Błędy silnika - pomożecie odczytać?
Cześć,
podłączyłem się dzisiaj pod AR 166 2,4 JTD z X 2000 - FES wypluł takie błędy jak poniżej - pomoże ktoś rozkodować?
P0235
P0101
P0380
P0191
P0110
P0404
http://img827.imageshack.us/img827/7801/errorsg.th.png
P0235
Boost Pressure sensor A circuit malfunction
The reason for this fault is that ECU has received very low signal from the sensor. The fault is not detected now. Clear fault codes, and observe for
future appearance of the same fault. Dashboard warning light was not activated for this fault.
P0101
Mass or Volume Air Flow Cct Range/Performance Problem
The fault is intermittent. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was activated for this fault.
P0380
Glow Plug/Heater Cct Malfunction
P0191
Fuel Rail Pressure Sensor Cct Range/Performance
The fault is not detected now. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was not activated for this fault.
P0110
Intake Air Temperature Cct Malfunction
P0404
Exhaust Gas Recirculation Cct Range/Performance
