Pokaż wyniki od 21 do 23 z 23
Temat: listwa matrix, zmiana na inną
  1. #21
    PL
    http://picasaweb.google.com/Sidor211...eat=directlink
    http://img864.imageshack.us/g/20110407033.jpg/
    http://amaxlpg.pl/index.php?page=mai...cat=335&cp=353
    ---------- Post added at 18:55 ---------- Previous post was at 18:54 ----------
    Moje Matrixy po 25tyś km
    Plik ściągnięto 10 raz(y) 200,52 KB
    Sprężynki
    ---------- Post added at 18:56 ---------- Previous post was at 18:55 ----------
    Cleaning of Matrix injectors
    Disassembly:
    Screw out 4 pcs of imbus 2.5 mm. Take down part of body with nozzles.
    Screw out 2 pcs of imbus 2.5 mm. Attention, everythinfg can go to pieces ! Avoid loss of them.
    Assembly:
    At the first, put rubber reversible pad to the plastic part of body. Up to plastic pad put down brass pad. See pic. 1, 2.
    Up to these revesible pads put down metal lame with rubber sit [8x]. Attention, chamfer face up. See pic.3 [wrong is signed].
    Up to metal lames, put distance pad. See pic. 4
    Put in peripheral seal and put together with part of body with coils. Screw by 2 pcs of imbus 2.5mm. See pic. 5,6.
    Check all O-ring seals and put together with cover of Matrix. Screw by 4 pcs of imbus 2.5 mm. See pic.
    Matrix heating up:
    For better working Matrix injector in winter it ir recommended to warm it up by hot water cooling car system. See pic.
    Intervals for servis:
    Every 20 000 km – change gas filter [gaseous state] and part of hose behind the filter
    Every 20 000 km – cleaning Matrix injectors
    Every 20 000 km – change LPG filter in LPG valve
    Every 100 000 km – change memranes in reducer
    ---------- Post added at 18:57 ---------- Previous post was at 18:56 ----------
    To Ci powinno wystarczyć
    Kto chce szuka sposobu,
    kto nie chce szuka powodu.
    155 V6 LPG-163 KM-była
    156 V6 LPG-190 KM-była
  2. #22
    Użytkownik Znawca Avatar kudlaty_bytom
    Bytom
    Alfa Romeo Gtv 2.0 TS
    Cytat Napisał piotriix Zobacz post
    co 20 tyś km? ja zrobiłem od zakupu auta ponad 17 tyś, a co było wcześniej, to jeden diabeł wie
    pomysł z podgrzaniem listwy miałem podobny, ale się zastanawiam, czy to w ogóle robić i czy pozbywać się tego na lato, czy zostawić pod maską jest i tak potem gorąco
    dzięki za fotki i materiały edukacyjne
    wiesz może czy mogę zamienić moją hd344, a przynajmniej ze zdjęć w necie tak wywnioskowałem, na hd544? niby złącze takie samo, tylko 544 ma 8 cewek, a moja 'tylko' 4
    przy 544 chyba jest krótszy czas podania gazu, bo przez dwie dysze leci, dobrze myślę?
    Ostatnio edytowane przez kudlaty_bytom ; 14-12-2011 o 20:49
    verdebiancorosso
  3. #23
    Bytom
    no dobrze Panie i Panienki
    dzisiaj listwa poszła na stół i ją wyczyściłem
    cała operacja zajęła 40 minut i przyniosła spodziewane i rozweselające efekty
    przełącza się przy przegazówce na postoju, nie trzeba silnika kręcić na biegu, bo gasł wtedy i jakoś tak lepiej jedzie
    teraz muszę znaleźć czas, by podpiąć pod kompa i zrobić regulację
    dzięki wielkie piortiix za podpowiedzi
    Ostatnio edytowane przez kudlaty_bytom ; 27-12-2011 o 20:40
    verdebiancorosso
  1. [145] Wymiana Kierownicy na inną
    Utworzone przez SzybkiPL w dziale 145/146/155
    Ostatni post / autor: 31-08-2015, 12:08
  2. Listwa wtryskowa Matrix
    Utworzone przez qbazz w dziale LPG Zone
    Ostatni post / autor: 21-09-2011, 13:58
  3. matrix silnik dziala a kluczyk sobie wyjmuje...
    Utworzone przez moreeek w dziale 156
    Odpowiedzi: 17
    Ostatni post / autor: 02-05-2010, 23:23
  4. [166] rozmiar dysz Matrix
    Utworzone przez jac_eek w dziale LPG Zone
    Ostatni post / autor: 21-06-2009, 16:56
