Pokaż wyniki od 1 do 2 z 2
Przeglądasz Forum Alfa Romeo - Alfaholicy. Wyświetlony wątek znajduje się w dziale Zrób to sam - Czyli instrukcja serwisowa pisana przez naszych użytkowników. W tym dziale przeczytasz m.in. jak wymienić termostat, filtry, żarówki, tarcze i klocki hamulcowe, a nawet sprzęgło czy pasek rozrządu.
UWAGA!!
W tym dziale publikujemy opisy napraw, przydatne dane techniczne itp. Nie komentujemy i nie zadajemy pytań!
    Menefreghista Romeo Avatar piotriix
    PL
    Czas spędzony na forum
    4 d 20 h 42 m
    Domyślnie Kluczyk (schematy, zdjęcia)
    Oryginalny tekst [eng] (zdjęcia na końcu)
    Alfa 2 Button Flip Key-fob replacing a micro-switch
    Produced by Michaeld for www.alfa156.net
    Here s how I changed the microswitch
    on my 2 button flip style
    key-fob.
    Firstly here s a photo of it to show
    you the type I mean. My car is a
    2001 2L TS 156.
    My key worked fine except for
    the alarm/central locking
    button.
    Warning . Before attempting this work you need to be a fairly
    competent solderer; the components are small and any solder splashes
    could result in the key not operating - with the result that it won t start the
    car (i.e. it won t be recognised). Read through this whole document
    before starting.
    Pay Attention and Work slowly when doing this, pay special attention to
    how everything comes apart. There are several small parts that need to
    go back in the correct places when assembling the fob again. Take
    photos if possible at every stage just in case.
    Ok let s take the key apart.
    1. Firstly remove the battery.
    Flip out the key (deploy it) and this should give you access to the battery
    holder.
    Turn the screw to Unlock and then remove the battery. You can just see the
    screw in this picture.
    Here s the battery removed. The
    battery is a 3 Volt CR2032 (Panasonic
    say) which you should be able to buy
    in most electrical shops. Note that the
    +ve of the battery faces down towards
    the desk in this picture.
    2. Remove the Fob Screw
    Remove the Alfa logo (don t ask me how
    as my key doesn t have one . )
    Remove the screw under the badge.
    3. Prise Open the Fob
    This part may be tricky the previous
    owner had glued the end of my key
    together to prevent it falling off the key
    ring (i.e. to stop the metal thingy coming out the end). Get a small blade
    screwdriver and slowly work around the join of the fob prising it apart. Due to the
    glue mine only opens like a clam shell which makes working at it harder (so all my
    descriptions are with the key prised open from the battery side), yours should open
    fully and the next steps will be easier for you.
    Here s what my fob looks
    like prised open.
    The 3 pronged
    clip is important
    as it picks up the
    +ve side of the
    battery. Notice
    that all 3 prongs
    are above the
    PCB (printed
    circuit board
    i.e. the green
    board in the
    picture) do not
    insert it with the
    middle one
    behind the PCB
    (this is a very
    easy mistake to
    make). Note the
    middle prong
    touches a large
    brown contact
    pad on the PCB.
    Also note the small clip marked 2. It s not that easy to see so I left the resolution on the
    photo quite high. This clip must again be above the PCB and when the key is
    assembled it touches the brown contact pad on the PCB. Do not replace the PCB
    with this contact hidden it must be on the underside of the PCB as shown and not
    on the component side. This clip is part of a large metal clip which starts off at the
    very back of the fob as seen looking at the photo (i.e. it is way down inside the fob
    where my finger is at the bottom of the photo). The job of this clip is to pick up the ve
    of the battery and to route it to the contact shown.
    Note - please look carefully at these two clips before taking the fob apart as they
    must go back exactly in the right positions. The 3 pronged clip is held in by the PCB
    and will fall out as soon as you remove the PCB. This clip is very fiddly to get back in
    correctly.
    Note also that the key itself is sprung and will fall out so try to see how it goes together
    before it falls out and don t loose and of the parts there s a small spring and a
    keyed button (that s the button you use to deploy the key).
    4. Remove the PCB
    Maybe your fob will come right apart and the next stages will be easier for you. I had
    to work with the fob levered open as shown above.
    Next prise out the PCB put a small bladed screwdriver in behind it and it should fall
    out. Make sure you don t loose the 3 pronged clip.
    5. Replace the Micro-switch
    You should see two micro-switches on the PCB. However it is not unusual for one of
    them to have broken or partially fallen off. Locate the broken micro-switch and
    desolder it from the board. You ll need a fine solder tip for this and steady hands. Do
    not splash any solder on the PCB or like me you ll short out some tracks and the key
    won t be recognised by your car. If you do then remove the solder splash with some
    braid (the braid from inside a TV aerial BNC cable should work).
