- reset parametrów wg. instrukcji z forum Unidiaga, temat 60
Kod:
For the moment it is already possible to do some of the things
requested below with UniDiag. In the "Misc and Debug" tab, there is a
new option "In Out Ctrl LI 30". With the fixed Ctrl Param 0x04, it is
possible to reset some values depending on the Local ID that is choosen.
For Alfa with a M1.5.5 motronic the following local ID's are usually used:
0xFD : Reset idle actuator
0xFE : Reset self-adapt. param. and idle act.
iskierka w tunelu V-box, tego drugiego nie moge znależć, na razie testy na "sucho".
system xp sp2, system gościa xp sp2, linker to v-box.
Jak tak, to ciekawe czy wykrywa inne , Parallels, VirtualBox ...
