Show results from 1 to 10 with 1341
15-11-2010, 16:39 #1The user Dwusuwowiec
- He joined the
- 12 2008
- Lives in
- Bielsko-Biala
- Auto
- Alfa Romeo 159 150 KM SW 2007
- Posts
- 130
JTDm - Ciężko pali na nierozgrzanym silniku
Hello.
It often happens that on a cold engineat 159 ( 1,9 jtd-m) as if had no desire to light.Grabs like a second time. what could be the reason ?
› Więcej...: JTDm - Ciężko pali na nierozgrzanym silniku
15-11-2010, 17:53 #2The user The pirate way
- He joined the
- 08 2010
- Lives in
- ZAMOSC
- Auto
- VOLVO V60 D3 + MERCEDES 190E 2.6
- Posts
- 225
I see that problem with zapalaniem 159 JTDM not a rare phenomenon. It surprises me because I have a lot of old JTD and running it was the last thing I'm not worried. You can forget about the heat with candles and so burned without problems. 159 it is better to give the candle to heat up, and on warm days when not working can telepnąć at startup and not surprising, turn.
Were:
159 1.9 JTDM 2006
156 2.4JTD 2002
15-11-2010, 17:58 #3
16-11-2010, 08:37 #4The user The pirate way
- He joined the
- 08 2010
- Lives in
- ZAMOSC
- Auto
- Posts
- 225
On warm days, the condition does not matter. This morning 8 degrees lit the proverbial touch as well (- 2), but in warm days, when candles do not heat, can push longer (2 to 3 sec) and telepnąć engineiem at startup.
Were:
159 1.9 JTDM 2006
156 2.4JTD 2002
21-05-2011, 03:26 #5The user The pirate way
- He joined the
- 10 2010
- Lives in
- 3miasto
- Auto
- e500 w211
- Posts
- 264
I and I have this problem, or is it the cold or heat every time as well cool, when you start or comes on immediately, but the car for a minute(as if not palil at all Gary ,not exactly working) or is hard to start ,popping up the info on the website, something with temp engineand and off. so it is Oki,new battery, and when the General serwisie.I'd also add that the car uzytkuje abroad, and gets normal fuel.
21-05-2011, 09:04 #6The user The pirate way
- He joined the
- 08 2010
- Lives in
- ZAMOSC
- Auto
- Posts
- 225
Hmm, I also recently twice jumped info when you start on too high a coolant temperature on the cold enginehave, and then hand the temperature was going to end, and was falling. Also yesterday, some time after starting he showed me the indicator cockpit 90 degrees, and a temperature sensor for exchange.
This zapalaniem a big problem, but when the heat and the cold engine starts noticeably worse. I have lately another 159 8V and smoked is definitely better.Were:
159 1.9 JTDM 2006
156 2.4JTD 2002
21-05-2011, 11:11 #7The user The pirate way
- He joined the
- 10 2010
- Lives in
- 3miasto
- Auto
- e500 w211
- Posts
- 264
don't know exactly what kind of info POPs up heh, because it happens very quickly
only visible mark from the temperature. I really don't know what it is , when they say that is normal
well, as for me, not OK if engine in the first few seconds is not working as it should.I used the same benzyniaki and such problems at the start was not. I hope I won't fall apart? because a long journey awaits me(3.5 thousand km)
14-09-2011, 20:26 #8The user Quadrifoglio Verde
- He joined the
- 07 2007
- Lives in
- Żegocina
- Auto
- AR 159 JTDm Ti, AR Giulietta Sport, AR Spider 3.0 V6
- Posts
- 6,673
I noticed another problem. Since then, as I have a 159 (over two months), it happened only a few times when engine already had time to cool down, that is, for example, after a night of Parking (in the garage), or today in the company after 10 hours of Parking.
So, during the shooting were busy longer than usual, lit a cigarette, but the pipe sent a lot of white smoke... What could be wrong? On hot the engine never was.
Best regards.
- Raphael
15-09-2011, 08:07 #9The user Expert
- He joined the
- 05 2011
- Lives in
- Kraków, Poland
- Auto
- 147 2.0 TS, 159 2.0 Jtdm SW
- Posts
- 1,190
white smoke, burning oil or the coolant...in the worst case it could be piston rings or a gasket under the head..
15-09-2011, 08:33 #10The user The pirate way
- He joined the
- 08 2010
- Lives in
- ZAMOSC
- Auto
- Posts
- 225
Were:
159 1.9 JTDM 2006
156 2.4JTD 2002
Similar threads
White smoke on engine nierozgrzanym
Created by vtvs in the section of the GTResponse: 11Last post/author: 28-11-2015, 22:28 -
Hard burn on a cold engine interrupts pulls
Created by murzyncannaba in section 166Response: 6Last post/author: 28-11-2015, 11:37 -
[159] Alfa 159 1.9 jTDm - does not fire / hard burn / light candle light
Created by gresko1982 in section 159/Brera/Brera SpiderResponse: 2Last post/author: 12-03-2015, 13:36 -
[159] 1.9 JTDm 150km - Hard to launch on a cold engine
Created by Wolfer in section 159/Brera/Brera SpiderResponse: 2Last post/author: 17-09-2014, 20:04 -
Difficult fires on a cold engine 1.9 jtdm
Created by mike87 in the section of the GTResponse: 7Last post/author: 08-02-2014, 07:23
