Strona 170 z 207 PierwszyPierwszy ... 70120160161162163164165166167168169170171172173174175176177178179180 ... OstatniOstatni
Pokaż wyniki od 1,691 do 1,700 z 2065
Temat: Fiatdiag, TS Diag, Alfadiag
  1. #1691
    Użytkownik Dwusuwowiec
    Police
    AR 156 1.9 JTD 2001 115KM cosmo blue
  2. #1692
    G 1.4 MA 170CV ECU Nexus 8GMF
    - to chyba tyle w temacie win 98 pl.
    Kod:
    A. The minimum recommended specification for the machine that AlfaDiag is to run on are as follows:
    # Processor*** 	550-megahertz (MHz) Intel Pentium-class processor or higher recommended.
    # Operating System 	Windows XP Professional.
    # Windows XP Home Edition.
    # Windows 2000 all versions.
    # Memory 	128 megabytes (MB) of RAM or higher MB recommended.
    # Hard disk 	Approx. 5 MB of hard disk space required for installation.
    # Display 	Minimum 800 x 600 or higher-resolution display with 256 colours.
    # Serial Device 	One free RS232 serial port. A USB to RS232 will not function correctly.
    # Other 	Install the latest Windows service packs and critical updates from the Windows Update site.
    # Install the latest version of the .NET Framework Version 2.0.
    - AR 156 TS 2.0 ecu M1.5.5
  3. #1693
    Artur
    Cytat Napisał murek Zobacz post
    http://allegro.pl/interfejs-fiat-alf...031436031.html
    ten kabel bedzie odpowiedni?
    Jeżeli polujesz na włoszkę, o jakże znamienitym numerze 156, to tak, ten będzie odpowiedni.
    Cytat Napisał bubu321 Zobacz post
    Też mi się tak wydaje
  4. #1694
    bargy
    Lightbulb Help needed!!!
    Hello everybody. Sorry I can only speak English & Greek, I need some help.
    I have an Alfa 147, I can't find a copy of alfadiag (latest version) and it's not easy to search the forum (I don't know the language)..
    Please PM me for info or a link
    Thanks in advance!
    By the way, is there any software that can reset the blinking milage (service schedule)?
    Is there any better program than Alfadiag for my car?
  5. #1695
    hi,
    - please specify which model you have AR 147, the TS and the JTD are other programs for diagnostics.
    - for the AR 147 TS is a good program Alfadiag and AlfaOBD.
    - here you have a direct link to the alfadiag
    1. http://www.4shared.com/file/13571379...31_online.html
    2. http://www.4shared.com/file/tZx79LCD/AD_Demo33011.html
    - and a brief instruction on how to run these programs
    NOTE: This program runs only under Windows XP !!!!!
    - In time to block the installation of anti-virus programs or run out of safe mode (F8 key at boot time.).
    1. program 3.1 unzip to directory example C:\alfadiag
    2. run from this directory alfadiag-loader.
    - alfadiag_loader if he does not start the program alfadiag follow steps A and B.
    A. - CTRL C and write code in notepad (CTRL V).
    B. - run from this directory alfadiag.exe, CTRL V or give written code.
    3. extract 3.3.0.11 file to a temporary directory.
    4. start installing 3.3.0.11 form the temporary directory, giving as a destination folder previous folder example C:\alfadiag.
    - sorry for my English but this is not my native language.
    Ostatnio edytowane przez bubu321 ; 04-02-2012 o 15:51
  6. #1696
    Użytkownik Świeżak Avatar mirage
    Olsztyn
    Alfa Romeo GT 1.9 JTD 2007r.
    Ja wiem, że to jest bardzo stary post kolegi arq ale miałem to samo z interfejsem i dzisiaj udało mi się połączyć i myślę że dla potomnych może się to przydać.
