Page 135 with 135 The firstThe first ... 3585125126127128129130131132133134135
Show results from 1,341 to 1,341 with 1341
  1. #1341
    The user I'm New -do not cry!
    He joined the
    05 2019
    Alfa Romeo 159 1.9 120 km
    Posts
    20
    [EDIT]
    Dobra, chyba mam problem z niedomagającym rozrusznikiem i zacznę od tego :-)
    › Więcej...: JTDm - Ciężko pali na nierozgrzanym silniku
Similar threads
  1. White smoke on engine nierozgrzanym
    Created by vtvs in the section of the GT
    Response: 11
    Last post/author: 28-11-2015, 22:28
  2. Hard burn on a cold engine interrupts pulls
    Created by murzyncannaba in section 166
    Response: 6
    Last post/author: 28-11-2015, 11:37
  3. [159] Alfa 159 1.9 jTDm - does not fire / hard burn / light candle light
    Created by gresko1982 in section 159/Brera/Brera Spider
    Response: 2
    Last post/author: 12-03-2015, 13:36
  4. [159] 1.9 JTDm 150km - Hard to launch on a cold engine
    Created by Wolfer in section 159/Brera/Brera Spider
    Response: 2
    Last post/author: 17-09-2014, 20:04
  5. Difficult fires on a cold engine 1.9 jtdm
    Created by mike87 in the section of the GT
    Response: 7
    Last post/author: 08-02-2014, 07:23
these
Alfa 159 1.9 120 km it fires
jokes, not smokes on the summer
alfa 159 1.9 jtdm ciezko pali
159 you
vectra c 1.9 cdti hard to smoke in the cold
it is hard to smoke after Parking
vectra c 1.9 cdti problem to have
alfa 159 activation of cold
replacing the spark 1.9 cdti 8v
vectra c does not smoke, blue smoke
vectra c 1.9 a bad start
alfa 159 1.9 jtd doesn't smoke
ar159 rano problem z odpaleniem
alfa 159 hard and smokes white smoke
Opel vectra c z19dth long rolls
hard disel smoke, the smoke from the manifold
1 9 jtd 101 odpalanie silnika
vectra c 1.9 cdti smokes
vectra c 1.9 cdti swirl and smoke
1.9 jtd 120 km ciezko odpala
alfa 159 2.4 in the morning, his eyes on the white
problem z pierwszym rozruchem i dym
1.9 jtd czujnik temperatury ciezko odpala
Once was, and not just Smoking in General, vectra c 1.9 cdti
alfa 159 1.9 jtdm slightly smokes
opel vectra c white smoke under load
trudny rozruch 2.0 cdti
the alfa 159 was hard
alfa romeo 159 1.9 jtdm 120 Smoking at boot
opel vectra c 1.9 cdti in the Parking lot in front of him blue
opel vectra c 1.9 cdti problem z odpalaniem
1.9 cdti p0335-29
alfa 159 nievpali first time
hard odpalajaca alfa 159 2.4
ar 159 jtdm long activation
alfa 159 1.9 ciezko pali
It was NOT on a cold engine alfa 159 1.9 jtdm 150 k
opel vectra c as a cold smoke
weak start of the Alfa 159
jokes, not smokes
alfa romeo 159 doesn't smoke
not expect
1.9 cdti smokes
signum 1.9 it was difficult
vectra c 1.9 cdti cieszko smokes in the summer the engine
alfa 159 2.4 jtd-lit cold
collectors 1.9 jtdm white smoke under load
vectra c morning blue smoke
159 activation
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
