http://picasaweb.google.com/Sidor211...eat=directlink
http://img864.imageshack.us/g/20110407033.jpg/
http://amaxlpg.pl/index.php?page=mai...cat=335&cp=353
---------- Post added at 18:55 ---------- Previous post was at 18:54 ----------
---------- Post added at 18:56 ---------- Previous post was at 18:55 ----------
Cleaning of Matrix injectors
Disassembly:
Screw out 4 pcs of imbus 2.5 mm. Take down part of body with nozzles.
Screw out 2 pcs of imbus 2.5 mm. Attention, everythinfg can go to pieces ! Avoid loss of them.
Assembly:
At the first, put rubber reversible pad to the plastic part of body. Up to plastic pad put down brass pad. See pic. 1, 2.
Up to these revesible pads put down metal lame with rubber sit [8x]. Attention, chamfer face up. See pic.3 [wrong is signed].
Up to metal lames, put distance pad. See pic. 4
Put in peripheral seal and put together with part of body with coils. Screw by 2 pcs of imbus 2.5mm. See pic. 5,6.
Check all O-ring seals and put together with cover of Matrix. Screw by 4 pcs of imbus 2.5 mm. See pic.
Matrix heating up:
For better working Matrix injector in winter it ir recommended to warm it up by hot water cooling car system. See pic.
Intervals for servis:
Every 20 000 km – change gas filter [gaseous state] and part of hose behind the filter
Every 20 000 km – cleaning Matrix injectors
Every 20 000 km – change LPG filter in LPG valve
Every 100 000 km – change memranes in reducer
---------- Post added at 18:57 ---------- Previous post was at 18:56 ----------
To Ci powinno wystarczyć![]()
Kto chce szuka sposobu,
kto nie chce szuka powodu.
155 V6v12 lpg -była
156 V6v24 lpg-była
147 2.0TS Selespeed lpg.-jest
166 2.0 V6 TB -LPG-jest
kudlaty_bytom thanked for this post
co 20 tyś km? ja zrobiłem od zakupu auta ponad 17 tyś, a co było wcześniej, to jeden diabeł wie
pomysł z podgrzaniem listwy miałem podobny, ale się zastanawiam, czy to w ogóle robić i czy pozbywać się tego na lato, czy zostawićpod maską jest i tak potem gorąco
dzięki za fotki i materiały edukacyjne
wiesz może czy mogę zamienić moją hd344, a przynajmniej ze zdjęć w necie tak wywnioskowałem, na hd544? niby złącze takie samo, tylko 544 ma 8 cewek, a moja 'tylko' 4
przy 544 chyba jest krótszy czas podania gazu, bo przez dwie dysze leci, dobrze myślę?
Ostatnio edytowane przez kudlaty_bytom ; 14-12-2011 o 20:49
verdebiancorosso
no dobrze Panie i Panienki
dzisiaj listwa poszła na stół i ją wyczyściłem
cała operacja zajęła 40 minut i przyniosła spodziewane i rozweselające efekty
przełącza się przy przegazówce na postoju, nie trzeba silnika kręcić na biegu, bo gasł wtedy i jakoś tak lepiej jedzie
teraz muszę znaleźć czas, by podpiąć pod kompa i zrobić regulację
dzięki wielkie piortiix za podpowiedzi
Ostatnio edytowane przez kudlaty_bytom ; 27-12-2011 o 20:40
verdebiancorosso
