Show results from 1 to 10 with 20
Subject: [145] the Squeak when turning
29-01-2009, 07:30 #1
Hello
Some days it bothers me one thing in my Alfie. The fact is that when sawing at the wheel something is squeaking in the front. I will add that the squeak only occurs when the steering wheel left. When working right, has no squeaking. I don't think it is the pump, because when the maximum left position of the steering wheel there is no squeak.
Spotthe feces is already someone with something, what could it be?
› Więcej...: [145] the Squeak when turning
29-01-2009, 08:11 #2
You have damaged a wheel bearing or worn, the bearing seat in the hub. When you turn the car leans and the brake disc is stuck on this piece of the cover of the shield against the arrow, so the beeps. The cost of the to replace the bearing 60 rubles and, possibly, the hub 80 UAH.
29-01-2009, 08:33 #3
Maybe you're right, but I will add only that this squeak only occurs when cornering in the Parking lot and at slow drive. When driving fast or squeak, does not have or is not audible. ;//
29-01-2009, 11:24 #4
29-01-2009, 11:44 #5thingA guest
29-01-2009, 18:28 #6The user Stallion
- He joined the
- 08 2008
- Lives in
- Capital (not to be confused with the village of Warsaw)
- Auto
- 146,199,4 BOXER + LPG
- Posts
- 161
29-01-2009, 20:34 #7
29-01-2009, 21:09 #8An administrator. the moderators Quadrifoglio Verde
- He joined the
- 05 2006
- Lives in
- Warsaw, Poland
- Auto
- 155 V6 1996. r 155V6 1995 3.0 12V
- Posts
- 11,237
I also have the opinion that it is the fault of the belt or the power steering pump . In the Parking lot, but a colleague did not write, or with a hot engineiem
Wrote stara.plesn
Alfa Romeo 75 Turbo 1987
Alfa Romeo 75 Turbo America 1990
Alfa Romeo Giulietta 1.6 1983
Alfa Romeo 145 1.4 boxer, 1997
Alfa Romeo 155 V6 1996
Alfa Romeo 155 V6 1993 3.0 12V spacer to the 1.8 8v 1995
30-01-2009, 08:28 #9VIP Maniac resoraków
- He joined the
- 01 2007
- Lives in
- Ruda Slaska
- Auto
- Wigry 3/part no ar166 1,4 tdi
- Posts
- 822
buddy tries plesn read carefully the posts, I have what he's got momentum, and wedłog you in the Parking lot engine there is no momentum ...
Wrote czarek145
Andrew, a colleague psał that squeaks from him in the Parking lot, and how slow he was going .[IMG]
[/IMG]Probably chlyb with tustym
30-01-2009, 11:25 #10
Gentlemen,
To better describe the problem: beeping occurs when lit engine. When watching the video did not check, I have to do this!
Squeak, metal, like obcierały two metal surfaces. Rather exclude, the belt and the pump, because it's just "loud noise".
Yeah, I recently changed the levers front, maybe it has something to do?
Similar threads
Squeak when you add gas while driving at low speeds.
Created by kividuma in section 156Response: 2Last post/author: 16-02-2013, 20:51 -
[146] Knocking when turning
Created by discits in the section 145/146/155Response: 10Last post/author: 12-09-2011, 21:30 -
The hum when turning 156 JTD
Created by chwmar in section 156Response: 3Last post/author: 29-04-2011, 19:08 -
[145] Squeak-steering pump on full turn
Created by alfa145kubarado in the section 145/146/155Response: 18Last post/author: 27-08-2010, 15:07 -
[145] it is strange, at max turn
Created by Pingwin in the section 145/146/155Response: 6Last post/author: 30-09-2008, 09:15
