Page 1 with 56 123456789101151 ... LastLast
Show results from 1 to 10 with 560
    The user Dwusuwowiec
    He joined the
    04 2008
    Lives in
    Zabrze
    Alfa 159 2,4 JTDM / Cinsoft
    Posts
    103
    Domyślnie Update your Nav Connect firmware
    On the net I found something like this
    http: //translate.googleusercontent.c..._i6BZt-iug3FYA
    Can someone share such a file?
    › Więcej...: Update your Nav Connect firmware
    The user Maniac resoraków Avatar marqo
    He joined the
    09 2010
    Lives in
    Opole
    AR 159 SW 1.9JTDM Q-Tronic 08'2007
    Posts
    581
    Quotation Wrote michal121 Zobacz post
    I'm also interested ...
    ---------- Post at 07:16 ---------- The previous post was posted at 06:45 ----------
    ---------- Post at 7:18 am ---------- The previous post was written at 07:16 ----------
    ---------- Post at 7:18 pm ---------- The previous post was posted at 07:18 ----------
    ---------- Post at 7:19 pm ---------- The previous post was posted at 07:18 ----------
    Best regards
    He joined the
    09 2010
    Lives in
    Opole
    Posts
    581
    To find out what version of Navi software is available:
    - press trip
    - press Setup (middle button)
    - press Connect (right button)
    - Press 3x Connect
    - press the right knob
    An additional "System" submenu appears.
    Best regards
    He joined the
    04 2008
    Lives in
    Zabrze
    Posts
    103
    Domyślnie Alpha 159
    Can take a snapshot and buy Such a compact. I'm too
    He joined the
    09 2010
    Lives in
    Opole
    Posts
    581
    I found on www.alfanatiques.com Only with Rapida without a premium account is heavy sucking. Maybe someone who has a premium account is a different server:
    Link to firmware: http://rapidshare.com/#download|764|...ROMEO.rar|5086
    Link to installation instructions: http://rapidshare.com/#!download|700|424267545|INSTRUCTION.docx|780
    Best regards
    The user Romeo Avatar YonasH
    He joined the
    07 2010
    Lives in
    Poznan
    Brerrrrra V6
    Posts
    1,201
    I downloaded what to throw?
    ... V6 sound - priceless!
    The user Stallion Avatar Lukasz78
    He joined the
    05 2009
    Lives in
    Bielsko-Biala
    BMW 520d / 177KM LCI 2008
    Posts
    192
    Domyślnie The firmware 12.3 and Alpha logo are ruled
    On the sofa and the instructions from these links already on Wednesday I've uploaded the navi. I did as in the instructions. The FLASHERA.2 status screen went past. The third line that is loading the program into memory probably went something wrong. He looked at the black screen and nothing. Flasher again started work. And again stuck on the black screen. I switched on and off. The logo itself appeared, I thought it worked but d ***. As it did not disappear. CD stuck in the drive. I just got the beautiful Alfa logo and so much. I had to take the CN + out of the car, untwist to get into the drive and then I was able to remove the disc. After turning on the power, resetting the setting mechanicI.I recorded a new board (nero, x4, dao / 96) i put a plate and nothing ... Logo as it was. It does not help. The unit is locked.
    * Update * (22.10.2010):
    Reprogramming (as far as possible) is only for the manufacturer of MM. The reason can be dedicated to the MM processor with integrated memory (ST BCC VJ528VNK under the fan). About the track further with the "friend" of the Fiat Auto trainer Poland in BB
    PS- admit to who has the same symptoms and sent equipment to the service until you know it, hmm?
    The user Romeo
    He joined the
    01 2010
    Lives in
    W-wa
    A159 2,4 SW QT
    Posts
    1,684
    I wonder if this soft is not up to the newer version of connect navi (unless G2) - this after 10.2007 - that is with this round menu
    He joined the
    09 2010
    Lives in
    Opole
    Posts
    581
    I just finished what I ended up with a SUCCESS upgrade. Autko I got from 08.2007 and earlier had v. 11.4 and now 12.3 on board.
    Lukasz78, did you enter the code during the update?
    ---------- Post at 22:02 ---------- The previous post was posted at 22:00 ----------
    Quotation Wrote alf-a147 Zobacz post
    After updating to 12.3, G2 maps should also work, but it will only be confirmed tomorrow as some G2 will have. Old maps operate under 12.3
    Best regards
    VIP Maniac resoraków Avatar Mariusz AutoDS
    He joined the
    09 2009
    Lives in
    Minsk Maz.
    147 1.9, 159 SW 2.4, Fiat x1 / 9
    Posts
    856
    Quotation Wrote Lukasz78 Zobacz post
    I do not hide that I'm damn interested in such a dump because I would like my bug fix myself.
    I do not think it was possible to make a backup .. because somehow there is not very much media to do that in navi record .. You will need to search version v. 11.4.
