Show results from 1 to 9 with 9
    The user Beginner Avatar misiek_tarnow
    He joined the
    06 2015
    Lives in
    Tarnów
    Alfa Romeo 147 1.6 ts 120 km
    Posts
    206
    Domyślnie The Central key has stopped working
    Hello, I have a problem yesterday it stopped working with the Central key, the trunk also does not open Central after wlozeniu grotto and przekreceniu works in the car as it was, I don't have cards, keys, codes and only one key, someone can help? What is the cost and where I can do it, I changed the batteries and nothing
    › Więcej...: The Central key has stopped working
    The user Maniac resoraków Avatar Koks
    He joined the
    09 2010
    Lives in
    boars
    AR 147 1910 JTD CF3 8V 115KM/85 KW (DISTINCTIVE)
    Posts
    626
    Could the decryption key. But without the code card lime. Or RAID ASOor some MAG elektronik that can pull the code from the ECU.
    Sent from my SM-G903F using Tapatalk
    The user Fachowiec Avatar maly_777
    He joined the
    08 2009
    Lives in
    Warsaw, Poland
    AR 156 FL SW 1.9 16V
    Posts
    2,525
    Classic.
    V. search electronics or ASO.
    KODOWANIE KLUCZY (Giulia Stelvio 159 inne)
    Konwersje HaveSAND->EU
    UPDATE MAP DO NAJNOWSZYCH 2023 (1,2,3 generacja), również z rynków USA
    KODOWANIE (używanych) RADARÓW ACC/DASM, BLISSów, zmiana radia i aktywacja AA/CP offline
    He joined the
    06 2015
    Lives in
    Tarnów
    Posts
    206
    and someone from the forum had this problem? I read that the cost of the the registration code is OK 200 rubles in ASO a coding key that rozkodował??
    He joined the
    08 2009
    Lives in
    Warsaw, Poland
    Posts
    2,525
    Non-stop someone has such a problem, the 147/GT.
    You can try the car electronics. Can also extract the PIN from the car.
    He joined the
    06 2015
    Lives in
    Tarnów
    Posts
    206
    260 map, keys, codes, kraków, tarnów - ASO they are sick, the encoding key 160-200 rubles., it's paranoia
    The user Maniac resoraków Avatar esco1982
    He joined the
    12 2014
    Lives in
    Olsztyn
    AR 166 3.0 V6 99r.,Fiat Tipo 1.4 T JET 2017
    Posts
    759
    Quotation Wrote misiek_tarnow Zobacz post
    Code card you need to have but it encoding is a trivial thing, so it is better to spend 100 zloty on the wire (which will come in handy for, e.g., diagnosis), than to give 200 PLN in ASO because the programming.
    AR 146 1.4 BOXER, AR 147TI 1.6 TS, AR 166 3.0 V6
    He joined the
    06 2015
    Lives in
    Tarnów
    Posts
    206
    Well on the forum and found Enigma Krakow - I called and sit in the car, 110 HP, I - 300 RUB for the code, encode the key and make a new key, I recommend mega, quickly and professionally
    The user I'm New -do not cry!
    He joined the
    05 2016
    looking for gt/ 147
    Posts
    4
    I had the same case. I went from one specialist to the next, all put out hands and advised to earn a key. Pushed so that the key is on part of the. The problem was simple lack of contact of the chip with a battery.
Similar threads
  1. Central with remote control stopped working and
    Created by drafter in section 147
    Response: 6
    Last post/author: 18-05-2016, 17:06
  2. After replacing the battery the FOB has stopped working
    Created by michal1903 in section 147
    Response: 7
    Last post/author: 27-10-2014, 18:49
  3. The fuel gauge
    Created by regedit89 in section 156
    Response: 6
    Last post/author: 28-12-2012, 22:40
  4. Response: 13
    Last post/author: 29-08-2012, 19:36
  5. [146] Central with a key?
    Created by SiGi in the section 145/146/155
    Response: 10
    Last post/author: 02-08-2010, 14:05
alfa rpmeo 147 tarnow kluczyk
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
