No to jak wszystkim stuka, jutro zaczynam z rana mojego katować - dopóki też nie usłyszę stukania...
A tak na poważnie - może to faktycznie RFy albo 20-ki na żwirze - i ja nie mam tego, bo jeżdżę na porządnych balonach 17"?
W Stelvio z oponami 20’’ tez mam to zachowanie. Tak jak w tytule wątka, to jest przeskakiwanie a nie stukanie. Wydaje mi sie normalne. Zdarza sie glownie podczas manewrow w hali garazowej. Mam wrazenie ze wynika to z 4x4
Cytat ponoć z fabrycznej dokumentacji:
Steering - Ackermann angle
The particular type of front suspension adopted for the Giulia (Alfa[emoji769] Link) has been studied and developed to obtain the best dynamic performance in every driving condition. In particular, the quadrilateral arrangement with a semi-virtual steering axis with double wishbone allows variation of the Ackermann angle with the variation of the steering angle. The Ackermann angle is given by a different steering angle between the internal and the external wheel. This characteristic, which is normally reserved for the most prestigious sports cars, has been fine-tuned to guarantee the lowest possible understeer in any driving condition and thus allow the Giulia better dynamic driving with greater safety and driving pleasure.
In particular driving conditions, with fully steered wheels it is nonetheless possible for a slight dragging of the internal wheel to be generated, which may be perceived as skipping of the tyre accompanied by noise.
This ohenomenon, called chattering, is influenced by the following parameters:
Characteristics and temperature of the road surface
Type of tyres
Tyre pressure
Steering angle
Speed of manoeuvre
The noise that is noticed in the driving condition described above is therefore determined by the parameters listed above and must NOT be considered an anomaly or a fault of the vehicle. This phenomenon is inherent only to specific design choices intended to pursue the maximum result in terms of vehicle safety. lt does not in any way influence the dynamic safety nor even the deterioration of the tyres or of any other mechanical component.
Ostatnio edytowane przez ciafok ; 04-08-2018 o 08:10
Bardzo ciekawe. Czyli można to u siebie mieć - i to nie defekt, albo można tego u siebie nie mieć.
Tym niemniej, pobawię się Stelviuszem i poobserwuję - z ciekawości.
Rzeczywiście wygląda na "feature":
https://www.giuliaforums.com/forum/7...html#post93593
Ostatnio edytowane przez ciafok ; 04-08-2018 o 08:09
Na dużych balonach może to być nie wyczuwalne bo się opona wygina, na niskim profilu lub rf bok opony jest na tyle sztywny ze opona zsuwa się po nawierzchni - normalna rzecz nie ma o czym dyskutować
To nie jest wada tylko fizyka
U mnie na kostce na 17 przy skręcie na parkingu czasem jest. Mam rwd
Z tego co wiem (mogę się mylić) stelvio jak i giulia ma inaczej zrobione zawieszenie jak większość aut. W tych autach koła przy skręcie są płasko do podłoża anie przechylone co daje jak największą styczność opony z asfaltem. Może właśnie ten feature powoduje przeskok opon
Miałem tak w 159 na oponach 235. Podobno przy wielowahaczowym zawieszeniu i szerokich gumach to norma
Identycznie jest w Maserati SQ4.
wcześniej:
YUGO 65 1.3 (ZASTAVA) '86 - 1994-1997
AR 146 1,4 boxer '97 - 1997-1999
AR 156 2,0 TS '98 - 2000-2001
AR 156 2,5 V6 '99 - 2001-2004
AR 156 GTA '03 - 2006-2009
AR 159 3,2V6 Q4 ti '07 - 2009-2014
teraz:
Honda CRV (służbowa)
Maserati Ghibli SQ4 '15
