Temat: Alfa Giulia- 2015
  1. #12921
    Giulia 2.0 Super / Giulietta QV
    U mnie też się tak sporadycznie zdarzało, tak ze 4 razy może (mam przejechane 4k km).
  2. #12922
    Cytat Napisał Nuakszot Zobacz post
    dość często jak na 4k km.... Termostat się zaczyna sypać? No bo jaki inny powód?
  3. #12923
    Termostat się nie sypie, bo ten wskaźnik pokazuje temperaturę oleju.
  4. #12924
    Użytkownik Maniak resoraków Avatar strzelec
    SD
    Alfa Romeo 156 2.4, Alfa Romeo 159 2.0 Mondeo Hybryd Vigniale
    To w takim razie silnik zaczyna się sypać, nie Anderson
  5. #12925
    Jaworze
    AR: 75 Busso/159 1,9Jtdm/ Fiat Coupe 2,0
    Tak Anderson "jak zwykle" ma rację fura się sypie jak nic
  6. #12926
    Użytkownik Maniak resoraków Avatar Garraty
    Giulia Veloce
    U mnie tez kilka razy nie tylko w Alfie Romeo, to jest calkiem normalne nie tylko w Alfie Romeo. Alfa tonie...
    http://www.giuliaforums.com/forum/46...r-heating.html
    Keep in mind this gauge in the Giulia is measuring oil temp, not coolant(water) temp. So the behaviour will be different. If you have a car with both gauges you can see that. Water temp is more easily regulated in most cars, and frankly most modern car water temp gauges lie to you anyway. BMW, for example, has rounded off the displayed water temp to the middle of the gauge for years. It doesn't mean the water/coolant is actually spot on the middle of the temp range all the time.
    I love that Alfa chose oil temp instead of water temp. It's a lot more useful in knowing exactly when your car is really warmed up. It's an unusual choice compared to every other car company, and a nice one, IMO.
    Dalej
    The oil is exposed to the inside engine temps, then cooled by the water jacket, which has a radiator in the loop. The coolant takes heat from the engine, so it seems normal that the oil would be hotter than the coolant.
    Dalej
    Oil temperature is probably the most important thing to know, specifically for those of us who are pushing our cars hard. Free reving (or worse - racing) on an engine that has not fully reached it's oil operating temperature is extremely dangerous. But don't think that the coolant gauge will tell you this information - it won't.
    As a general rule of thumb, after the car is warmed up, oil tends to be a few degrees warmer than the coolant (usually 10-15 degrees Fahrenheit)
    Optymalna temperatura oleju silnikowego kształtuje się na poziomie 90-130° C. Przy dynamicznej jeździe jego temperatura może jednak dojść nawet do 150° C. I mówimy tu o temperaturze mierzonej w misce olejowej. W samym silniku, zwłaszcza w górnej części tłoka (przy wkładce kompensacyjnej tłoka) jego temperatura potrafi dojść nawet do 260° C.
    Tak to jest pisac posty nie majac pojecia o czym sie mowi, termostat sie sie sypie ale czy w samochodzie?
    Ostatnio edytowane przez Garraty ; 19-05-2017 o 23:11
  7. #12927
    Rzeszów
    Zgadza się, z grubsza drugie tyle zajmuje olejowi dojść do temp pracy w porównaniu do wody.
    Szkoda, że w ts-ach i V-kacg nie bylo tych wskazań, razem z ciśnieniem oleju. Może nie byloby takiej zlej slawy Alfy Romeo.
    Oczywiście zakładając, ze kierowca wiedzialby jak te wskazania interpretować.
    Temp oleju w Giulii to fajna sprawa, taki motoryzacyjny smaczek w dobie izolowania kierowcy od tego co się w silniku dzieje.
    Choć niektóre marki dają tylko lampkę - za zimno, za gorąco, a mimo to silniki nie padają
  8. #12928
    Użytkownik Znawca Avatar azar
    Giulia Veloce, Giulietta 1.4
    Dzięki nie wiedziałem, że to jest temp oleju. W 159 było napisane Acqua. Tu mogli napisać oil
    Alfa tonie ...
    Własne: 147->146->156->159->159->Giulietta->Giulia Super->Giulia Veloce
    Jaram się, że jeździłem 147 GTA, 156 GTA, Brera Ti, 159 SW Ti, Mito Veloce, Giulietta Veloce, 4C
    Jaram się, że siedziałem: Prototyp 8C
  9. #12929
    Rzeszów
    Ale jest znaczek "konewki" ?
  10. #12930
    W Q jest oczywiście "konewka".
    https://i.wheelsage.org/pictures/a/a...foglio_82.jpeg
    W 2.2 D również.
Nazwa:	DSC_1089.jpg
Rozmiar:	22.9 KB
    Wskaźnik super sprawa – przy trasach autostradowych jest to niezły wskaźnik jakości zalanego oleju.
    Ostatnio edytowane przez jahu ; 20-05-2017 o 11:33
    Odpowiedzi: 53
    Odpowiedzi: 91
  3. Alfa Giulia w 2014?
    Odpowiedzi: 1818
  4. Alfa Giulia
  5. Alfa Romeo Giulia
