Strona 10 z 27 PierwszyPierwszy 1234567891011121314151617181920 ... OstatniOstatni
Pokaż wyniki od 91 do 100 z 266
Temat: OBD II - Kody błędów
  1. #91
    Użytkownik Znawca Avatar Dawid_Zielu
    Alfa Romeo 166 FL 2,4 JTD 20V Sportronic '03
    C1768 Air Suspension Rear Height Sensor Low Signal Circuit Short To Ground
    C1770 Air Suspension Vent Solenoid Output Circuit Failure
    C1771 Air Suspension Vent Solenoid Output Circuit Open
    C1772 Air Suspension Vent Solenoid Output Circuit Short To Battery
    C1773 Air Suspension Vent Solenoid Output Circuit Short To Ground
    C1774 Coolant Temp. Out of Range
    C1775 DC-DC Converter Failure
    C1776 Heater System Failure
    C1777 Vacuum Pressure Circuit Failure
    C1778 Power Steering Failure
    C1779 Blower Switch Failure
    C1780 Temperature Select Failure
    C1781 Engine Coolant Temperature Signal Missing/Fault
    C1790 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Failure
    C1791 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Open
    C1792 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Battery
    C1793 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Ground
    C1795 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Failure
    C1796 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Open
    C1797 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Battery
    C1798 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Ground
    C1800 Air Suspension Reservoir Solenoid Circuit Failure
    C1805 Mismatched PCM and/or ABS-TC Module
    C1813 Air Suspension LR Vent Request Exceeded Max. Timing
    C1814 Air Suspension RR Vent Request Exceeded Max. Timing
    C1818 Air Suspension LR Air Compress Request Exceeded Max. Timing
    C1819 Air Suspension RR Air Compress Request Exceeded Max. Timing
    C1820 Air Suspension RF Air Compress Request Exceeded Max. Timing
    C1830 Air Suspension Compressor Relay Circuit Failure
    C1831 Air Suspension Compressor Relay Circuit Open
    C1832 Air Suspension Compressor Relay Circuit Short To Battery
    C1833 Air Suspension Compressor Relay Circuit Short To Ground
    C1834 Gauge Drive Current Fault
    C1835 Current Sense Circuit Failure
    C1836 Battery Temp. Out of Range
    C1837 Battery Heater Circuit Failure
    C1838 Charging System Fault
    C1839 Leakage Fault
    C1840 Air Suspension Disable Switch Circuit Failure
    C1841 Air Suspension Disable Switch Circuit Open
    C1842 Air Suspension Disable Switch Circuit Short To Battery
    C1843 Air Suspension Disable Switch Circuit Short To Ground
    C1844 Air Suspension Secondary Front Inflator Solenoid Output Circuit Failure
    C1845 Air Suspension Front Inflator Solenoid Output Circuit Failure
    C1846 Air Suspension Front Inflator Solenoid Output Circuit Open
    C1847 Air Suspension Front Inflator Solenoid Output Circuit Short To Battery
    C1848 Air Suspension Front Inflator Solenoid Output Circuit Short To Ground
    C1849 Master Cylinder Pressure Out of Range
    C1850 Air Suspension Warning Lamp Circuit Failure
    C1851 Air Suspension Warning Lamp Circuit Open
    C1852 Air Suspension Warning Lamp Circuit Short To Battery
    C1853 Air Suspension Warning Lamp Circuit Short To Ground
    C1854 Motor Temperature Out of Range
    C1855 Acceleration Position Sensor Conflict
    C1856 Traction Motor Encoder circuit Failure
    C1859 PRNDL Input #2 Circuit Failure
    C1860 PRNDL Input #3 Circuit Failure
    C1861 PRNDL Input #4 Circuit Failure
    C1862 Contactor Circuit Failure
    C1863 External Charging Fault
    C1864 Battery Module Fault
    C1865 Air Suspension Rear Inflator Solenoid Output Circuit Failure
    C1866 Air Suspension Rear Inflator Solenoid Output Circuit Open
    C1867 Air Suspension Rear Inflator Solenoid Output Circuit Short To Battery
    C1868 Air Suspension Rear Inflator Solenoid Output Circuit Short To Ground
    C1869 Air Suspension Gate Solenoid Output Circuit Failure
    C1870 Air Suspension Gate Solenoid Output Circuit Open
    C1871 Air Suspension Gate Solenoid Output Circuit Short To Battery
    C1872 Air Suspension Gate Solenoid Output Circuit Short To Ground
    C1873 Air Suspension RF Air Spring Solenoid Output Circuit Failure
    C1874 Air Suspension RF Air Spring Solenoid Output Circuit Open
    C1875 Air Suspension RF Air Spring Solenoid Output Circuit Short To Battery
    C1876 Air Suspension RF Air Spring Solenoid Output Circuit Short To Ground
    C1877 Air Suspension LF Air Spring Solenoid Output Circuit Failure
    C1878 Air Suspension LF Air Spring Solenoid Output Circuit Open
    C1879 Air Suspension LF Air Spring Solenoid Output Circuit Short To Battery
    C1880 Air Suspension LF Air Spring Solenoid Output Circuit Short To Ground
    C1881 Air Suspension RF Height Sensor Circuit Failure
    C1882 Air Suspension RF Height Sensor Circuit Open
