Przeglądasz Forum Alfa Romeo - Alfaholicy. Wyświetlony wątek znajduje się w dziale Zrób to sam - Czyli instrukcja serwisowa pisana przez naszych użytkowników. W tym dziale przeczytasz m.in. jak wymienić termostat, filtry, żarówki, tarcze i klocki hamulcowe, a nawet sprzęgło czy pasek rozrządu. UWAGA!! W tym dziale publikujemy opisy napraw, przydatne dane techniczne itp. Nie komentujemy i nie zadajemy pytań!
Thanks (Dane)
198
Thanks (Otrzymane)
77
Likes (Dane)
0
Likes (Otrzymane)
0
Dislikes (Dane)
0
Dislikes (Otrzymane)
0
Czas spędzony na forum
4 d 20 h 59 m
Kluczyk (schematy, zdjęcia)
Oryginalny tekst [eng] (zdjęcia na końcu)
Alfa 2 Button Flip Key-fob replacing a micro-switch Produced by Michaeld for www.alfa156.net Here s how I changed the microswitch on my 2 button flip style key-fob. Firstly here s a photo of it to show you the type I mean. My car is a 2001 2L TS 156. My key worked fine except for the alarm/central locking button. Warning . Before attempting this work you need to be a fairly competent solderer; the components are small and any solder splashes could result in the key not operating - with the result that it won t start the car (i.e. it won t be recognised). Read through this whole document before starting. Pay Attention and Work slowly when doing this, pay special attention to how everything comes apart. There are several small parts that need to go back in the correct places when assembling the fob again. Take photos if possible at every stage just in case. Ok let s take the key apart. 1. Firstly remove the battery. Flip out the key (deploy it) and this should give you access to the battery holder. Turn the screw to Unlock and then remove the battery. You can just see the screw in this picture. Alfa 2 Button Flip Key-fob replacing a micro-switch Produced by Michaeld for www.alfa156.net Here s the battery removed. The battery is a 3 Volt CR2032 (Panasonic say) which you should be able to buy in most electrical shops. Note that the +ve of the battery faces down towards the desk in this picture. 2. Remove the Fob Screw Remove the Alfa logo (don t ask me how as my key doesn t have one . ) Remove the screw under the badge. 3. Prise Open the Fob This part may be tricky the previous owner had glued the end of my key together to prevent it falling off the key ring (i.e. to stop the metal thingy coming out the end). Get a small blade screwdriver and slowly work around the join of the fob prising it apart. Due to the glue mine only opens like a clam shell which makes working at it harder (so all my descriptions are with the key prised open from the battery side), yours should open fully and the next steps will be easier for you. Here s what my fob looks like prised open. The 3 pronged clip is important as it picks up the +ve side of the battery. Notice that all 3 prongs are above the PCB (printed circuit board i.e. the green board in the picture) do not insert it with the middle one behind the PCB (this is a very easy mistake to make). Note the middle prong touches a large brown contact pad on the PCB. Alfa 2 Button Flip Key-fob replacing a micro-switch Produced by Michaeld for www.alfa156.net Also note the small clip marked 2. It s not that easy to see so I left the resolution on the photo quite high. This clip must again be above the PCB and when the key is assembled it touches the brown contact pad on the PCB. Do not replace the PCB with this contact hidden it must be on the underside of the PCB as shown and not on the component side. This clip is part of a large metal clip which starts off at the very back of the fob as seen looking at the photo (i.e. it is way down inside the fob where my finger is at the bottom of the photo). The job of this clip is to pick up the ve of the battery and to route it to the contact shown. Note - please look carefully at these two clips before taking the fob apart as they must go back exactly in the right positions. The 3 pronged clip is held in by the PCB and will fall out as soon as you remove the PCB. This clip is very fiddly to get back in correctly. Note also that the key itself is sprung and will fall out so try to see how it goes together before it falls out and don t loose and of the parts there s a small spring and a keyed button (that s the button you use to deploy the key). 