Witam.
Nie jestem bywalcem tego działu na forum ale myślę że uzyskam tutaj informacje których szukam.
Może ktoś wie jaka powinna być kompresja na tłokach w 3.0V6QV 200KM a jaka w 3.0V6 184KM? Mowa oczywiście o silniku w bardzo dobrym stanie.
Witam.
QV-10:1
zwykła 9,5:1
Alfa 164 2.0, Twin Spark, 1962 cc, 1987-, Engine Code 064-20
Ignition Data
Ignition system type: El-ecu
Ignition coil make/type: Bo/0 221 122 344
Supply voltage: 11 - Volts without ballast resistor
Primary resistance: 0.5 Ohms
Secondary resistance: 5000-7000 Ohms
Distributor make/type: Bo/0 261 200 108
Contact breaker gap/air: n / a mm
Dwell angle: n / a Deg
Ignition Timing - unleaded: 9-4/800 Deg eng/rpm (without vacuum)
Ignition Timing - leaded: 9-11/800 Deg eng/rpm (without vacuum)
Timing mark location: Pulley
No 1 plug location: O/S/F
Firing Order: 1-3-4-2
Spark plug make: Lodge
Spark plug type: 25HLD
Electrode gap: 0.6 mm
Fuel System
Fuel type: L/U +Cat
Fuel pump type/pressure: Elec/2.8-3.2 bar
Engine idle speed: 750-850 rpm
Fast idle speed: n / a rpm
CO level at idle speed: 0.4-1.2 Vol %
Engine Data
Valve clearance - inlet: 0.40-0.45 c mm (cold)
Valve clearance - exhaust: 0.45-0.50 c mm (cold)
Compression pressure: n / a bar
Oil pressure: 3.5-5.0/5000 bar/eng/rpm
Radiator pressure cap: 1.08 bar/type
Drive belt 1 - size: n / a mm/type
Drive belt 2 - size: n / a mm/type
Electrical System
Alternator output: 85/2000 Amps/eng/rpm
Regulated output: 14.4 Volts
Battery: 12/55 V/Ah
Starter motor make/type: Bo/0 001 108 048
Other Data
Clutch operation type: Hyd
Clutch adjustment: S/Adj. mm
Cambelt failure: n / a
Cambelt Part Number: n / a
Tyre pressures: 2.2(31)f 2.0(28)r bar (psi)
Back to page top or return to menu
Alfa 164, 3.0 V6. 2959 cc, 1988-, Engine Code 064-10/12
Ignition Data
Supply voltage: n / a
Distributor make/type: Bo/0 261 200 117
Ignition Timing - unleaded: 6-8/700 Deg eng/rpm (without vacuum)
Ignition Timing - leaded: 6-8/700 Deg eng/rpm (without vacuum)
No 1 plug location: O/S/R
Firing Order: 1-4-2-5-3-6
Spark plug type: 2HL
Fuel System
Fuel type: L/U +Cat
Engine idle speed: 650-750 [Cat=650-800] rpm
CO level at idle speed: 0.4-1.2 [Cat=0.2 Max] Vol %
Engine Data
Valve clearance - inlet: 0.48-0.50 c mm (cold)
Valve clearance - exhaust: 0.23-0.25 c mm (cold)
Oil pressure: 4-6/5000 bar/eng/rpm
Electrical System
Battery: 12/60 V/Ah
Other Data
Cambelt failure: Damage
Cambelt Part Number: 60562106
Alfa 164, 3.0i V6, 2959 cc, 1990-93, Engine Code 643-01
Ignition Data
Primary resistance: 0.45-0.55 Ohms
Secondary resistance: 5400-6600 Ohms
Distributor make/type: Bo/-
Ignition Timing - unleaded: n / a Deg eng/rpm (without vacuum)
Ignition Timing - leaded: n / a Deg eng/rpm (without vacuum)
Timing mark location: n / a
Spark plug make: NGK
Spark plug type: PGR6A
Electrode gap: 0.8 mm
Fuel System
Fuel type: U Cat
Fuel pump type/pressure: Elec/3.8-4.2 bar
Engine idle speed: 700-800 rpm
Engine Data
Oil pressure: 3.9-5.9/5000 bar/eng/rpm
Radiator pressure cap: 0.9-1.1 bar/type
Drive belt 1 - size: 9.5x845 KDB850 mm/type
Electrical System
Alternator output: 85/3000 Amps/eng/rpm
Battery: 12/60 V/Ah
Other Data
Cambelt Part Number: 60500466 [Cloverleaf=60561244]
Tyre pressures: 2.1(30)f 2.0(28)r bar (psi)
Niestety w tym calym litaniu nie ma informacji o kompresji.