    Cytat Napisał arq Zobacz post
    Pomoże mi ktoś,próbuje połączyć moją alfę z alfadiagiem i oczywiście nie dochodzi do połączenia,robię test connection,i wywal mi ten jeden error w którym nie wiem o co chodzi
    UseUSB: True
    SerialPort: COM3 : Winachsf0
    KwpTiming:
    RequestInterByteTime: 5
    EcuResponseTimeout: 1500
    EcuResponseInterbyteTimeout: 100
    IsoTiming:
    EcuResponseInterbyteTimeout: 150
    Sending bytes: [ 55 AA 55 AA 55 AA 55 AA ]
    Received bytes:[ 55 AA 55 AA 55 AA 55 AA ]
    Expected Bytes: 1 Received Bytes: 1 Total wait time: 0 ms
    Expected Bytes: 1 Received Bytes: 0 Total wait time: 5007,2 ms
    Error:Serial Device Timeout Exception: ISO00: Timeout reading INIT byte [1] Timeout: 5000
    Test Complete
    O co chodzi w tym błędzie
    Prosze o pomoc
    Dziękuje
    Mi osobiście pomogły dwie rzeczy :
    1- mój interfejs był z przełącznikiem : poduszki - silnik - naklejka była odwrotnie przyklejona i wystarczyło przełącznik w drugą pozycję zmienić
    2- w ustawieniach portu szeregowego (win 7 ->system -> menedżer urządzeń->porty (com i lpt)-> <wybrany wirtualny port COM> ->ustawienia portu-> sterowanie przepływem -> sprzętowe
    Jakby nadal był problem to warto sprawdzić w zaawansowanych ustawieniach opóźnienia, ja mam ustawione na 1ms.
    I tak przy okazji, dzisiaj pierwszy raz połączyłem się z moją alfą i co ciekawe, podczas połączenia się z programem DnEcuDiag, wybierając ECU 2.10.4 program wyświetlił mi takie szczegóły (a w zasadzie ich nie wyświetlił, win7 32bit, netbook) :
    Poza tym, nie mogłem żadnych czujników sprawdzić, była tylko prędkość auta i jeszcze jakaś inna i w zasadzie nie wyglądało to na dobrze działający program
    Próbowałem FiatECUScan'em ale niestety wersja demo nie pozwala mi na sprawdzenie mojego auta tylko na jakąś tam symulację Czy mogę liczyć na Waszą pomoc? Jeśli tak to poproszę o PM'a Podczas gdy wyświetlił mi komunikat o wersji demo, w tym samym czasie na chwilę wyświetlił informacje o moim ecu i te były tam kompletne.
    Pozdrawiam!
    Ostatnio edytowane przez mirage ; 05-02-2012 o 21:06
    + kilka innych ;-)
  7. #1697
    Użytkownik Romeo Avatar euroscan
    Katy Wroclawskie/ Wrocław/ Legnica
    147 TS 1.6, bez wariatora
    oj na tym forum nie lubia jak ktoś daje także tło. a czemu nie alfaobd, jest przecież wersja 1.5 5 patrz.
Nazwa:	M2.10.jpg
Rozmiar:	41.5 KB
    Ostatnio edytowane przez euroscan ; 05-02-2012 o 20:25
  8. #1698
    Olsztyn
    Cytat Napisał euroscan Zobacz post
    Dziękuję za pomoc. Domyślam się, że nie lubią, też nie lubię, ale jak nie dało rady inaczej jak choćby przez wrzucenie załącznika ani obrazka w edytorze wiadomości (pod sam koniec wysyłania się zacinało) to przestawało to być już zabawne i zasoby mojej cierpliwości zaczynały dość drastycznie maleć. Spróbuję zaraz naprawić swój błąd. A ten alfaobd zadziała na ECU 2.10.4?
    + kilka innych ;-)
  9. #1699
    Bełchatów
    Cytat ze strony alfaobd:
    Bosch Motronic M2.10.4 Alfa 145/146/155/156/GTV/Spider
    Fiat Bravo(a)/Coupe/Marea
    Lancia K
    http://chomikuj.pl/danus77
  10. #1700
    - tylko to ma być wersja 1.5.5 Patrz. (patch).
  1. Dziwny odczyt alfa diag.
    Utworzone przez mario333 w dziale 166
    Ostatni post / autor: 16-07-2015, 08:42
  2. Diag w jeleniej
    Utworzone przez Azalgo w dziale Dolnośląskie
    Ostatni post / autor: 02-07-2015, 21:31
  3. v-scan multi diag działa z alfami?
    Utworzone przez tomkolp w dziale Forum ogólne o Alfa Romeo
    Ostatni post / autor: 13-10-2012, 16:12
  4. Test wtrysków w Alfa Diag?
    Utworzone przez Woland83 w dziale 156
    Ostatni post / autor: 23-04-2011, 15:55
  5. Problemy z podłączeniem ELM 327 usb diag...
    Ostatni post / autor: 11-03-2011, 07:40