    ---------- Post at 22:41 ---------- The previous post was posted at 22:25 ----------
    Quotation Wrote marqo Zobacz post
    ... but .. in French it is ..m someone in english .. german and best in polish? Maybe someone knows French and would be so polite and would translate the following:
    INSTRUCTION DE MISE A JOUR
    TRADUCTION EFFECTUE PAR FANOU DU FORUM ALFA ROMEO ONLINE
    1- Voiture éteinte activer la radio Avec de bouton d'allumage (19)
    2- Presse le bouton TRIP (23) sur le Connect pour accéder & # 224; La page-écran TRIP GÉNÉRAL
    3- De la page-écran TRIP GÉNÉRAL presser le bouton MY CAR, en sur la display, de façon & # 224; Passer & # 224; La peut arriver que le la car, so bu pas cher, le buzzer, etc ..)
    4- Allez dans la page-écran AUDIO en pressant la touche AUDIO (24)
    5- Insérer le CD firmware, et attendre quelques secondes l'apparition de la fen CD CD ERROR.
    6- Éteindre le Connect bouton d'allumage (19). Attendre et la vérifier la compl.
    7- Rallumer le CONNECT touche d'allumage (19)
    8- Le message apparaît: FLASHER PROGRAM avec la séquence des opérations sont en train d'arriver.
    9- Presse de mani et rapide et sans interruptions les boutons suivants 3-4-5-6 sur le bas et bouton (9) en haut & # 224; L'extr & # 234; me droite. (De façon & # 224; composer 3-4-5-6-9 rapidement)
    10- Un double allumage confirme la reconnaissance du password.
    11- Apréal quelques second la séquence des et implanté.
    12- Le CD est expulsé automatiquement: l'extraire.
    13- Au retour du logo ALFA éteindre le CONNECT bouton ON / OFF (19)
    14- L'opération a été accomplis: le CONNECT est opérationnel.
    15- Maintenant entrer en AUTODIAGNOSTIC et valterer le le ait correctement été chargé dans la ligne version SW, The queer les chambres chiffres correspondent au SW chargé. 11.3 (pour d'autres renseignements voir procédure AUTODIAGNOSTICCONNECT 2 ° GÉNÉRATION)
    Au cas o & # 249; Pour n'importe quel raison, la procédure de mise a jour échouait, le système et série et redémarre automatisation sans plus visualiser le logo ALFA.
    Dave cette situation (avec l'ecran noir) taper le mot de passe et attendre l'apparition d'un relatif & # 224; L'état de la modernization, dans ces cas la visualization pourrait tarder quelque seconde.
    Le dépositif répétera deux fois la séquence d'extinction / allumage, pour ensuite s'éteindre définitivement, il faut donc répartir du point 7.
    Regards, Mariusz / AutoDS Team Poland / Alfa 147 1.9 JTD GTA-look, Alfa 159 SW 2,4 JTDm, Fiat X1 / 9
Similar threads
  1. [159] Update softkey Connect Connect round menu
    Created by rokis in section 159/Brera/Brera Spider
    Response: 6
    Last post/author: 26-08-2018, 19:34
  2. [159] Nav Connect - update
    Created by Bassotronic in section 159/Brera/Brera Spider
    Response: 51
    Last post/author: 28-05-2014, 11:27
  3. Autoradio CONNECT Nav + firmware 4.08
    Created by wodzart in the section of the General Forum of the Alfa Romeo
    Response: 0
    Last post/author: 13-04-2014, 15:31
  4. Does anyone have Connect Nav + Firmware 4.08
    Created by andrzejm36 in section 147
    Response: 18
    Last post/author: 27-01-2012, 18:52
  5. Loudlink - new firmware.
    Created by szerszeń in section 166
    Response: 5
    Last post/author: 08-12-2010, 19:42
Updated alpha romeo 159 navigation
How to extinguish
What version of softwave has nav
Nav Connect 156068727
Alfa 159 what cd setup cd
forum afa romeo nawigacja navi connect
159 navigation
Connect nav alfa brera
Alfa 159 master code
Alfa 159 connect nav update
Radionav update
Updated alpha 159 navigator
Alfa romeo 159 radio navi
Master code connect nav
FIRMWARE GPS ALFA BRERA
Navteq sd
Submenu 159
Updated alpha romeo navigation software
Alpha navigation 159 update
How to check the software versions. Alpha 159
Alfa 159 connect master code
Navi 159
Locked cd alpha 159
alfa connect nav
upgrade firmware alfa romeo 159
alfa nit g2 aktualizacja
aktualizacja radia alfa 159
Autodiagnostik Passee
nawigacja karta sd
Firmware 11.4 to 12.3 chomikuj
Autodiagnostik Alf
Update maps from sd alpha card
Connect nav what version of software
Aggiornamento connect nav alfa 159
Conect navi
Cant clean tffs area
Fiat croma unsuccessful update
mise a jour gps alfa romeo 159
Connect nav alfa 159
Fiat new soft to nav conect
Connect nav 159
Master code alfa 159 connect 156068727
Firmware of 11 3 croma
Connect nav
Updated alpha romance navigation
alfa romeo 159 navi aktualizacja nawigacjifirmware 11.4 do 12.3 alfaAUTODIAGNOSTICCONNECT 2 ° GÉNÉRATIONalfa romeo 159 12.3 aktualizacjaradio z navi alfa 159 gdzie jest przycisk ok
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
