Typy przepływomierzy/wkładek
  • Autor wątku Autor wątku ap2
Z góry przepraszam za odkop, ale czy któryś z użytkowników posiada może programik udostępniony przez kolegę @sdero w poście #556 (https://www.forum.alfaholicy.org/14...womierzy_wkladek-post2055145.html#post2055145). Na serwerze nie jest już niestety dostępny a nie mogę ogarnąć wzoru, który podawał w #555.
Edit:
Znalazłem na forum MES taką informację:
"When reading data from the ECU, the mass air flow is not reported in kg per hour but in mg per stroke. Converting one value to the other is quite simple:
At 900 RPM a 4 cilinder 4 stroke engine makes 900 RPM * 2 strokes/revolution * 60 minutes in one hour = 108,000 strokes. So if the ECU reads 480 mg/stroke at idle, it equals to 108,000 * 480e-6 = 52 kg/hour air flow. 480 mg/stroke is the value you should read with a 1.9L engine during idle when the EGR is closed. One full cilinder filling is 0.48 liter. Air is about 1290 mg per liter. So one could calculate 0.48 * 1290 = 619 mg/stroke. However, the cilinder is not fully filled as it has to suck in the air in a limited amount of time. Therefore the value is a little lower. (If the turbo would be really working at idle, the air flow could be higher than 619 mg/stroke.) The output voltage of a Pierburg MAF during idle and closed EGR is about 1.6V. A Bosch MAF reads about 2.2V in this situation. With a closed EGR you should measure about 480mg/stroke. With a 78% opened EGR you should read about 290 mg/stroke. If the values you find are much lower, something is blocking the air flow or the MAF has gone bad. The air flow can be blocked by a clogged air filter, a clogged intercooler, a (partly) closed anti shudder valve, a clogged intake manifold or bad valves. The intake manifold may clog due to soot/oil as exhaust fumes are fed back into the engine by the EGR and oil is fed into the engine by the CCV. It's also possible that the EGR is stuck open."
Wykonując przeliczenia wg powyższego wzoru masa zmierzona na wolnych obrotach wychodzi mi większa od oczekiwanej, co zgadzałoby sie z faktem że egr jest zaślepiony.
Da się jeszcze gdzieś dostać przepływomierz z wkładką F 00C 2G2 044 lub F 00C 2G2 030 za poniżej 300zł?
Ewentualnie czy ten F 00C 2G8 338 też będzie dobry? Potrzebuję do Stilo 1.9 JTD 115KM