    The micro-switches are similar to this .
    This is a J bend one the contacts at either end are shaped like
    a J. The fob uses gull wing ones which are shaped like an L so
    the electrical contacts lie flat on the PCB.
    Here s a drawing
    of the gullwing
    type.
    The micro-switches are from ITT and are KSR251G type
    (KSR253G will also do as will KSR231G and KSR233G).
    Here s the PCB
    removed.
    The micro-switches are the
    silver rectangles with black
    dots (buttons) marked as 1
    and 2.
    1 is for the central
    locking/alarm and 2 is the
    boot release (I hope that s
    correct). This is the view
    after I replaced the switch
    so I haven t got a photo of
    it broken (the top was
    cracked and part of it
    eventually fell out).
    Here s what it looked like after I had removed
    the faulty switch.
    Sorry about the quality of this picture arrow 1
    points to the area where the central locking
    micro-switch was removed. The contacts are to
    the left and right of the tip of the arrow. Arrow 2
    points to the other micro-switch still I position
    (you can just make out the black button).
    6. Putting it Back Together
    This is actually quite hard and requires 4 hands .
    Snap the key back as shown in section 3 so the fob is open like a clam-shell. Or if your
    key comes fully apart then ignore and just proceed to the next paragraph.
    Drop in the PCB with the micro-switches against the rubber buttons on the top of the
    key. Make sure the clip at the end is touching the contact (clip 2 in section 3). Prise up
    the edge of the PCB closest to you and then slip the 3 pronged clip in under it making
    sure all 3 prongs are visible. Jiggle the clip until it touches the contact and the edge of
    it is trapped by the edge of the PCB. It s hard to describe so that s why I suggested
    paying attention to how it came out.
    Now insert the spring for the key and put the button on the end of it. Note the button
    has 3 keyed lugs on it which locate into the hinge of the key. The spring has a foot
    sticking out of it and this foot anchors the spring against a plastic lug on the fob. Wind
    the button up against the spring so that it flips the key out when deployed. Wind it anticlockwise
    looking down on it I wound it three rotations I think. Next slip the key over
    the button and using a screwdriver or forceps turn the button until it springs into place
    in the recess in the key note the button must protrude out the top of the key so make
    sure the lugs in the button slip into the correct slots in the key hinge.
    Now try to put the fob back together and is everything goes well snap it shut and
    replace the screw which was under the logo.
    Replace the battery and press either of the rubber buttons. The red LED should come
    on. If not then the most likely problem is that the two clips haven t been installed
    correctly so check these.
    7. The Scarey Bit
    Next run out and try the key. Both buttons should work and .. the key should start the
    car. If the key doesn t get recognised by the car then open it up again and check for
    solder splashes.
    That s about it pretty difficult in a way and certainly not for the novice.
    Any questions then email me on stockdam@hotmail.com
    Zdjęcia kluczyków
    Schematy kluczyków
      Fun starts @ 3000!
    http://www.alfa156.net
      Fun starts @ 3000!
      Fun starts @ 3000!
      Fun starts @ 3000!
    Kto chce szuka sposobu,
    kto nie chce szuka powodu.
    155 V6v12 lpg -była
    156 V6v24 lpg-była
    147 2.0TS Selespeed lpg.-jest
    166 2.0 V6 TB -LPG-jest
    PL
    4 d 20 h 42 m
    Przetłumaczony [pl] (Google Tłumacz)
    Alfa 2 Button Flip Breloczek zastępując micro-switch
    Produced by Michaeld dla www.alfa156.net
    Tutaj s jak zmieniłem mikroprzełącznik
    w moim stylu przycisk 2 klapki
    breloczka.
    Po pierwsze tutaj s zdjęcie to pokazać
    ci typu I mean. Mój samochód jest
    2001 2L TS 156.
    Mój klucz pracował dobrze, z wyjątkiem
    alarm / centralny zamek
    przycisk.
    Ostrzeżenie. Przed próbą tej pracy trzeba być dość
    Właściwe solderer; elementy są małe i wszelkie plamy lutu
    może spowodować klucz nie operacyjny - w związku z czym zdobył t start
    samochodu (tzn. zdobył t uznawane). Przeczytaj uważnie cały ten dokument
    przed startem.
    Cieplutkie i Pracy powoli, gdy ten sposób zwrócić szczególną uwagę na
    jak wszystko jest osobno. Istnieje kilka małych części, które muszą
    cofnąć się w odpowiednich miejscach, gdy montaż FOB ponownie. Wziąć
    zdjęć, jeśli to możliwe na każdym etapie, na wszelki wypadek.
    Ok niech s wziąć klucz od siebie.
