Strona 25 z 162 PierwszyPierwszy ... 15161718192021222324252627282930313233343575125 ... OstatniOstatni
Pokaż wyniki od 241 do 250 z 1611
Temat: Zużycie paliwa
  1. #241
    Stelvio 280KM
    Cytat Napisał walgreen Zobacz post
    Czy w silniku, który ma Q, nie ma przypadkiem tak, że w pewnych warunkach są odłączane dwa cylindry?
    Cylinder deactivation
    I had an OBD reader connected on a trip from Scotland to London and back and was able to monitor this.
    Cylinder deactivation works in both A and N mode, but is disabled in D. It works in gears 6, 7, 8, and may work in lower gears (but didn't try it). In gear 8, it works up to 81mph indicated on the dashboard. At 82mph it didn't work.
    For cylinder activation to start, I estimate torque needs to be below 80NM, and then will remain on 3 cylinders up until about 120NM (these are both guesses based on OBD data). Also, at regular intervals of about 100 seconds, it will deactivate for a few seconds to keep the cat up to temperature.
    I can't feel or hear when it is happening. There is no change in engine note or rhythm. However, when it happens, the instantaneous mpg bar will jump from approximately 33mpg to 55mpg. I think this is the only way to tell without connecting an OBD reader.
    Sometimes a gradient would mean the torque needed was slightly higher than the threshold set for cylinder deactivation to enable. I found that by reducing throttle ever so slightly would be enough to enable, then I could very gently apply throttle again and remain on 3 cylinders.
    Wysłane z mojego BLA-L09 przy użyciu Tapatalka
  2. #242
  3. #243
    Stelvio 280KM
    Tylko krajówki, bez autostrad. Wyprzedzanie zawsze i wszędzie gdzie się dało w ramach rozsądku.
  4. #244
    Alfa Romeo Stelvio
    Cytat Napisał Rafał Zobacz post
    Spalanie w stelvio 280km benzin
    Jesteś mistrzem ekodrivingu Ja ponizej 13 srednio raczej nie schodzę.. aż wole sobie nie wyobrażac jaka frajdę z jazdy czujesz A raczej jej brak serio juz wole dołożyć te 25zl za 100km ale miec przyjemność z jazdy
    Wysłane z mojego SM-N950F przy użyciu Tapatalka
  5. #245
    Użytkownik Znawca Avatar azar
    Giulia Veloce, Giulietta 1.4
    Trochę sporo
    Veloce litr mniej by było srsly.
    Fizyka
  6. #246
    ViP Znawca Avatar Rafał
    Kozy k/Bielsko-Biała
    164 Q4 , Giulietta QV, 164 - 2 szt , Alfa Galaxy / BUSSO Stelvio Super 280KM/ Spider ph2
    Cytat Napisał niegowic Zobacz post
    Nie podniecaj sie tak z opiniami ! mam 15 aut i każde testuje w różnych warunkach!. To pitolenie bo ja ! Temat jest o spalaniu a nie biadoleniu.
  7. #247
    Alfa Romeo Stelvio
    Moim zdaniem odczucia co do warunków i wrażeń z jazdy sa istotne.
  8. #248
    Tak ale własne !- ze mną nie jechałeś więc nie znasz odczuć z tego testu!!! więc domniemywasz i uświadamiam Ci , że się mylisz .
  9. #249
    Alfa Romeo Stelvio
    Napewno sie mylę (Ja tylko 8k km zrobilem takim samochodem wiec no sorry co ja mogę wiedzieć ile spala) jechałeś tak ze kazdy Cie wyprzedzal chyba że nie bylo gdzie
    Widocznie lubisz korzystac z trybu żeglowania w samochodzie i tyle, ja lubię jak mnie wgniata w siedzenie albo czasem tyłem zarzuci.. O gustach się nie dyskutuje. W sumie nie wiem co Cię urazilo w moim napisaniu ze jesteś mistrzem ekodrivingu.. Ja przyznaje nie umiem tak jezdzic bo nawet gdy zacznę to wcześniej czy później musze depnac
    No i umówmy się mysle ze wiecej osob sie zgodzi ze spalanie w Stelvio
    7.5l czy moje 19,5l to są wartosci skrajne w codziennej jezdzie raczej żadna z tych wartości nie bedzie spalaniem ktore przeciętnie sie uzyskuje.
    Wiec tez chce na to zwrócić uwagę.. Bo jeśli ktoś kupi 280KM benzyne stelvio i bedzie mial spalanie 7.5 w ciągłej eksploatacji tzn. Ze napewno nie wykorzystuje możliwości tego samochodu albo co gorsza ktos kupi i bedzie przekonany że takie spalanie to norma.
    No a pozatym mysle ze nie tylko ja ale tez inni chetnie przeczytają w jakich testowałes, bo sam wynik bez kontekstu jest niczym...
    Ja mogę się założyć ze spale 0l/100km ma dystansie 100km..
    Ostatnio edytowane przez niegowic ; 01-09-2018 o 22:14
  10. #250
    Użytkownik Rowerzysta Avatar sebol75
    Poznań
    Alfa Romeo Giulia Veloce, 159JTDm150@192/405, 147JTD
    Trochę tak jest - ja jak chce jechać eco to ustawiam tempomat na 140 na autostradzie ale zawsze w ciągu max kilkunastu minut mi się zaczyna nudzić i but choćby do tych 180
  1. [159] Zużycie paliwa / spalanie 159, Brera, Spider
    Utworzone przez alces1 w dziale 159/Brera/Brera Spider
    Odpowiedzi: 3224
    Ostatni post / autor: 08-03-2023, 18:25
  2. [159] zużycie paliwa BENZYNA
    Odpowiedzi: 15
  3. [159] hamowanie silnikiem i zużycie paliwa 2.0 litra/100 km
    Odpowiedzi: 14
  4. Zużycie paliwa i sonda lambda
  5. Zużycie paliwa na postoju - wskazania ICS