    C1883 Air Suspension RF Height Sensor Circuit Short To Battery
    C1884 Air Suspension RF Height Sensor Circuit Short To Ground
    C1885 Air Suspension RR Height Sensor Circuit Failure
    C1886 Air Suspension RR Height Sensor Circuit Open
    C1887 Air Suspension RR Height Sensor Circuit Short To Battery
    C1888 Air Suspension RR Height Sensor Circuit Short To Ground
    C1889 Air Suspension LF Height Sensor Circuit Failure
    C1890 Air Suspension LF Height Sensor Circuit Open
    C1891 Air Suspension LF Height Sensor Circuit Short To Battery
    C1892 Air Suspension LF Height Sensor Circuit Short To Ground
    C1893 Air Suspension LR Height Sensor Circuit Failure
    C1894 Air Suspension LR Height Sensor Circuit Open
    C1895 Air Suspension LR Height Sensor Circuit Short To Battery
    C1896 Air Suspension LR Height Sensor Circuit Short To Ground
    C1897 Steering VAPS II Circuit Loop Failure
    C1898 Steering VAPS II Circuit Loop Open
    C1899 Steering VAPS II Circuit Loop Short To Battery
    C1900 Steering VAPS II Circuit Loop Short To Ground
    C1901 Ride Control RR Shock Actuator Circuit Failure
    C1902 Ride Control RR Shock Actuator Circuit Open
    C1903 Ride Control RR Shock Actuator Circuit Short To Battery
    C1904 Ride Control RR Shock Actuator Circuit Short To Ground
    C1905 Ride Control LR Shock Actuator Circuit Failure
    C1906 Ride Control LR Shock Actuator Circuit Open
    C1907 Ride Control LR Shock Actuator Circuit Short To Battery
    C1908 Ride Control LR Shock Actuator Circuit Short To Ground
    C1909 Ride Control RF Shock Actuator Circuit Failure
    C1910 Ride Control RF Shock Actuator Circuit Open
    C1911 Ride Control RF Shock Actuator Circuit Short To Battery
    C1912 Ride Control RF Shock Actuator Circuit Short To Ground
    C1913 Ride Control LF Shock Actuator Circuit Failure
    C1914 Ride Control LF Shock Actuator Circuit Open
    C1915 Ride Control LF Shock Actuator Circuit Short To Battery
    C1916 Ride Control LF Shock Actuator Circuit Short To Ground
    C1917 Steering EVO Out-of-Range Fault
    C1918 Air Suspension Ride Height Select Switch Circuit Failure
    C1920 Led #1 Circuit Failure
    C1921 VAPS Solenoid Actuator Output Circuit Failure
    C1922 VAPS Solenoid Actuator Output Circuit Open
    C1923 VAPS Solenoid Actuator Output Circuit Short To Battery
    C1924 VAPS Solenoid Actuator Output Circuit Short To Ground
    C1925 VAPS Solenoid Actuator Return Circuit Failure
    C1926 VAPS Solenoid Actuator Return Circuit Open
    C1927 VAPS Solenoid Actuator Return Circuit Short To Battery
    C1928 VAPS Solenoid Actuator Return Circuit Short To Ground
    C1929 Air Suspension Front Compressor Relay Circuit Failure
    C1930 Air Suspension Front Compressor Relay Circuit Open
    C1931 Air Suspension Front Compressor Relay Circuit Short To Battery
    C1932 Air Suspension Front Compressor Relay Circuit Short To Ground
    C1933 Solenoid Current Out Of Range
    C1934 HPU (Hydraulic Pump Unit) Pressurisation Failure
    C1935 Chime Circuit Failure
    C1936 Hydraulic Pump Relay Circuit Failure
    C1937 Steering Wheel Angle Sensor Offset Failure
    C1938 Invalid Steering Wheel Angle Sensor ID
    C1939 Brake Pressure Switch Input Circuit Failure
    C1940 Brake Pressure Switch Mechanical Failure
    C1942 Unrecognized Powertrain Configuration
    C1943 Airbag Deployment Indication Input Fault
    C1944 Gauge Driver Circuit Fault
    C1945 Park Switch Indicates Park with Vehicle Moving
    C1946 Seat Track Position Switch Circuit Open
    C1947 Seat Track Position Switch Circuit Short to Ground
    C1948 Seat Track Position Switch Circuit Resistance Out of Range
    C1949 Accelerometer Sensor Circuit Open
    C1950 Accelerometer Sensor Circuit Failure
    C1951 Lateral Accelerometer Sensor Circuit Open
    C1952 Yaw Rate Sensor Circuit Open
    C1953 Master Cylinder Pressure Sensor Circuit Open
    C1954 Master Cylinder Pressure Sensor Circuit Failure
    C1955 Steering Angle Sensor Circuit Open
    C1956 Steering Angle Sensor Circuit Failure
    C1957 Dynamic Stability Control Valve RF Circuit Failure
    C1958 Dynamic Stability Control Valve LF Circuit Failure
    C1959 Lateral Accelerometer Sensor Circuit Failure
    C1960 Driver Brake Apply Circuit Fault
    C1961 Park Lamp Relay Coil Circuit Failure
    C1962 Park Lamp Relay Coil Short to Battery
    C1963 Stability Control Inhibit Warning
    C2767 Reserved - TBD
    B1200 Climate Control Pushbutton Circuit Failure
    B1201 Fuel Sender Circuit Failure
    B1202 Fuel Sender Circuit Open
    B1203 Fuel Sender Circuit Short To Battery
    B1204 Fuel Sender Circuit Short To Ground
    B1205 EIC Switch-1 Assembly Circuit Failure
    B1206 EIC Switch-1 Assembly Circuit Open
    B1207 EIC Switch-1 Assembly Circuit Short To Battery
