Czy łaczył sie ktoś Unidiagiem z ABS ?
- nalezy ustawić adres z 0x10 na 0x20, oraz zmienic pin we wtyczce z 7 na pin 1.
- tylko jaka prędkośc transmisji, chyba 4800 ?
- albo kupic wtyczkę z podłaczeniem do Airbag, ABS, ECU.
- na forum Unidiaga autor programu sprzedaje takie po 40 Euro, troche drogo.
- kody błedów ABS, z transkrypcja niemiecką. Goole cos mi zle przetłumaczyło.
Kod:
LH = Left Hand / Left Side
RH = Right-handed / right side
Error codes for the ABS control unit Bosch "ABS 5.3" and "ABS 2E":
12-diagnosis - Start / End (Starts / Ends with the diagnosis)
16-valve defect magnetic front LH /
17-valve defect magnetic front RH /
18-magnetic valve defect behind
19-defective safety valve relay
25-False Übetragungstaktung-gear wheel defektr
26-magnetic valve defect behind LH
27-magnetic valve defect behind RH
28-defect discharge valve Magne front RH
29-defect discharge valve Magne front LH
31-defect discharge valve Magne rear LH
32-defect discharge valve Magne rear RH
35-pump defects Rückforderpumpe Relaikreis
37-Broken Bremslichtschalter
39-Broken Vordersensor LH
41-Vordersensor not connected LH
42-Broken Vordersensor RH
43-Vordersensor not connected RH
44-Broken rear sensor LH
45-Behind sensor is not connected LH
46-Broken rear sensor RH
47-back sensor is not connected RH
48-battery voltage is not okay
55-defect control unit
56-reading with "ausblinken" failed
74-lot impact on warning in the instrument block