4. Remove the PCB Maybe your fob will come right apart and the next stages will be easier for you. I had to work with the fob levered open as shown above. Next prise out the PCB put a small bladed screwdriver in behind it and it should fall out. Make sure you don t loose the 3 pronged clip. 5. Replace the Micro-switch You should see two micro-switches on the PCB. However it is not unusual for one of them to have broken or partially fallen off. Locate the broken micro-switch and desolder it from the board. You ll need a fine solder tip for this and steady hands. Do not splash any solder on the PCB or like me you ll short out some tracks and the key won t be recognised by your car. If you do then remove the solder splash with some braid (the braid from inside a TV aerial BNC cable should work). The micro-switches are similar to this . This is a J bend one the contacts at either end are shaped like a J. The fob uses gull wing ones which are shaped like an L so the electrical contacts lie flat on the PCB. Here s a drawing of the gullwing type. The micro-switches are from ITT and are KSR251G type (KSR253G will also do as will KSR231G and KSR233G). Here s the PCB removed. The micro-switches are the silver rectangles with black dots (buttons) marked as 1 and 2. 1 is for the central locking/alarm and 2 is the boot release (I hope that s correct). This is the view after I replaced the switch so I haven t got a photo of it broken (the top was cracked and part of it eventually fell out). Alfa 2 Button Flip Key-fob replacing a micro-switch Produced by Michaeld for www.alfa156.net Here s what it looked like after I had removed the faulty switch. Sorry about the quality of this picture arrow 1 points to the area where the central locking micro-switch was removed. The contacts are to the left and right of the tip of the arrow. Arrow 2 points to the other micro-switch still I position (you can just make out the black button). 6. Putting it Back Together This is actually quite hard and requires 4 hands . Snap the key back as shown in section 3 so the fob is open like a clam-shell. Or if your key comes fully apart then ignore and just proceed to the next paragraph. Drop in the PCB with the micro-switches against the rubber buttons on the top of the key. Make sure the clip at the end is touching the contact (clip 2 in section 3). Prise up the edge of the PCB closest to you and then slip the 3 pronged clip in under it making sure all 3 prongs are visible. Jiggle the clip until it touches the contact and the edge of it is trapped by the edge of the PCB. It s hard to describe so that s why I suggested paying attention to how it came out. Now insert the spring for the key and put the button on the end of it. Note the button has 3 keyed lugs on it which locate into the hinge of the key. The spring has a foot sticking out of it and this foot anchors the spring against a plastic lug on the fob. Wind the button up against the spring so that it flips the key out when deployed. Wind it anticlockwise looking down on it I wound it three rotations I think. Next slip the key over the button and using a screwdriver or forceps turn the button until it springs into place in the recess in the key note the button must protrude out the top of the key so make sure the lugs in the button slip into the correct slots in the key hinge. Now try to put the fob back together and is everything goes well snap it shut and replace the screw which was under the logo. Replace the battery and press either of the rubber buttons. The red LED should come on. If not then the most likely problem is that the two clips haven t been installed correctly so check these. 7. The Scarey Bit Next run out and try the key. Both buttons should work and .. the key should start the car. If the key doesn t get recognised by the car then open it up again and check for solder splashes. That s about it pretty difficult in a way and certainly not for the novice. Any questions then email me on stockdam@hotmail.com