    B1208 EIC Switch-1 Assembly Circuit Short To Ground
    B1209 EIC Switch-2 Assembly Circuit Failure
    B1210 EIC Switch-2 Assembly Circuit Open
    B1211 EIC Switch-2 Assembly Circuit Short To Battery
    B1212 EIC Switch-2 Assembly Circuit Short To Ground
    B1213 Anti-Theft Number of Programmed Keys Is Below Minimum
    B1214 Running Board Lamp Circuit Failure
    B1215 Running Board Lamp Circuit Short to Battery
    B1216 Emergency & Road Side Assistance Switch Circuit Short to Ground
    B1217 Horn Relay Coil Circuit Failure
    B1218 Horn Relay Coil Circuit Short to Vbatt
    B1219 Fuel Tank Pressure Sensor Circuit Failure
    B1220 Fuel Tank Pressure Sensor Circuit Open
    B1222 Fuel Temperature Sensor #1 Circuit Failure
    B1223 Fuel Temperature Sensor #1 Circuit Open
    B1224 Fuel Temperature Sensor #1 Circuit Short to Battery
    B1225 Fuel Temperature Sensor #1 Circuit Short to Ground
    B1226 Fuel Temperature Sensor #2 Circuit Failure
    B1227 Fuel Temperature Sensor #2 Circuit Open
    B1228 Fuel Temperature Sensor #2 Circuit Short to Battery
    B1229 Fuel Temperature Sensor #2 Circuit Short to Ground
    B1231 Longitudinal Acceleration Threshold Exceeded
    B1232 DO NOT USE (See Shop Manual for Description)
    B1233 Glass Break Sensor Failure
    B1234 Mirror Switch Invalid Code
    B1235 Window Feedback Failure
    B1236 Window Feedback Loss of Signal
    B1237 Window Feedback Out of Range
    B1238 Over Temperature Fault
    B1239 Air Flow Blend Door Driver Circuit Failure
    B1240 Wiper Washer Rear Pump Relay Circuit Failure
    B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery
    B1242 Air Flow Recirculation Door Driver Circuit Failure
    B1243 Express Window Down Switch Circuit Short to Battery
    B1244 Wiper Rear Motor Run Relay Circuit Failure
    B1245 Wiper Rear Motor Run Relay Circuit Short to Battery
    B1246 Dim Panel Potentiometer Switch Circuit Failure
    B1247 Panel Dim Switch Circuit Open
    B1248 Passenger's Seatback Autoglide Rearward Switch Circuit Short to Ground
    B1249 Blend Door Failure
    B1250 Air Temperature Internal Sensor Circuit Failure
    B1251 Air Temperature Internal Sensor Circuit Open
    B1252 Air Temperature Internal Sensor Circuit Short To Battery
    B1253 Air Temperature Internal Sensor Circuit Short To Ground
    B1254 Air Temperature External Sensor Circuit Failure
    B1255 Air Temperature External Sensor Circuit Open
    B1256 Air Temperature External Sensor Circuit Short To Battery
    B1257 Air Temperature External Sensor Circuit Short To Ground
    B1258 Solar Radiation Sensor Circuit Failure
    B1259 Solar Radiation Sensor Circuit Open
    B1260 Solar Radiation Sensor Circuit Short To Battery
    B1261 Solar Radiation Sensor Circuit Short To Ground
    B1262 Servo Motor Defrost Circuit Failure
    B1263 Servo Motor Vent Circuit Failure
    B1264 Servo Motor Foot Circuit Failure
    B1265 Servo Motor Coolair Bypass Circuit Failure
    B1266 Servo Motor Airintake Left Circuit Failure
    B1267 Servo Motor Airintake Right Circuit Failure
    B1268 Servo Motor Potentiometer Defrost Circuit Failure
    B1269 Servo Motor Potentiometer Defrost Circuit Open
    B1270 Servo Motor Potentiometer Defrost Circuit Short To Battery
    B1271 Servo Motor Potentiometer Defrost Circuit Short To Ground
    B1272 Servo Motor Potentiometer Vent Circuit Failure
    B1273 Servo Motor Potentiometer Vent Circuit Open
    B1274 Servo Motor Potentiometer Vent Circuit Short To Battery
    B1275 Servo Motor Potentiometer Vent Circuit Short To Ground
    B1276 Servo Motor Potentiometer Foot Circuit Failure
    B1277 Servo Motor Potentiometer Foot Circuit Open
    B1278 Servo Motor Potentiometer Foot Circuit Short To Battery
    B1279 Servo Motor Potentiometer Foot Circuit Short To Ground
    B1280 Servo Motor Potentiometer Coolair Circuit Failure
    B1281 Servo Motor Potentiometer Coolair Circuit Open
    B1282 Servo Motor Potentiometer Coolair Circuit Short To Battery
    B1283 Servo Motor Potentiometer Coolair Circuit Short To Ground
    B1284 Servo Motor Potentiometer Airintake Left Circuit Failure
    B1285 Servo Motor Potentiometer Airintake Left Circuit Open
    B1286 Servo Motor Potentiometer Airintake Left Circuit Short To Battery
    B1287 Servo Motor Potentiometer Airintake Left Circuit Short To Ground
    B1288 Servo Motor Potentiometer Airintake Right Circuit Failure
    B1289 Servo Motor Potentiometer Airintake Right Circuit Open
    B1290 Servo Motor Potentiometer Airintake Right Circuit Short To Battery
    B1291 Servo Motor Potentiometer Airintake Right Circuit Short To Ground
    B1292 Battery Power Relay Circuit Failure
    B1293 Battery Power Relay Circuit Open
    B1294 Battery Power Relay Circuit Short To Battery
    B1295 Battery Power Relay Circuit Short To Ground
