Pokaż wyniki od 11 do 17 z 17
Temat: Problem z abs asr
    krisvanmoto
    A moze byc przez konczace sie tylne szczeki hamulcowe? chociaz jak jest cieplej to brak tych bledow. Mialem ten problem w zeszlym roku przyszlo lato problem znikna i teraz wrocil ponownie.
    147 1.6 TS
    to jest porblem typowo elektryczny gdzies jest slabe polaczenie albo cos jest uszkodzone
    Użytkownik Pirat drogowy
    Citroen C5 Tourer 2.0HDi
    sprawdź miernikiem napięcie na akumulatorze jak silnik pracuje bo może siada powoli alternator i nie doładowuje akumulatora a wtedy mogą być podobne problemy bo pompa absu potrzebuje "dużo" prądu.
    147 1.6 TS
    problem znikł odlaczylem i podlaczylem ponownie wtyczke na pompie abs
    Dla kolegi Nooe info z podłączenia:
    Alfa Romeo 147 1.9 JTD
    Bosch ABS 5.7 ASR/TC
    READING ERROR CODES:
    1: C1522 - ABS to instrument panel data line
    ERROR DETAILS:
    Vehicle speed: 2,750 km/h
    Brake light switch: ON
    There is one or more dialogue lines among the different systems that are installed on board: in this case the anomaly concerns the line or the lines between the ABS system and the instrument board.
    Possible causes can be related to a short circuit to the ground or to an anomaly in the instrument board.
    The fault is not detected now, but it is stored in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was activated for this fault.
    2: C1200 - Front right speed sensor, wiring error
    ERROR DETAILS:
    Brake light switch: OFF
    The speed signal of the indicated wheel is missing or wrong.
    Check:
    1) the wheel sensor and the associated wiring to the ABS ECU for opens, shorts and weak connections, and the ECU for proper ground.
    2) the sensor continuity and resistance
    3) the ECU ground connection
    4) the air gap between sensor and impulse ring
    5) the impulse ring and sensor to have no signs of damage or deformation, and to be free of magnetic dust
    6) the wheel bearing for excessive play
    NOTE:
    1) It is ESSENTIAL that all the rims and tires are of the same size, as specified by the manufacturer, and that the tires have correct pressure and show uniform wear
    2) using an Oscilloscope to check the signal gives an excellent visual reference of the signal integrity and enables easy comparison between the wheel sensors.
    3) this code may be set if a wheel is rotated independently when the car is lifted up and the Key is ON
    The reason for this fault is that ECU did not receive signal from the sensor. The fault is not detected now, but it is stored in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was activated for this fault.
    Ja już troszkę powiedziałem w czym szukać przyczyny. A z ciekawostki dodam auto na liczniku ~172 kkm a w kompie Odometer: 414642,4 km
    Nooe
    400 tys i bez wiekszych problemów, jutro będę miał troszkę czasu to przeczyszczę kabelki i powiem czy to pomogło.a błąd z poduszki usunięty i się juz nie pojawił
    Użytkownik Maniak resoraków Avatar Mati147
    Kielce
    Alfa romeo 147 1.6TS 120km 2001r
    odnawiam temat .
    panowie dziś sprawdzałem błędy ABSu i wyskoczył mi tylko ten Kliknij obrazek, aby uzyskać większą wersję
Nazwa:	DSC_0238.jpg
Rozmiar:	48.9 KB
    Spojrzałem też na kontrolki i wyskakiwało też to podczas odczytu błędów Kliknij obrazek, aby uzyskać większą wersję
Nazwa:	DSC_0239.jpg
Rozmiar:	50.0 KB
ID:	99535Kliknij obrazek, aby uzyskać większą wersję
Nazwa:	DSC_0240.jpg
Rozmiar:	56.2 KB
ID:	99536Kliknij obrazek, aby uzyskać większą wersję
Nazwa:	DSC_0241.jpg
Rozmiar:	57.6 KB
    Ale co najważniejsze błędu nie mogę skasować .
    ale podczas jazdy nie zapala mi się żadna kontrolka nawet nie mrugnie , abs działa poprawnie ,
    czemu błędu nie mogę usunąć ???
  1. ICS problem z radiem, problem z dzwiękiem - przerywa, pyka
    Utworzone przez deszczyk w dziale 166
    Odpowiedzi: 45
    Ostatni post / autor: 29-02-2016, 10:43
  2. Odpowiedzi: 21
    Ostatni post / autor: 21-02-2015, 10:52
  3. Odpowiedzi: 4
    Ostatni post / autor: 16-05-2014, 16:41
  4. Odpowiedzi: 2
    Ostatni post / autor: 11-04-2014, 16:03
  5. Odpowiedzi: 7
    Ostatni post / autor: 04-09-2012, 18:25
