to make really good dpf and egr off, with proper logic modification - to make exactly the same sofware working order as in the same ECU which has no dpf installed you need to change at least those maps:
1 EGR Hysteresis
2 EGR Hysteresis
3 EGR Hysteresis
4 EGR Hysteresis
5 EGR deviation
6 EGR SWITCH
7 EGT Sensor linearisation
8 Particle filter status vs. engine status matrix
9 Engine speed threshold to interrupt a regeneration in idle conditions
10 In Case Of Regeneration 1
11 Delay time after engine start
12 Error debouncing time for error "too many interrupted regenerations"
13 Error debouncing time for error "too many regenerations are exceeded to max. allowed regeneration time"
14 Factor for residual particulate in case of interrupted regeneration
15 EGT DETECT
16 EGT HEAL
17 EGT DETECT 2
18 EGT HEAL 2
19 Switch to deactivate the physical model output
20 Time constant for limited physical model
21 Time constant for air stream resistance
22 Time constant for soot mass
23 Negative threshold of volume flow gradient for dynamic plausibility check
24 MIN Difference Pressure For Monitoring Of DPF
25 Ower limit of difference pressure for hoseline monitoring
26 Upper limit for monitoring of particulate filter characteristic
27 Lower limit for monitoring of particulate filter characteristic
28 Oil ashes accumulated in the trap
29 EGT LINEARISATION
30 EGT DETECT
31 EGT HEAL
32 EGT DETECT
33 EGT HEAL
34 Maximum Time Allowed For Regeneration
35 MAX & MIN Temp Before Cat
36 MAX & MIN Temp Before DPF
37 DPF corrected SOT
38 RPM Threshold For Trigger Of Temperature Plausibility Check
39 Upper Limit SRC Difference Pressure
40 Lower Limit SRC Difference Pressure
41 Switch To Take The Differential Pressure Offset Into Account
42 Stops Forced Regeneration If Value Is Greater Then 0
43 Volume Flow Difference Per Second
44 Volume Flow Gradient For Hoseline Monitoring
45 Upper Temp Limit For Cold Start Detection
46 MAX Permitted Deviation During Cold Start
47 Upper Limit SRC Temperature Sensors
48 Lower Limit SRC Temperature Sensors
49 Error Debounce Time Engine Protection
50 Healing Debounce Time Engine Protection
51 Lock Time For Temp Sensor Plausibility After Short Time Running
52 DIFF PRESSURE SENSOR LINEARISATION
53 DIFF MIN VOLTAGE
54 DIFF MAX VOLTAGE
55 DIFF DEBOUNCE
56 DIFF DEBOUNCE
57 DIFF HEAL
58 DIFF HEAL
59 EGT MIN VOLTAGE
60 EGT MAX VOLTAGE
61 DPF software monitoring SWITCH - Indicates the presence of DPF and Lambda sensor in the vehicle