Zdjęcia kluczyków
Schematy kluczyków
Kto chce szuka sposobu, kto nie chce szuka powodu. 155 V6v12 lpg -była 156 V6v24 lpg-była 147 2.0TS Selespeed lpg.-jest 166 2.0 V6 TB -LPG-jest
Thanks (Dane)
198
Thanks (Otrzymane)
77
Likes (Dane)
0
Likes (Otrzymane)
0
Dislikes (Dane)
0
0
4 d 20 h 59 m
Przetłumaczony [pl] (Google Tłumacz)
Alfa 2 Button Flip Breloczek zastępując micro-switch Produced by Michaeld dla www.alfa156.net Tutaj s jak zmieniłem mikroprzełącznik w moim stylu przycisk 2 klapki breloczka. Po pierwsze tutaj s zdjęcie to pokazać ci typu I mean. Mój samochód jest 2001 2L TS 156. Mój klucz pracował dobrze, z wyjątkiem alarm / centralny zamek przycisk. Ostrzeżenie. Przed próbą tej pracy trzeba być dość Właściwe solderer; elementy są małe i wszelkie plamy lutu może spowodować klucz nie operacyjny - w związku z czym zdobył t start samochodu (tzn. zdobył t uznawane). Przeczytaj uważnie cały ten dokument przed startem. Cieplutkie i Pracy powoli, gdy ten sposób zwrócić szczególną uwagę na jak wszystko jest osobno. Istnieje kilka małych części, które muszą cofnąć się w odpowiednich miejscach, gdy montaż FOB ponownie. Wziąć zdjęć, jeśli to możliwe na każdym etapie, na wszelki wypadek. Ok niech s wziąć klucz od siebie. 1. Po pierwsze wyjmij baterię. Odwróć się klawisz (rozdysponowania) i to powinno dać Ci dostęp do baterii posiadacza. Skręć śrubę, aby odblokować i wyjmij baterię. Możesz po prostu zobaczyć Śruba w tym obrazie. Alfa 2 Button Flip Breloczek zastępując micro-switch Produced by Michaeld dla www.alfa156.net Tutaj s baterii usunięte. baterii 3 V CR2032 (Panasonic powiedzmy), które powinny być w stanie coś kupić w większości sklepów elektrycznych. Należy pamiętać, że + ve z baterii twarze w dół w kierunku biurko w ten obraz. 2. Usuń Fob śrubowe Usunąć logo Alfa (Nie pytaj mnie jak jak mój klucz doesn t have one. ) Usunąć śruby pod odznakę. 3. Prise Open Fob Ta część może być trudne poprzednie właściciel miał przyklejone do końca mój klucz razem, aby zapobiec wypadnięciu kluczowych pierścień (tj. do przystanku metal thingy coming out end). Get małe ostrze śrubokręt i powoli obejść dołączyć fob prising go od siebie. Ze względu na mój klej tylko otwiera jak muszli małż, które sprawia, że praca na trudniejsze (a więc wszystkie moje Opisy są kluczem prised otwarte z boku baterii), powinny same biblioteki w pełni i następnym krokiem będzie łatwiejsze. Oto coś co wygląda mój fob jak prised otwarte. 3 zębach Klip jest ważne jak to odbiera + ve stronie baterii. Wskazówki że wszystkie 3 zębach są przede PCB (drukowanej płytki drukowane tj. zielony pokładzie zdjęcie) nie włóż ją z środkowa z tyłu PCB (jest to bardzo łatwe błędem make). Uwaga Bliski Prong dotyka duże brązowy kontakt Podkładka na płytce. Alfa 2 Button Flip Breloczek zastępując micro-switch Produced by Michaeld dla www.alfa156.net Zwróć także uwagę na małe wideo oznaczone 2. Nie s to takie proste, aby zobaczyć, więc lewej rezolucji w sprawie Fotografia dość wysokie. Ten klip musi zostać ponownie powyżej PCB i gdy klucz jest zmontowane dotknie brązowy pad kontakt na płytce. Nie zastąpi PCB z tego kontaktu ukryte należy na spodzie PCB, jak pokazano, a nie po stronie elementu. Ten klip jest częścią dużej metalowy zatrzask, który uruchamia się samym końcu FOB jak widać patrząc na zdjęcia (tj. nie jest aż wewnątrz fob gdzie mój palec jest na dole zdjęcia). Zadaniem tego klipu jest podnieść ve baterii i przekierować go na wskazany kontakt. Uwaga - proszę uważnie patrzeć na te dwa pliki przed podjęciem oprócz FOB, ponieważ musi wrócić dokładnie w prawej pozycji. 3 zębach wideo odbywa się przez PCB i wypadnie jak najszybciej usunąć PCB. Ten klip jest bardzo skrzypce wrócić w prawidłowo. Zauważ też, że sam klucz jest tłumiona i wypadnie więc spróbuj zobaczyć jak to idzie w parze zanim wypadnie i don t luźne i części nie sa małe wiosną i wyczerpiesz przycisku (czyli s przycisku możesz używać do wdrażania kluczowych). 