    1. Po pierwsze wyjmij baterię.
    Odwróć się klawisz (rozdysponowania) i to powinno dać Ci dostęp do baterii
    posiadacza.
    Skręć śrubę, aby odblokować i wyjmij baterię. Możesz po prostu zobaczyć
    Śruba w tym obrazie.
    Tutaj s baterii usunięte.
    baterii 3 V CR2032 (Panasonic
    powiedzmy), które powinny być w stanie coś kupić
    w większości sklepów elektrycznych. Należy pamiętać, że
    + ve z baterii twarze w dół w kierunku
    biurko w ten obraz.
    2. Usuń Fob śrubowe
    Usunąć logo Alfa (Nie pytaj mnie jak
    jak mój klucz doesn t have one. )
    Usunąć śruby pod odznakę.
    3. Prise Open Fob
    Ta część może być trudne poprzednie
    właściciel miał przyklejone do końca mój klucz
    razem, aby zapobiec wypadnięciu kluczowych
    pierścień (tj. do przystanku metal thingy coming out end). Get małe ostrze
    śrubokręt i powoli obejść dołączyć fob prising go od siebie. Ze względu na
    mój klej tylko otwiera jak muszli małż, które sprawia, że praca na trudniejsze (a więc wszystkie moje
    Opisy są kluczem prised otwarte z boku baterii), powinny same biblioteki
    w pełni i następnym krokiem będzie łatwiejsze.
    Oto coś co wygląda mój fob
    jak prised otwarte.
    3 zębach
    Klip jest ważne
    jak to odbiera
    + ve stronie
    baterii. Wskazówki
    że wszystkie 3 zębach
    są przede
    PCB (drukowanej
    płytki drukowane
    tj. zielony
    pokładzie
    zdjęcie) nie
    włóż ją z
    środkowa
    z tyłu PCB
    (jest to bardzo
    łatwe błędem
    make). Uwaga
    Bliski Prong
    dotyka duże
    brązowy kontakt
    Podkładka na płytce.
    Zwróć także uwagę na małe wideo oznaczone 2. Nie s to takie proste, aby zobaczyć, więc lewej rezolucji w sprawie
    Fotografia dość wysokie. Ten klip musi zostać ponownie powyżej PCB i gdy klucz jest
    zmontowane dotknie brązowy pad kontakt na płytce. Nie zastąpi PCB
    z tego kontaktu ukryte należy na spodzie PCB, jak pokazano, a nie
    po stronie elementu. Ten klip jest częścią dużej metalowy zatrzask, który uruchamia się
    samym końcu FOB jak widać patrząc na zdjęcia (tj. nie jest aż wewnątrz fob
    gdzie mój palec jest na dole zdjęcia). Zadaniem tego klipu jest podnieść ve
    baterii i przekierować go na wskazany kontakt.
    Uwaga - proszę uważnie patrzeć na te dwa pliki przed podjęciem oprócz FOB, ponieważ
    musi wrócić dokładnie w prawej pozycji. 3 zębach wideo odbywa się przez PCB
    i wypadnie jak najszybciej usunąć PCB. Ten klip jest bardzo skrzypce wrócić w
    prawidłowo.
    Zauważ też, że sam klucz jest tłumiona i wypadnie więc spróbuj zobaczyć jak to idzie w parze
    zanim wypadnie i don t luźne i części nie sa małe wiosną i
    wyczerpiesz przycisku (czyli s przycisku możesz używać do wdrażania kluczowych).
    4. Usuwanie PCB
    Może wasz przyjdzie FOB prawo od siebie i następne etapy będą łatwiejsze. Miałem
    do pracy z FOB podważeniem bramy, jak wskazano powyżej.
    Następnie odchyl się PCB umieścić małe śrubokrętu w za nim i powinien spadek
    na zewnątrz. Upewnij się, że Don t loose 3 zębach wideo.
    5. Wymień Micro-switch
    Powinieneś zobaczyć dwa mikro-przełączników na płytce. Jednak nie jest czymś niezwykłym dla jednego z
    je się, że łamane lub częściowo spadł. Znajdź podziale mikro-przełącznika i
    desolder go z planszy. You ll potrzeby cienkiej końcówki lutowniczej na tej ręce stały. Zrobić
    nie czyścić wszelkie lutu na płytce lub jak ja was ll zwarcie niektórych utworów i klucz
    wygrałem nie będzie uznawane przez Twojego samochodu. Jeśli tak to usuń splash lutu z niektórymi
    Braid (oplot z wnętrza telewizji kablowej antena BNC powinny działać).
    Mikroprzełączniki są podobne do tego.
    To J zakręcie jeden z kontaktów na obu końcach są w kształcie
    J. FOB używa Frajer te skrzydła, które są w kształcie L tak
    styków elektrycznych leżeć płasko na PCB.