    B1296 Power Supply Sensor Circuit Failure
    B1297 Power Supply Sensor Circuit Open
    B1298 Power Supply Sensor Circuit Short To Battery
    B1299 Power Supply Sensor Circuit Short To Ground
    B1300 Power Door Lock Circuit Failure
    B1301 Power Door Lock Circuit Open
    B1302 Accessory Delay Relay Coil Circuit Failure
    B1303 Accessory Delay Relay Coil Circuit Open
    B1304 Accessory Delay Relay Coil Circuit Short To Battery
    B1305 Accessory Delay Relay Coil Circuit Short To Ground
    B1306 Oil Level Switch Circuit Open
    B1307 Oil Level Switch Circuit Short To Battery
    B1308 Oil Level Switch Circuit Short To Ground
    B1309 Power Door Lock Circuit Short To Ground
    B1310 Power Door Unlock Circuit Failure
    B1311 Power Door Unlock Circuit Open
    B1312 Lamp Headlamp Input Circuit Short To Battery
    B1313 Battery Saver Relay Coil Circuit Failure
    B1314 Battery Saver Relay Coil Circuit Open
    B1315 Battery Saver Relay Coil Circuit Short To Battery
    B1316 Battery Saver Relay Coil Circuit Short To Ground
    B1317 Battery Voltage High
    B1318 Battery Voltage Low
    B1319 Driver Door Ajar Circuit Failure
    B1320 Driver Door Ajar Circuit Open
    B1321 Driver Door Ajar Circuit Short To Battery
    B1322 Driver Door Ajar Circuit Short To Ground
    B1323 Door Ajar Lamp Circuit Failure
    B1324 Door Ajar Lamp Circuit Open
    B1325 Door Ajar Lamp Circuit Short To Battery
    B1326 Door Ajar Lamp Circuit Short To Ground
    B1327 Passenger Door Ajar Circuit Failure
    B1328 Passenger Door Ajar Circuit Open
    B1329 Passenger Door Ajar Circuit Short To Battery
    B1330 Passenger Door Ajar Circuit Short To Ground
    B1331 Decklid Ajar Rear Door Circuit Failure
    B1332 Decklid Ajar Rear Door Circuit Open
    B1333 Decklid Ajar Rear Door Circuit Short To Battery
    B1334 Decklid Ajar Rear Door Circuit Short To Ground
    B1335 Door Ajar RR Circuit Failure
    B1336 Door Ajar RR Circuit Open
    B1337 Door Ajar RR Circuit Short To Battery
    B1338 Door Ajar RR Circuit Short To Ground
    B1339 Chime Input Request Circuit Short To Battery
    B1340 Chime Input Request Circuit Short To Ground
    B1341 Power Door Unlock Circuit Short To Ground
    B1342 ECU Is Defective
    B1343 Heated Backlite Input Circuit Failure
    B1344 Heated Backlite Input Circuit Open
    B1345 Heated Backlite Input Circuit Short To Ground
    B1346 Heated Backlite Input Circuit Short To Battery
    B1347 Heated Backlite Relay Circuit Failure
    B1348 Heated Backlite Relay Circuit Open
    B1349 Heated Backlite Relay Short To Battery
    B1350 Heated Backlite Relay Short To Ground
    B1351 Ignition Key-In Circuit Short To Battery
    B1352 Ignition Key-In Circuit Failure
    B1353 Ignition Key-In Circuit Open
    B1354 Ignition Key-In Circuit Short To Ground
    B1355 Ignition Run Circuit Failure
    B1356 Ignition Run Circuit Open
    B1357 Ignition Run Circuit Short To Battery
    B1358 Ignition Run Circuit Short To Ground
    B1359 Ignition Run/Acc Circuit Failure
    B1360 Ignition Run/Acc Circuit Open
    B1361 Ignition Run/Acc Circuit Short To Battery
    B1362 Ignition Run/Acc Circuit Short To Ground
    B1363 Ignition Start Circuit Failure
    B1364 Ignition Start Circuit Open
    B1365 Ignition Start Circuit Short To Battery
    B1366 Ignition Start Circuit Short To Ground
    B1367 Ignition Tach Circuit Failure
    B1368 Ignition Tach Circuit Open
    B1369 Ignition Tach Circuit Short To Battery
    B1370 Ignition Tach Circuit Short To Ground
    B1371 Illuminated Entry Relay Circuit Failure
    B1372 Illuminated Entry Relay Circuit Open
    B1373 Illuminated Entry Relay Short To Battery
    B1374 Illuminated Entry Relay Short To Ground
    B1375 Oil Change Lamp Circuit Open
    B1376 Oil Change Lamp Circuit Short To Battery
    B1377 Oil Change Lamp Circuit Failure
    B1378 Oil Change Lamp Circuit Short To Ground
    B1379 Oil Change Reset Button Circuit Short To Ground
    B1380 Oil Change Reset Button Circuit Failure
    B1381 Oil Change Reset Button Circuit Open
    B1382 Oil Change Reset Button Circuit Short To Battery
    B1383 Oil Level Lamp Circuit Short To Battery
    B1384 Oil Level Lamp Circuit Failure
    B1385 Oil Level Lamp Circuit Open
    B1386 Oil Level Lamp Circuit Short To Ground
    B1387 Oil Temperature Sensor Circuit Open
    B1388 Oil Temperature Sensor Circuit Short To Battery
    B1389 Oil Temperature Sensor Circuit Failure
    B1390 Oil Temperature Sensor Circuit Short To Ground
    B1391 Oil Level Switch Circuit Failure
    B1392 Power Door Memory Lock Relay Circuit Failure
    B1393 Power Door Memory Lock Relay Circuit Open
    B1394 Power Door Memory Lock Relay Circuit Short To Battery
    B1395 Power Door Memory Lock Relay Circuit Short To Ground
    B1396 Power Door Lock Circuit Short To Battery
    cdn.