4. Usuwanie PCB Może wasz przyjdzie FOB prawo od siebie i następne etapy będą łatwiejsze. Miałem do pracy z FOB podważeniem bramy, jak wskazano powyżej. Następnie odchyl się PCB umieścić małe śrubokrętu w za nim i powinien spadek na zewnątrz. Upewnij się, że Don t loose 3 zębach wideo. 5. Wymień Micro-switch Powinieneś zobaczyć dwa mikro-przełączników na płytce. Jednak nie jest czymś niezwykłym dla jednego z je się, że łamane lub częściowo spadł. Znajdź podziale mikro-przełącznika i desolder go z planszy. You ll potrzeby cienkiej końcówki lutowniczej na tej ręce stały. Zrobić nie czyścić wszelkie lutu na płytce lub jak ja was ll zwarcie niektórych utworów i klucz wygrałem nie będzie uznawane przez Twojego samochodu. Jeśli tak to usuń splash lutu z niektórymi Braid (oplot z wnętrza telewizji kablowej antena BNC powinny działać). Mikroprzełączniki są podobne do tego. To J zakręcie jeden z kontaktów na obu końcach są w kształcie J. FOB używa Frajer te skrzydła, które są w kształcie L tak styków elektrycznych leżeć płasko na PCB. Tutaj s rysunek z Gullwing typ. Mikroprzełączniki są z ITT i KSR251G typu (KSR253G zrobi jak będzie KSR231G i KSR233G). Tutaj s PCB usunięte. Mikro-przełączniki prostokąty srebrny z czarnym punktów (guziki), oznaczony jako 1 i 2. 1 stosuje się do centralnego zamek / alarm i 2 prasowa boot (mam nadzieję, że s poprawna). To jest widok po I zastępuje przełącznik więc t przystań dostał zdjęcie zepsute (najlepsze było pęknięty i części ostatecznie wypadł). Alfa 2 Button Flip Breloczek zastępując micro-switch Produced by Michaeld dla www.alfa156.net Oto coś co wyglądało jak po moim usunięte wadliwego przełącznika. Przepraszam za jakość tej strzałki zdjęcie 1 wskazuje na obszar, w którym centralny zamek mikro-przełącznika została usunięta. Kontaktów z lewej i prawej stronie końcówki strzałki. Arrow 2 wskazuje na innych mikro-switch still I miejsce (można po prostu zrobić się czarny przycisk). 6. Putting it Back Together To jest rzeczywiście dość trudne i wymaga 4 ręce. Snap kluczyk jak podano w sekcji 3, tak FOB jest otwarte jak clam-shell. Albo, jeśli klucz jest w pełni poza to zignorować i po prostu przejść do następnego akapitu. Spadek PCB z mikro-przełączniki przed gumowe przyciski na szczycie klucz. Upewnij się, że wideo w końcu dotyka kontaktowe (clip 2 w pkt 3). Prise się krawędzi płytki najbliżej Ciebie, a następnie wsunąć 3 zębach klip w jego mocy podejmowania czy wszystkie 3 zapięcia są widoczne. Jiggle klip aż dotknie kontakt i krawędzi jest on uwięziony przez krawędź płytki. To s trudne do opisania, tak aby s dlaczego zaproponował zwrócenie uwagi na, jak to wyszło. Teraz wstawić na wiosnę na klucz i umieścić przycisk na koniec. Uwaga: Przycisk ma 3 wyczerpiesz występy na to, które znaleźć pod zawiasy klucz. Wiosna stóp wystającą i ta kotwice stóp wiosną przed plastikowe LUG na fob. Wiatr zapiąć od wiosny tak, że odwrócenie kluczyk przy wdrożeniu. Wind it tyłu patrząc na nią I ran to trzech lotów myślę. Następnie wsunąć klucz w ciągu przycisk i za pomocą śrubokręta lub pęseta włączyć przycisk, aż rodzi się na swoim miejscu we wnęce w kluczowych Uwaga przycisk musi wystawać na górze klawisz tak zrobić Upewnij się, że występy w poślizg przycisk do odpowiedniego gniazda w kluczowych zawiasu. Teraz spróbuj położyć FOB wraz z powrotem i wszystko pójdzie dobrze, to zamknięte i przystawki zastąpienie śruby znajdującej się pod logo. Włóż baterię i nacisnąć jeden z przycisków gumowych. Czerwona dioda powinna pochodzić na. Jeśli nie to najprawdopodobniej problem jest, że dwa pliki t Haven został zainstalowany słusznie więc sprawdzić te. 7. Bit Scarey Następna zabraknie i spróbować klawisza. Oba przyciski powinny działać i .. klucz powinien rozpocząć samochód. Jeśli klucz nie robi t get uznane przez samochód a następnie otworzyć go ponownie i sprawdzić odpryski cyny. To s o tym bardzo trudno w sposób i na pewno nie dla nowicjuszy. Wszelkie pytania, to napisz do mnie na stockdam@hotmail.co
