abuy something good and at a reasonable price???
    Maybe someone has extra????
    Best regards
    He joined the
    07 2012
    Lives in
    LHR
    159 V6
    Posts
    10,938
    All you can somewhere buy new? And for how much? 10K rubles?
    159 1.9 JTDm 16V -> 2.2 JTS -> 1750 TBi -> 3.2 JTS Q4
    The user Maniac resoraków Avatar Pakul
    He joined the
    05 2014
    Lives in
    Warka
    AR 159 2.4 KM 227 474 NM; DPF, EGR OFF
    Posts
    52
    you have a DPF ?
    The user Beginner Avatar mroku
    He joined the
    11 2013
    Lives in
    Kraków, Poland
    159 Berlin 2.4 jtd
    Posts
    134
    Head new, apparently, not to buy, and if you have miraculously found, then the price space. Get effectively used also borders on the miraculous. In principle, probably, the only solution is to regenerate a head (welding). As a regenerated, unfortunately, don't know, maybe someone here has this in writing. My not yet drawn
    The user Dwusuwowiec Avatar Lich
    He joined the
    04 2014
    Lives in
    Bydgoszcz
    AR 159 2.4 200 KM
    Posts
    105
    Somewhere mignął front of me, that the head of a new "OK". 5K RUBLES.
    Can such a decision?
    http://allegro.pl/glowica-alfa-romeo...651098395.html
    He joined the
    01 2013
    Lives in
    Słopnice
    Posts
    791
    Ladies and gentlemen, is to buy new and restored at the factory
    Price shock:
    new "OK". 10tyś RUB.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    regenerated approx. 5tyś rubles, Too, revelations has
    Regeneration is not included in the game, because I was told that this crack will not give zaspawać
    Drama. I sell this car. even with a damaged head. Made:
    Grip and dwumasa - original !!! 17 thousand km ago I replaced the invoice (this, too, I have)
    valve timing - original ASO
    suspension forward, up and down - also the originalthe cost of the perhaps all too aware) Changed about 3 months ago!!!!
    I thought a little pośmigam and, please, no thanks.
    Willingly I will give for Giuliettę 2.0 JTDM or 17 TBI
    ---Updated---
    Quotation Wrote Lich Zobacz post
    Man, these guys have nothing. I can only fix your, if so, has burst in a place that zespawają otherwise you do not take the job. This auction is shit!!!!
    and this price is 1400 + 800 as you buy a Deposit-it's a little, come on, and you have a new
    The user Pasjonat
    He joined the
    04 2008
    Lives in
    159 SW 1.9 16v jtdm
    Posts
    3,309
    Quotation Wrote slawek986 Zobacz post
    Price shock:
    Check the status of the warehouse. Apparently, these part of the no warehouses.
    Contact Tomkiem_KRK. He will give you a direction for people who have been doing heads. Can help.
    He joined the
    04 2014
    Lives in
    Bydgoszcz
    AR 159 2.4 200 KM
    Posts
    105
    At what mileage did this happen?
    The user Maniac resoraków Avatar bobby
    He joined the
    10 2014
    Lives in
    Lublin
    Franny (159 2.4 JTDM 06')
    Posts
    956
    Does anyone know why these heads are dropping like flies?
    The user Pasjonat
    He joined the
    04 2008
    Lives in
    159 SW 1.9 16v jtdm
    Posts
    3,309
    Quotation Wrote bobby Zobacz post
    A few suspects:
    DPF
    for large EGT
    for the high temperature fan restart
    weak material
Similar threads
  1. [159] Cracked head 2.4 GHz
    Created by elelmo in section 159/Brera/Brera Spider
    Response: 7
    Last post/author: 24-12-2015, 23:21
  2. if head 1.9 jtd 8V jtdm 8V 115km and 120 km are the same?
    Created by lukas1983 in section 156
    Response: 0
    Last post/author: 14-07-2012, 07:42
  3. Cracked brake hoses
    Created by blandor in section 166
    Response: 11
    Last post/author: 31-10-2011, 18:51
  4. [146] crackling wires, fuel
    Created by niania82 in the section 145/146/155
    Response: 5
    Last post/author: 24-04-2010, 09:34
  5. Cracked hoses of system of a turbo-supercharging
    Created by Ołówek1977 in section 156
    Response: 11
    Last post/author: 30-09-2009, 21:29
2.4 jtdm pekajace glowice
modification of head 2.4 jtdm
pekajace glowice 2.4 159
jtd cylinder head crack
fotolaboratorija quality brera 2.4 jtd
alfa 159 2.4 cylinder head
2.4 multijet cylinder head problem
glowica alfa 2 4 jtd 20v czy pasuje do jtdm
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