    Alfa Romeo - "bez serca bylibyśmy jedynie maszynami"
  2. #92
    B1397 Power Door Unlock Circuit Short To Battery
    B1398 Driver Power Window One Touch Window Relay Circuit Failure
    B1399 Driver Power Window One Touch Window Relay Circuit Open
    B1400 Driver Power Window One Touch Window Relay Circuit Short To Battery
    B1401 Driver Power Window One Touch Window Relay Circuit Short To Ground
    B1402 Driver Power Window Down Switch Circuit Failure
    B1403 Driver Power Window Up Switch Circuit Failure
    B1404 Driver Power Window Down Circuit Open
    B1405 Driver Power Window Down Circuit Short To Battery
    B1406 Driver Power Window Down Circuit Short To Ground
    B1407 Driver Power Window Up Circuit Open
    B1408 Driver Power Window Up Circuit Short To Battery
    B1409 Driver Power Window Up Circuit Short To Ground
    B1410 Driver Power Window Motor Circuit Failure
    B1411 Driver Power Window Motor Circuit Open
    B1412 Driver Power Window Motor Circuit Short To Battery
    B1413 Driver Power Window Motor Circuit Short To Ground
    B1414 Power Window LR Motor Circuit Failure
    B1415 Power Window LR Motor Circuit Open
    B1416 Power Window LR Motor Circuit Short To Battery
    B1417 Power Window LR Motor Circuit Short To Ground
    B1418 Passenger Power Window Motor Circuit Failure
    B1419 Passenger Power Window Motor Circuit Open
    B1420 Passenger Power Window Motor Circuit Short To Battery
    B1421 Passenger Power Window Motor Circuit Short To Ground
    B1422 Power Window RR Motor Circuit Failure
    B1423 Power Window RR Motor Circuit Open
    B1424 Power Window RR Motor Circuit Short To Battery
    B1425 Power Window RR Motor Circuit Short To Ground
    B1426 Lamp Seat Belt Circuit Short To Battery
    B1427 Lamp Seat Belt Circuit Open
    B1428 Lamp Seat Belt Circuit Failure
    B1429 Lamp Seat Belt Circuit Short To Ground
    B1430 Seat Belt Switch Circuit Short To Ground
    B1431 Wiper Brake/Run Relay Circuit Failure
    B1432 Wiper Brake/Run Relay Circuit Short To Battery
    B1433 Wiper Brake/Run Relay Circuit Short To Ground
    B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure
    B1435 Wiper Hi/Low Speed Relay Coil Circuit Open
    B1436 Wiper Hi/Low Speed Relay Coil Circuit Short To Battery
    B1437 Wiper Hi/Low Speed Relay Coil Circuit Short To Ground
    B1438 Wiper Mode Select Switch Circuit Failure
    B1439 Wiper Mode Select Switch Circuit Open
    B1440 Wiper Mode Select Switch Circuit Short To Battery
    B1441 Wiper Mode Select Switch Circuit Short To Ground
    B1442 Door Handle Switch Circuit Failure
    B1443 Door Handle Switch Circuit Open
    B1444 Door Handle Switch Circuit Short To Battery
    B1445 Door Handle Switch Circuit Short To Ground
    B1446 Wiper Park Sense Circuit Failure
    B1447 Wiper Park Sense Circuit Open
    B1448 Wiper Park Sense Circuit Short To Battery
    B1449 Wiper Park Sense Circuit Short To Ground
    B1450 Wiper Wash/Delay Switch Circuit Failure
    B1451 Wiper Wash/Delay Switch Circuit Open
    B1452 Wiper Wash/Delay Switch Circuit Short To Battery
    B1453 Wiper Wash/Delay Switch Circuit Short To Ground
    B1454 Wiper Washer Fluid Lamp Circuit Failure
    B1455 Wiper Washer Fluid Lamp Circuit Open
    B1456 Wiper Washer Fluid Lamp Circuit Short To Battery
    B1457 Wiper Washer Fluid Lamp Circuit Short To Ground
    B1458 Wiper Washer Pump Motor Relay Circuit Failure
    B1459 Wiper Washer Pump Motor Relay Coil Circuit Open
    B1460 Wiper Washer Pump Motor Relay Coil Circuit Short To Battery
    B1461 Wiper Washer Pump Motor Relay Coil Circuit Short To Ground
    B1462 Seat Belt Switch Circuit Failure
    B1463 Seat Belt Switch Circuit Open
    B1464 Seat Belt Switch Circuit Short To Battery
    B1465 Wiper Brake/Run Relay Circuit Open
    B1466 Wiper Hi/Low Speed Not Switching
    B1467 Wiper Hi/Low Speed Circuit Motor Short To Battery
    B1468 Chime Input Request Circuit Failure
    B1469 Chime Input Request Circuit Open
    B1470 Lamp Headlamp Input Circuit Failure
    B1471 Lamp Headlamp Input Circuit Open
    B1472 Lamp Headlamp Input Circuit Short To Ground
    B1473 Wiper Low Speed Circuit Motor Failure
    B1474 Battery Saver Power Relay Circuit Short To Battery
    B1475 Accessory Delay Relay Contact Short To Battery
    B1476 Wiper High Speed Circuit Motor Failure
    B1477 Wiper Hi/Low Circuit Motor Short To Ground
    B1478 Power Window One Touch Up/Down Activated Simultaneously
    B1479 Wiper Washer Fluid Level Sensor Circuit Failure
    B1480 Wiper Washer Fluid Level Sensor Circuit Open
    B1481 Wiper Washer Fluid Level Sensor Circuit Short To Battery
    B1482 Wiper Washer Fluid Level Sensor Circuit Short To Ground
    B1483 Brake Pedal Input Circuit Failure
    B1484 Brake Pedal Input Open Circuit
    B1485 Brake Pedal Input Circuit Battery Short
    B1486 Brake Pedal Input Circuit Ground Short
    B1487 Door Handle Right Front Circuit Failure
    B1488 Door Handle Right Front Circuit Open
    B1489 Door Handle Right Front Short To Battery
    B1490 Door Handle Right Front Short To Ground
    B1491 Ignition Cylinder Sensor Circuit Failure
    B1492 Ignition Cylinder Sensor Open Circuit
    B1493 Ignition Cylinder Sensor Battery Short
    B1494 Ignition Cylinder Sensor Ground Short
    B1495 Decklid Punch-Out Sensor Circuit Failure
    B1496 Decklid Punch-Out Sensor Open Circuit
    B1497 Decklid Punch-Out Sensor Battery Short
    B1498 Decklid Punch-Out Sensor Ground Short
