Page 9 with 31 The firstThe first 12345678910111213141516171819 ... LastLast
Show results from 81 to 90 with 306
  1. #81
    The user Maniac resoraków Avatar radzik2908
    He joined the
    03 2011
    Lives in
    Siemiatycze, Podlaskie
    Posts
    648
    Quotation Wrote Czarny_28 Zobacz post
    My has 72 Ah but pretty does not rozladowal because even filmed. I do not know at this so I ask. Sorry for the przyglupawe questions but I prefer to ask than cause trash and cry that went wrong. That is, how much should I load your? approx. 20 hours?
    Black, a mistake 7, 2A, for 10 hours, that is, you should no longer disconnect, and the proof of this quote from the battery:
    "Shock of not more than 1/10 (e.g.: 45 Ah-4.5 A) not more than 10 hours. If you have a hydrometer after obtaining density 1.28 G/cm"
    › Więcej...: What battery should be in 1.9 JTDm?
  2. #82
    The user Quadrifoglio Verde Avatar Czarny_28
    He joined the
    11 2010
    Lives in
    Debica RDE - podkarpackie
    Posts
    6,842
    well, you disconnect immediately because it is 13 hours already passes. I do not have a hydrometer, and battery charger pozyczony from neighbor of zeszlej erazero distance only controls with the clue and the knob. I need something to buy. What do you think about this? http://allegro.pl/solidny-mocny-pros...087245107.html
  3. #83
    The user Stallion Avatar kalma
    He joined the
    04 2011
    Lives in
    Gliwice
    AR159 JTDm 16V 2007
    Posts
    170
    Looks OK, but as you do not want to worry about charging batteries, to buy the charger with microprocessor control of the loading process. Then you connect the batteries and forget about the case.
  4. #84
    He joined the
    03 2011
    Lives in
    Posts
    648
    Black, I suggest Norauto nx3000, or have a look here http://www.semi.com.pl/
    Call them, surely You will tell itbuy.
  5. #85
    He joined the
    11 2010
    Lives in
    Posts
    6,842
    Damn and I forgot odpiac aku. Of persecution to the wound that is 20 hours. I hope that it will be nothing. Boys do not have enough money to buy a battery charger. Now I have a lot of expenses and cash slowly ends so I have so gora 200 zl
  6. #86
    The user Beginner Avatar BeBe
    He joined the
    12 2011
    Lives in
    SG
    2008 159SW
    Posts
    237
    And what has to happen? After charging rectifier loads the minimum current row. No, unless you have the charger where it ask non-stop 6A or Iles there. Then the rifle with your hand it.
  7. #87
    He joined the
    11 2010
    Lives in
    Posts
    6,842
    and I know how to popzyczylem the old corpse
  8. #88
    He joined the
    03 2011
    Lives in
    Posts
    648
    I found the company with you:
    F.h.u. "BATER BIS" batteries and car mats
    ROAD WORKERS 7, DĘBICA, subcarpathian voivodship, 39-200, Poland
    (14) 6834020
    Have the offer rectifiers the company Masta, too bad. Call.
  9. #89
    The user Pasjonat Avatar jahu
    He joined the
    04 2008
    Lives in
    Posts
    3,428
    When you have connected it just once is nothing will happen. If you bind it every few days is aku after several months probably breathed his last by the spirit.
    If you do not have this workshop does not make sense to push into a super expensive rectifiers (unless you like). I haven't used the charger from 6-7 years. now, with all the problems with battery/launching this I try to fire up the boot and cables immediately looking for the cause of the problem (I buy a new battery, possibly features auto to electrician to control the starter and alternator). If your problem is fuel is the only thing you need to do is to remove the cause of the problem and forget about the case, and does not deal with the battery.
  10. #90
    He joined the
    11 2010
    Lives in
    Posts
    6,842
    but the charger so or so useful and do not like to spend a lot of money on such things so buy something affordable but not cheapest. Radzik Drogowcow is close to my work so I walk up after Sunday. Thanks for the hint. Best regards
Similar threads
  1. What should be the cabin filter?
    Created by Dziubek99 in section 166
    Response: 19
    Last post/author: 20-09-2016, 21:05
  2. Response: 3
    Last post/author: 13-01-2014, 17:25
  3. [159] Which is better to buy battery for ar159 1.9 JTDM 150KM ?
    Created by Bllondas in section 159/Brera/Brera Spider
    Response: 4
    Last post/author: 05-03-2012, 12:48
  4. What should be the correct boost??
    Created by Kayrol in section 156
    Response: 3
    Last post/author: 04-10-2011, 16:52
  5. [33] What should be the battery 33 1.4 and a boxer?
    Created by alfa 33 in the section 33/164
    Response: 4
    Last post/author: 07-12-2010, 21:00
battery alfa 159
alfa 159 battery
what battery for alfa romeo 159 1.9 jtdm
battery alfa 159 1.9 jtdm
what battery for alfa 159 1.9 jtdm
what battery on the alfa 159 1.9 jtdm
battery alfa romeo 159 1.9 jtd
alfa 159 1.9 jtd as a battery
what battery for alfa romeo 159 jtdm
what battery multipla 1.9 jtd
as battery alfa romeo 159 jtdalfa romeo 159 1.9 jtd as a batterybattery alfa romeo 159 jtdmalfa romeo 159 jtdm as a batteryakymulator do alfy 159batteries for alfa 159alfa romeo 159 1.9 jtdm batteryalfa romeo 159 1.9 jtd batterybattery alfa 159 jtdmfiat multipla batteryBattery Pack Alpha 159 2.0 battery alfa romeo 159 2 0what battery for alfa romeo 159 jtdmbattery for alfa romeo 159 jtdmalfa 159 battery factory1.9 jtdm batterywhat options multipli battery for fiat 1.9 jtd1.9 jtd120 jaki akumulatormultipla what batteryalfa romeo 159 jtdm batteryakumulator alfa romeo 159 1.9 jtdmbattery alfa romeo 159what battery on the alfa 159 1.9alfa romeo 159 1 9 battaryas batteries, alfa159 jtdm 8v1.9what should be the battery in alfie jokesbattery 159battery for alfa 159jaki akumulator alfa 159 1.9alfa 159 akumulator plusoryginalna pojemnosc akumulatora do alfy 159 1.9jaki akumulator alfa 159 jtdmalfa 1.9 110 koni jaki akumulatorquel batterie pour alfa 159jtd 1501.9 jtdm 120 km jaki akumulatorakumulator alfa romeo 159 1.9 jtdm 150 konidati tecnici batteria alfa 159akumulator fiat multipla jtd
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
