- brakujące opisy blędów z rodziny P1xxx.
P0100 -> Air Flow Meter
P0105 -> Pressure Sensor in Manifold
P0110 -> Air Temperature Sensor
P0115 -> Water Temperature Sensor
P0120 -> Throttle Valve Potentiometer (DKG)
P0130 -> Lambda Sensor
P0170 -> Lambda Regulation
P0201 -> Injector Cylinder 1
P0202 -> Injector Cylinder 2
P0203 -> Injector Cylinder 3
P0204 -> Injector Cylinder 4
P0230 -> Fuel Pump Relay
P0325 -> Knock Sensor
P0335 -> Engine RPM Sensor [Crankshaft Position Sensor]
P0336 -> Reference Mark (teeth == 60)
P0340 -> Engine Timing Sensor [Camshaft Position Sensor]
P0443 -> Canister
P0480 -> Fan 1 Relay
P0481 -> Fan 2 Relay
P0483 -> Fans Control
P0500 -> Vehicle Speed Sensor
P0560 -> Battery Voltage
P0605 -> ECU Rom / Eprom Error
P0654 -> TD Signal for Rev Counter
P0655 -> Engine Coolant Over Temperature Warning Light
P1171 -> Self-Adaptation Parameters DTV
P1172 -> Self-Adaptation Parameters TRA
P1173 -> Self-Adaptation Parameters FRA
P1325 -> Knock Evaluation Circuit
P1511 -> Throttle Valve Potentiometer MDS (DKS)
P1512 -> MDS Motor Blocked
P1513 -> MDS Final Stage
P1531 -> Conditioner Compressor Relay
P1653 -> Timing Variator
P1654 -> Modular Manifold
U1600 -> Immobiliser
OBD II Fault Codes Reference Guide
The Diagnostic Trouble Code numbering follows a standardized structure. All Diagnostic Trouble
Codes have a letter
followed by a 4-digit number (e.g. P1234).
The first letter defines the system designation:
First Letter
System Designation
P Power train
C Chassis
B Body
U Network Communications systems
For EOBD, first digit defines code type
First Digit
Code
0 Standard EOBD
1 Defined by vehicle manufacturer
2 Standard EOBD
3 Network Communication
Second digit defines system identification
Second Digit
Meaning
0 Standard Code. Refer to generic P0 code list.
1 Fuel or Air Metering and Auxiliary Emission Controls
2 Fuel or Air Metering and Auxiliary Emission Controls
3 Ignition System or Misfire
4 Auxiliary Emission Controls
5 Speed control (Idle, vehicle and Auxiliary Inputs)
6 Trip Computer and Auxiliary Inputs
7 Transmission
8 Transmission
9 Transmission
Other Code Groups which may be read:
P10-- to P12-- Fuel and Air Metering and Auxiliary Emission Controls
P13-- Ignition System or Misfire
P14-- Auxiliary Emission Controls
P15-- Vehicle Speed, Idle Control, and Auxiliary Inputs
P16-- Computer and Auxiliary Outputs
P17-- to P19-- Transmission
P2--- SAE Controlled DTCs
P20-- to P22-- Fuel and Air Metering and Auxiliary Emission Controls
P23-- Ignition System or Misfire
P24-- to P29-- SAE Reserved
P3--- Manufacturer Controlled and SAE Reserved
P30-- to P32-- Fuel and Air Metering and Auxiliary Emission Controls
P33-- Ignition System Misfire
P34-- to P39-- SAE Reserved