    B1499 Lamp Turn Signal Left Circuit Failure
    B1500 Lamp Turn Signal Left Circuit Open
    B1501 Lamp Turn Signal Left Circuit Short To Battery
    B1502 Lamp Turn Signal Left Circuit Short To Ground
    B1503 Lamp Turn Signal Right Circuit Failure
    B1504 Lamp Turn Signal Right Circuit Open
    B1505 Lamp Turn Signal Right Circuit Short To Battery
    B1506 Lamp Turn Signal Right Circuit Short To Ground
    B1507 Flash To Pass Switch Circuit Failure
    B1508 Flash To Pass Switch Circuit Open
    B1509 Flash To Pass Switch Circuit Short To Battery
    B1510 Flash To Pass Switch Circuit Short To Ground
    B1511 Driver Door Handle Circuit Failure
    B1512 Driver Door Handle Circuit Open
    B1513 Driver Door Handle Circuit Short To Battery
    B1514 Driver Door Handle Circuit Short To Ground
    B1515 Seat Driver Occupied Switch Circuit Failure
    B1516 Seat Driver Occupied Switch Circuit Open
    B1517 Seat Driver Occupied Switch Circuit Short To Battery
    B1518 Seat Driver Occupied Switch Circuit Short To Ground
    B1519 Hood Switch Circuit Failure
    B1520 Hood Switch Circuit Open
    B1521 Hood Switch Circuit Short To Battery
    B1522 Hood Switch Circuit Short To Ground
    B1523 Keyless Entry Circuit Failure
    B1524 Keyless Entry Circuit Open
    B1525 Keyless Entry Circuit Short To Battery
    B1526 Keyless Entry Circuit Short To Ground
    B1527 Memory Set Switch Circuit Failure
    B1528 Memory Set Switch Circuit Open
    B1529 Memory Set Switch Circuit Short To Battery
    B1530 Memory Set Switch Circuit Short To Ground
    B1531 Memory 1 Switch Circuit Failure
    B1532 Memory 1 Switch Circuit Open
    B1533 Memory 1 Switch Circuit Short To Battery
    B1534 Memory 1 Switch Circuit Short To Ground
    B1535 Memory 2 Switch Circuit Failure
    B1536 Memory 2 Switch Circuit Open
    B1537 Memory 2 Switch Circuit Short To Battery
    B1538 Memory 2 Switch Circuit Short To Ground
    B1539 Mirror Driver Switch Assembly Circuit Failure
    B1540 Mirror Driver Switch Assembly Circuit Open
    B1541 Mirror Driver Switch Assembly Circuit Short To Battery
    B1542 Mirror Driver Switch Assembly Circuit Short To Ground
    B1543 Seat Direction Switch Assembly Circuit Failure
    B1544 Seat Direction Switch Assembly Circuit Open
    B1545 Seat Direction Switch Assembly Circuit Short To Battery
    B1546 Seat Direction Switch Assembly Circuit Short To Ground
    B1547 Power Window Master Circuit Failure
    B1548 Power Window Master Circuit Open
    B1549 Power Window Master Circuit Short To Battery
    B1550 Power Window Master Circuit Short To Ground
    B1551 Decklid Release Circuit Failure
    B1552 Decklid Release Circuit Open
    B1553 Decklid Release Circuit Short To Battery
    B1554 Decklid Release Circuit Short To Ground
    B1555 Ignition Run/Start Circuit Failure
    B1556 Ignition Run/Start Circuit Open
    B1557 Ignition Run/Start Circuit Short To Battery
    B1558 Ignition Run/Start Circuit Short To Ground
    B1559 Door Lock Cylinder Circuit Failure
    B1560 Door Lock Cylinder Circuit Open
    B1561 Door Lock Cylinder Circuit Short To Battery
    B1562 Door Lock Cylinder Circuit Short To Ground
    B1563 Door Ajar Circuit Failure
    B1564 Door Ajar Circuit Open
    B1565 Door Ajar Circuit Short To Battery
    B1566 Door Ajar Circuit Short To Ground
    B1567 Lamp Headlamp High-Beam Circuit Failure
    B1568 Lamp Headlamp High-Beam Circuit Open
    B1569 Lamp Headlamp High-Beam Circuit Short To Battery
    B1570 Lamp Headlamp High-Beam Circuit Short To Ground
    B1571 Door Ajar LR Circuit Failure
    B1572 Door Ajar LR Circuit Open
    B1573 Door Ajar LR Circuit Short To Battery
    B1574 Door Ajar LR Circuit Short To Ground
    B1575 Lamp Park Input Circuit Failure
    B1576 Lamp Park Input Circuit Open
    B1577 Lamp Park Input Circuit Short To Battery
    B1578 Lamp Park Input Circuit Short To Ground
    B1579 Dim Panel Increase Input Circuit Failure
    B1580 Dim Panel Increase Input Circuit Open
    B1581 Dim Panel Increase Input Circuit Short To Battery
    B1582 Dim Panel Increase Input Circuit Short To Ground
    B1583 Dim Panel Decrease Input Circuit Failure
    B1584 Dim Panel Decrease Input Circuit Open
    B1585 Dim Panel Decrease Input Circuit Short To Battery
    B1586 Dim Panel Decrease Input Circuit Short To Ground
    B1587 Autolamp Delay Increase Circuit Failure
    B1588 Autolamp Delay Increase Circuit Open
    B1589 Autolamp Delay Increase Circuit Short To Battery
    B1590 Autolamp Delay Increase Circuit Short To Ground
    B1591 Autolamp Delay Decrease Circuit Failure
    B1592 Autolamp Delay Decrease Circuit Open
    B1593 Autolamp Delay Decrease Circuit Short To Battery
    B1594 Autolamp Delay Decrease Circuit Short To Ground
    B1595 Ignition Switch Illegal Input Code
    B1596 Service Continuous Codes
    B1597 Driver's Seat Seatback Autoglide Forward Switch Circuit Short to Ground
    B1598 Driver's Seat Seatback Autoglide Rearward Switch Circuit Short to Ground
    B1599 Passenger's Seatback Autoglide Forward Switch Circuit Short to Ground
    B1600 PATS Ignition Key Transponder Signal Is Not Received
    B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder
    B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder
    B1603 Lamp Anti-Theft Indicator Circuit Failure
    B1604 Lamp Anti-Theft Indicator Circuit Open
    B1605 Lamp Anti-Theft Indicator Circuit Short To Battery
    B1606 Lamp Anti-Theft Indicator Circuit Short To Ground
