The Body Computer M001 - connector A - receives a direct power supply from the battery through the line protected by maxi fuse F01 of the engine compartment control unit B001.
Pin 11 of connector G of M001 provides the Body Computer with a reference earth.
The ignition switch H001 is supplied by the engine compartment junction unit B001 via the line protected by fuse F03.
In the MAR-ON position, many protected "ignition-operated" circuits and services are supplied ("INT" and "15/54" lines): the ignition-operated signal "15/54" is sent to the engine compartment junction unit B001, whilst the "INT" signal is sent to the Body Computer M001, to pin 2 of connector G.
The ignition-operated signal "INT/A", however, is sent to the Body Computer M001 at pin 9 of connector G.
Rotating the ignition key of the switch H001 to the extreme position (AVV) - pin 50 - the electromagnet winding for the starter A020 is supplied, pin 50.
Pin 30 of A020 - connector A - i.e. the actual motor, receives a power supply with the voltage coming directly from the battery through the junction box B099. The direct current produced by the alternator A010 (pin B+), connector B, is sent to the battery A001, passing through the motor A020.
