Show results from 71 to 80 with 306
		Subject: What battery should be 1.9 JTDm?
	03-02-2012, 18:52 #71
				I have something like this http://www.autokosmetyki.pl/w%C4%82%...pray,p865.html
Pseudobulbs in all holes and the game, and so seriously all padlocks, locks, ignition key in the car, his wife and everything move the walls.
› Więcej...: What battery should be in 1.9 JTDm?
	03-02-2012, 19:00 #72The user Quadrifoglio Verde
- He joined the
 - 11 2010
 - Lives in
 - Debica RDE - podkarpackie
 - Auto
 - AR 159 SW, Progression, Nero Oceano, 1.9 JTDm 16V, 2006r.
 - Posts
 - 6,842
				radzik OK but I asked about the K2 Vulcan because that I have and I do not know if it can be or not really? One more question with a series of stupid but I'm kinda a layman so I ask, and you are a little posmiejcie. How to clean the easiest plug aku? Fine paper sciernym can be? And if you can let someone answer my previous question-how to get into the car when we fall completely aku?
	03-02-2012, 19:03 #73
	03-02-2012, 19:09 #74
				Plug you can paper purge. And how will it completely this rozbierasz aku electronic key and open the the door metal insert.
	03-02-2012, 19:14 #75
				First, empty Castle defroster it later grease, how to continue to be held, you can put down a Vulcan, smarten Castle and at the end of the grease.
Joint clean out fine paper, later a spray electrical connections or technical Vaseline on founded plug.
Have you tried to open the car with the remote control because the end of the rozładowałeś the battery? Yesterday in the car of his wife, also could not close remote control because aku barely hovering, but after 5 minutes, amazingly I could close and open the remote control, if not open with remote or key, you can hook up the cables to the boot or the charger as far as you can.
	03-02-2012, 19:46 #76The user Quadrifoglio Verde
- He joined the
 - 11 2010
 - Lives in
 - Auto
 - Posts
 - 6,842
				But how to hook the cables as the mask is closed? Speaking about the sample situation. Do not rozladowalem aku to the end. Just crashed in August computer and swiecil August in and light is pASOand the Jingle quietly some podzespol (but what I do not know). Just przezywam last the horror of this alfina. Why does she make me so stressed? Kalma I know that demolish the key and uzwam Metal Blade but today I do not want to turn the Castle so I ask if there are other ways besides nailing glazing because it's the easiest and most cruel way to get to the inside without a key. I guess uchyle maske for the night just in case if I fell aku. Niedomkne just so I poloze on the mask. One can not nothing powykreca:-(
	03-02-2012, 19:56 #77
	03-02-2012, 20:08 #78The user Quadrifoglio Verde
- He joined the
 - 11 2010
 - Lives in
 - Auto
 - Posts
 - 6,842
				and one more question. Has an effect on aku length its loading? I have doladowuje rozladowal in August because that aku nowke (bought in last Saturday). Load it from 12 from 6A. I do not know because I do not want to also przedobrzyc in order not to have the bad effects. You can no longer have hooked the battery in charger or not really?
	03-02-2012, 20:09 #79
	03-02-2012, 20:15 #80
Similar threads
What should be the cabin filter?
Created by Dziubek99 in section 166Response: 19Last post/author: 20-09-2016, 21:05 -
The rear anti-roll bar what the clearance should be ?
Created by e5nio in section 156Response: 3Last post/author: 13-01-2014, 17:25 -
[159] Which is better to buy battery for ar159 1.9 JTDM 150KM ?
Created by Bllondas in section 159/Brera/Brera SpiderResponse: 4Last post/author: 05-03-2012, 12:48 -
What should be the correct boost??
Created by Kayrol in section 156Response: 3Last post/author: 04-10-2011, 16:52 -
[33] What should be the battery 33 1.4 and a boxer?
Created by alfa 33 in the section 33/164Response: 4Last post/author: 07-12-2010, 21:00