    B1607 Illuminated Entry Input Circuit Failure
    B1608 Illuminated Entry Input Open Circuit
    B1609 Illuminated Entry Input Short Circuit To Battery
    B1610 Illuminated Entry Input Short Circuit To Ground
    B1611 Wiper Rear Mode Select Switch Circuit Failure
    B1612 Wiper Rear Mode Select Switch Circuit Open
    B1613 Wiper Rear Mode Select Switch Circuit Short To Battery
    B1614 Wiper Rear Mode Select Switch Circuit Short To Ground
    B1615 Wiper Rear Disable Switch Circuit Failure
    B1616 Wiper Rear Disable Switch Circuit Open
    B1617 Wiper Rear Disable Switch Circuit Short To Battery
    B1618 Wiper Rear Disable Switch Circuit Short To Ground
    B1619 Wiper Rear Low Limit Input Circuit Failure
    B1620 Wiper Rear Low Limit Input Circuit Open
    B1621 Wiper Rear Low Limit Input Circuit Short To Battery
    B1622 Wiper Rear Low Limit Input Circuit Short To Ground
    B1623 Lamp Keypad Output Circuit Failure
    B1624 Lamp Keypad Output Open Circuit
    B1625 Lamp Keypad Output Short Circuit To Battery
    B1626 Lamp Keypad Output Short Circuit To Ground
    B1627 PRNDL Reverse Input Circuit Failure
    B1628 PRNDL Reverse Input Open Circuit
    B1629 PRNDL Reverse Input Short To Battery
    B1630 PRNDL Reverse Input Short Circuit To Ground
    B1631 Mirror Driver Left Circuit Failure
    B1632 Mirror Driver Left Circuit Open
    B1633 Mirror Driver Left Circuit Short To Battery
    B1634 Mirror Driver Left Circuit Short To Ground
    B1635 Mirror Driver Right Circuit Failure
    B1636 Mirror Driver Right Circuit Open
    B1637 Mirror Driver Right Circuit Short To Battery
    B1638 Mirror Driver Right Short To Ground
    B1639 Mirror Passenger Left Circuit Failure
    B1640 Mirror Passenger Left Circuit Open
    B1641 Mirror Passenger Left Circuit Short To Battery
    B1642 Mirror Passenger Left Circuit Short To Ground
    B1643 Mirror Passenger Right Circuit Failure
    B1644 Mirror Passenger Right Circuit Open
    B1645 Mirror Passenger Right Circuit Short To Battery
    B1646 Mirror Passenger Right Circuit Short To Ground
    B1647 Seat Driver Recline Forward Circuit Failure
    B1648 Seat Driver Recline Forward Circuit Open
    B1649 Seat Driver Recline Forward Circuit Short To Battery
    B1650 Seat Driver Recline Forward Circuit Short To Ground
    B1651 Seat Driver Recline Backward Circuit Failure
    B1652 Seat Driver Recline Backward Circuit Open
    B1653 Seat Driver Recline Backward Circuit Short To Battery
    B1654 Seat Driver Recline Backward Circuit Short To Ground
    B1655 Seat Driver Rear Up Circuit Failure
    B1656 Seat Driver Rear Up Circuit Open
    B1657 Seat Driver Rear Up Circuit Short To Battery
    B1658 Seat Driver Rear Up Circuit Short To Ground
    B1659 Seat Driver Front Up Circuit Failure
    B1660 Seat Driver Front Up Circuit Open
    B1661 Seat Driver Front Up Circuit Short To Battery
    B1662 Seat Driver Front Up Circuit Short To Ground
    B1663 Seat Driver Front Up/Down Motor Stalled
    B1664 Seat Driver Rear Up/Down Motor Stalled
    B1665 Seat Driver Forward/Backward Motor Stalled
    B1666 Seat Driver Recline Motor Stalled
    B1667 Mirror Driver Up/Down Motor Stalled
    B1668 Mirror Driver Right/Left Motor Stalled
    B1669 Mirror Passenger Up/Down Motor Stalled
    B1670 Mirror Passenger Right/Left Motor Stalled
    B1671 Battery Module Voltage Out Of Range
    B1672 Seat Driver Occupied Input Circuit Failure
    B1673 Seat Driver Occupied Input Circuit Open
    B1674 Seat Driver Occupied Input Circuit Short To Battery
    B1675 Seat Driver Occupied Input Circuit Short To Ground
    B1676 Battery Pack Voltage Out Of Range
    B1677 Alarm Panic Input Circuit Failure
    B1678 Alarm Panic Input Circuit Open
    B1679 Alarm Panic Input Circuit Short To Battery
    B1680 Alarm Panic Input Circuit Short To Ground
    B1681 PATS Transceiver Module Signal Is Not Received
    B1682 PATS Is Disabled (Check Link Between PATS And Transponder)
    B1683 Mirror Driver/Passenger Switch Circuit Failure
    B1684 Mirror Driver/Passenger Switch Circuit Open
    B1685 Lamp Dome Input Circuit Failure
    B1686 Lamp Dome Input Circuit Open
    B1687 Lamp Dome Input Circuit Short To Battery
    B1688 Lamp Dome Input Circuit Short To Ground
    B1689 Autolamp Delay Circuit Failure
    B1690 Autolamp Delay Circuit Open
    B1691 Autolamp Delay Circuit Short To Battery
    B1692 Autolamp Delay Circuit Short To Ground
    B1693 Autolamp On Circuit Failure
    B1694 Autolamp On Circuit Open
    B1695 Autolamp On Circuit Short To Battery
    B1696 Autolamp On Circuit Short To Ground
    B1697 Mirror Driver/Passenger Switch Circuit Short To Battery
    B1698 Mirror Driver/Passenger Switch Circuit Short To Ground
    B1699 Passenger's Seat Occupied Switch Circuit Short to Ground
    B1700 Passenger's Seatbelt Tension Reducer Circuit Short to Ground
    B1701 Seat Driver Recline Forward Switch Circuit Failure
    B1702 Seat Driver Recline Forward Switch Circuit Open
    B1703 Seat Driver Recline Forward Switch Circuit Short To Battery
    B1704 Seat Driver Recline Forward Switch Circuit Short To Ground
    B1705 Seat Driver Recline Rearward Switch Ci
  3. #93
    Użytkownik Romeo Avatar kiepas96
    Czerwionka-Leszczyny
    Alfa 156 1.8 TS
    Alfa 147 2007 rok 1.9 JTDM
    P0230 - Fuel Pump Relay Command - Signal LOW wczoraj skasowany , dzisiaj wrócił, auto świeżo zakupione więc nie wiem czy coś pracuje nie tak, auto jedzie i nie szarpie
    tak btw czy JTDM są 8V i 16V?