    Tutaj s rysunek
    z Gullwing
    typ.
    Mikroprzełączniki są z ITT i KSR251G typu
    (KSR253G zrobi jak będzie KSR231G i KSR233G).
    Tutaj s PCB
    usunięte.
    Mikro-przełączniki
    prostokąty srebrny z czarnym
    punktów (guziki), oznaczony jako 1
    i 2.
    1 stosuje się do centralnego
    zamek / alarm i 2
    prasowa boot (mam nadzieję, że s
    poprawna). To jest widok
    po I zastępuje przełącznik
    więc t przystań dostał zdjęcie
    zepsute (najlepsze było
    pęknięty i części
    ostatecznie wypadł).
    Oto coś co wyglądało jak po moim usunięte
    wadliwego przełącznika.
    Przepraszam za jakość tej strzałki zdjęcie 1
    wskazuje na obszar, w którym centralny zamek
    mikro-przełącznika została usunięta. Kontaktów z
    lewej i prawej stronie końcówki strzałki. Arrow 2
    wskazuje na innych mikro-switch still I miejsce
    (można po prostu zrobić się czarny przycisk).
    To jest rzeczywiście dość trudne i wymaga 4 ręce.
    Snap kluczyk jak podano w sekcji 3, tak FOB jest otwarte jak clam-shell. Albo, jeśli
    klucz jest w pełni poza to zignorować i po prostu przejść do następnego akapitu.
    Spadek PCB z mikro-przełączniki przed gumowe przyciski na szczycie
    klucz. Upewnij się, że wideo w końcu dotyka kontaktowe (clip 2 w pkt 3). Prise się
    krawędzi płytki najbliżej Ciebie, a następnie wsunąć 3 zębach klip w jego mocy podejmowania
    czy wszystkie 3 zapięcia są widoczne. Jiggle klip aż dotknie kontakt i krawędzi
    jest on uwięziony przez krawędź płytki. To s trudne do opisania, tak aby s dlaczego zaproponował
    zwrócenie uwagi na, jak to wyszło.
    Teraz wstawić na wiosnę na klucz i umieścić przycisk na koniec. Uwaga: Przycisk
    ma 3 wyczerpiesz występy na to, które znaleźć pod zawiasy klucz. Wiosna stóp
    wystającą i ta kotwice stóp wiosną przed plastikowe LUG na fob. Wiatr
    zapiąć od wiosny tak, że odwrócenie kluczyk przy wdrożeniu. Wind it tyłu
    patrząc na nią I ran to trzech lotów myślę. Następnie wsunąć klucz w ciągu
    przycisk i za pomocą śrubokręta lub pęseta włączyć przycisk, aż rodzi się na swoim miejscu
    we wnęce w kluczowych Uwaga przycisk musi wystawać na górze klawisz tak zrobić
    Upewnij się, że występy w poślizg przycisk do odpowiedniego gniazda w kluczowych zawiasu.
    Teraz spróbuj położyć FOB wraz z powrotem i wszystko pójdzie dobrze, to zamknięte i przystawki
    zastąpienie śruby znajdującej się pod logo.
    Włóż baterię i nacisnąć jeden z przycisków gumowych. Czerwona dioda powinna pochodzić
    na. Jeśli nie to najprawdopodobniej problem jest, że dwa pliki t Haven został zainstalowany
    słusznie więc sprawdzić te.
    7. Bit Scarey
    Następna zabraknie i spróbować klawisza. Oba przyciski powinny działać i .. klucz powinien rozpocząć
    samochód. Jeśli klucz nie robi t get uznane przez samochód a następnie otworzyć go ponownie i sprawdzić
    odpryski cyny.
    To s o tym bardzo trudno w sposób i na pewno nie dla nowicjuszy.
    Wszelkie pytania, to napisz do mnie na stockdam@hotmail.co
      Fun starts @ 3000!
      Fun starts @ 3000!
      Fun starts @ 3000!
      Fun starts @ 3000!
    155 V6v12 lpg -była
    156 V6v24 lpg-była
  3. Thanks Parzi thanked for this post
    kluczyk alfa romeo 147
    kluczyk
    kluczyk alfa 147
    mikroswitchpilot alfa 147schemat kluczyka alfa 147bateria do kluczyka alfa 147kluczyk alfaalfa romeo 147 schemat kluczykaprzełącznik z kluczykiem schematwww.ask.comrozrząd schematfob kluczykschemat kluczyka pilotahow to change micro switch fobpilot uniwersalny brelok schematmicroswitch alfa romeoschemat kluczyka alfamikroswitch kluczykawnętrze kluczyka alfa romeoswich do wymianymicroswitch schematwymiana baterii kluczyk alfa 147fob ksr253gmikroswiche do pilotamicro switch pod maska 147
