Użytkownik
Świeżak
Fiatmultiecuscan
Czy multiecuscan bedzie działał na kablu od delphiego? Jesli nie, jakie potrzebuje kupic kable/kabel zeby obsłuzyc w pełni alfe 147 2008r. bo czytałem ze jeden nie wystarczy?
Użytkownik
Jestem NOWY - nie krzyczcie!
[lang=en]I use MultiEcuScan diagnostics with ELM interface and KKL interface it has a module selection switch on it.
Adapters are required for the ELM interface so that it can be connected to different modules.
• KL - KKL/VagCom/OBDKey interface
• ELM - ELM 327 v1.3+/OBDLink/OBDKey interface
• A1 - ADAPTER CABLE 1 (green)
• A2 - ADAPTER CABLE 2 (row)
• A3 - ADAPTER CABLE 3 (yellow)
• A4 - ADAPTER CABLE 4 (purple)
• A5 - ADAPTER CABLE 5 (blue)
• A6 - ADAPTER CABLE 6 (gray)
• 3-Pin - 3-PIN ADAPTER CABLE
• P1 - Pin 1 (for interfaces with pin switch)
• P3 - Pin 3 (for interfaces with pin switch)
• P9 - Pin 9 (for interfaces with pin switch)
• P12 - Pin 12 (for interfaces with pin switch)
• P13 - Pin 13 (for interfaces with pin switch)
List of modules to be connected and which interfaces are required.
• Bosch EDC15C7 CF3/EOBD Diesel Injection (1.9 8V, 2.4 10V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM
• Bosch EDC16 CF3/EOBD Diesel Injection (1.9 16V, 2.4 20V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM
• Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9 16V, 2.4 20V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM
• Bosch ABS 5.7 |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
• Bosch ABS 5.7 ASR/TC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
• Bosch ABS 5.7 VDC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
• Bosch ABS 8 |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
• Bosch ABS 8 ASR |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
• Bosch ABS 8 VDC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
• Allied Airbag MY97 |INFO|DTC|PRM| KL A2 P3
• Siemens Airbag MY99 |INFO|DTC|PRM|ACT| KL A2 P3
• Service Interval Reset |INFO|ADJ| ELM
• Connect (NAV) Marelli |INFO|DTC|PRM|ACT| ELM
• Convergence Marelli/Microsoft (Blue&Me) |INFO|DTC| ELM
• Convergence Marelli/Microsoft C3 (Blue&Me Nav) |INFO|DTC| ELM
• Instrument Panel Mannesman VDO |INFO|DTC|PRM|ACT|ADJ| ELM
• Body Computer Marelli (937) |INFO|DTC|PRM|ACT|ADJ| ELM
• CAN Info |INFO| ELM
• CAN Monitor / Vehicle Settings |DTC|PRM|ADJ|
• CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELM
• Delphi climate control (Dual zone) |INFO|DTC|PRM|ACT| ELM
• Delphi climate control (Single zone) |INFO|DTC|PRM|ACT| ELM
• Bosch XENON headlamp (left) |INFO|DTC|PRM|ACT|ADJ| KL ELM A1 P12
• Bosch XENON headlamp (right) |INFO|DTC|PRM| KL ELM A1 P12
• Valeo XENON headlamp (left) |INFO|DTC|PRM|ACT|ADJ| KL ELM A1 P12
• Valeo XENON headlamp (right) |INFO|DTC|PRM|ACT|ADJ| KL ELM A1 P12
• Boot/Rear Doors TRW |INFO|DTC|PRM|ACT| ELM
• Driver's Door TRW |INFO|DTC|DTC EX|PRM|ACT| ELM
• Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9 16V, 2.4 20V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM[/lang]
Użytkownik
Świeżak
Czy ktoś ma multiecuscan na Windows XP?
- Nie możesz zakładać nowych tematów
- Nie możesz pisać wiadomości
- Nie możesz dodawać załączników
- Nie możesz edytować swoich postów
Zasady na forum