Ja mam po mniej więcej 12 bar na każdym garze
To nie dobrze bo umie w zwykłym silnik 3.0v6 w 75 jest 10 bar. Silnik po remoncie co gorsza. W drugiej 75 z oryginalnym silnikiem QV jest po 13 bar czyli też szału nie ma skoro u ciebie w zwykłym 3,0 jest po 12 bar. Musze jeszcze pożyczyć od kogoś inny ciśnieniomierz może mój coś oszukuje.
Stopień sprężania od ciśnienia na cylindrze trochę się różni
Skoro tak zabłysłeś to teraz zabłyśnij ile to ciśnienie powinno wynosić.
Tradycyjnie okolo 13, wystarczy poszukać.
Minimalne ciśnienie sprężania dopuszczalne przez producenta to 11 bar poniżej silnik kwalifikuje się do naprawy.
A skąd wziąłeś takie wyliczenia? Pisałem już wcześniej w QV mam 13 Bar, a silnik ma przejechane 250tys wiec skąd to 12,5?
To wszystko puki co nie trzyma się kupy. W zwykłym 3.0V6 ma 10bar. Silnik ma założone wałki od wersj QV plus sterownik i przepływke od 164QV, 200KM. Do tego kolektor wydechowy CSC. Auto wypluło na hamowni 207KM czyli wydawało by się że silnik jest zdrowy, a z tego co na razie wszyscy piszą to mój silnik nadaje się do małego remontu.
Zgadza się, jest taki wzór i w przypadku seryjnych silników atmosferycznych się nawet w miarę sprawdza - ale wystarczy że silnik ma wałek ponad 270 stopni i overlap ponad 45 stopni i traci rację bytu, zbyt wielu zmiennych nie uwzględnia i trzeba o tym pamiętać - nie mniej przy seryjnych silnikach o jakich rozmawiamy jest OK.
Spróbuj wyregulować zawory na początku
Przy zmianie walkow wszystko ustawione. Ssace 0,4 wydech 0.15. Ale nie w tym rzecz potrzebuje praktycznych inlormacji a nie teoretycznych, typu mam alfe 3.0 12v mierzylem i kompresja byla ....
To nie są prawidłowe luzy. Mu tu piszemy konkretnie
Read more: http://www.forum.alfaholicy.org/33_1...#ixzz3aQuXqfuE
Wiem ze nie jest to luz jaki podaje instrukcja. Swiadomie ustawialem ciasniej.
Bryka tyle co wyjechala z garazu i byl pomiar wiec minimalnie zagrzana. Wiec moje ustawienie luzuw nie mialo na to wplywu.
A miezyles w swojej 155 3.0 kompresje?
To u mnie ciśnienie 10bar a moc bajeczna, czeski film. Znajomy ma 155 3.0 musze podjechać i sprawdzić jaką ma kompresje jego bryka.
No te luzy masz ciekawe, ja mierzylem i gtv i swoje pudło i mam 12 12,5 +/-
Czym mierzone? Tester z końcówką na gwincie czy wtykaną ? A dlaczego pytam - miałem nie dawno sytuację, dzwoni do mnie kolega że w BMW R6 zmierzył kompresję i ma po 8,5 bar równo każdy cylinder - mówię weź ty zegar sprawdź, na innym aucie. Sprawdził i zegar OK - okazało się jednak coś innego, tester miał adapter do pomiary taki na wcisk w komorę świecy, nie dochodził do końca szczelnie do gwintu tylko uszczelniał się powyżej przez co zwiększała się objętość komory nad tłokiem i zmieniał bardzo mocno stopień kompresji silnika, pomiar wykonany na adapterze wkręcanym bezpośrednio w gniazdo świecy wskazał 13,5 bar.