    już wiem 8V
    Ostatnio edytowane przez kiepas96 ; 26-05-2011 o 15:00
  4. #94
    G 1.4 MA 170CV ECU Nexus 8GMF
    - sprawdziłem wyrywkowo, coś dziwne te opisy błedów.
    - czy to aby do alfy, czy raczej z internetu sciągniete jako bledu OBD lub EOBD.
    - przykład: C1112 opis: no communication on CAN network.
    - sprawa już wyjaśniona, program alfaOBd w wersji 1.3.1 miał żle napisana procedure interpretacji błedów.
    - biblioteki programu zostały poprawione.
    - powyższy opis bledów jest poprawny.
    Ostatnio edytowane przez bubu321 ; 28-05-2011 o 20:50
    - AR 156 TS 2.0 ecu M1.5.5
  5. #95
    - kody błędów od B1000 -- B1199, uzupełnienie powyższej listy.
    - kody dla Fiata, Lancii, Alfy oraz dla wszystkich instrumentów, innej listy nie znalazłem.
    B1000 Control unit
    B1000 Control unit faulty
    B1000 Control Unit faulty (Microprocessor)
    B1000 Error inside the control unit
    B1001 TEG Lock/Unlock System
    B1001 No end of line configuration
    B1001 Power supply
    B1001 Puddle lights
    B1001 Rain sensor power supply
    B1001 Slide button
    B1001 Speakers outputs
    B1001 K line
    B1001 Steering lock/unlock
    B1001 Seat back forwards button
    B1001 Transponder aerial
    B1001 W. lamp faulty
    B1001 Xenon high voltage drive
    B1001 Speed sensor power supply
    B1001 Engine oil level sensor
    B1001 Spark plug
    B1001 Instrument panel
    B1001 Control unit faulty
    B1001 Driver's side front wind. lift. butt.
    B1001 Electric steering warning lamp
    B1001 Body computer
    B1001 Error inside the control unit
    B1001 Error on switch
    B1001 Front right speaker
    B1001 Front w. riser button driver's side
    B1001 GPS aerial
    B1001 Hood posit.
    B1001 Electric fan control
    B1002 GPS module function.
    B1002 GPS aerial
    B1002 Mode + button
    B1002 Inversion betw. master and slave C.U.
    B1002 K line
    B1002 Key transponder
    B1002 LH buzzer
    B1002 MODE button
    B1002 Power distribution
    B1002 Seat back backwards button
    B1002 System Led
    B1002 TEG enable switch line
    B1002 Vehicle code
    B1002 Fuel Pump
    B1002 Control Unit Power Supply
    B1002 Transponder aerial
    B1002 Boot release
    B1002 EBD w. lamp
    B1002 Front w. riser button driver's side
    B1002 ABS w. lamp
    B1002 AD/C hydraulic oil temp.
    B1002 Boot opening
    B1002 Communication with front panel
    B1002 End of line configuration incorrect
    B1002 Front left speaker
    B1002 Battery voltage
    B1002 Front height button
    B1002 Driver's side front wind. lift. butt.
    B1002 Electrochromic mirror
    B1002 Electric Parking Brake Signal
    B1003 Seat height button up
    B1003 Window riser up actuator
    B1003 Rear LH wind. UP comm.
    B1003 Rear lh window riser
    B1003 Rear LH window up button
    B1003 Rear right speaker
    B1003 RF receiver
    B1003 RH buzzer
    B1003 Solenoid valves temperature
    B1003 System calibration
    B1003 TEG lock/unlock
    B1003 TEG presence congruent with Immo
    B1003 Transponder or secret key incorrect or absent
    B1003 Water temperature sensor
    B1003 Ignition key switch line
    B1003 Rear height button
    B1003 Vehicle configuration received from CAN not correc
    B1003 Electrochromic mirror
    B1003 Key transponder
    B1003 Brightness sensor
    B1003 CAN line error
    B1003 Communication with rear panel
    B1003 Electric steering warning lamp
    B1003 ABS w. lamp
    B1003 Fan
    B1003 Front lh window riser
    B1003 Mode - button
    B1003 Potentiometer
    B1003 Incorrect configuration
    B1003 keyboard
    B1003 LH front elect. window button
    B1003 Front w. riser button pass. side
    B1003 Control unit faulty
    B1003 Paseng. side front wind. lift. butt.
    B1004 RH front elect. window button
    B1004 Rear RH window up
    B1004 Rear rh window riser
    B1004 Rear LH window down button
    B1004 Rear left speaker
    B1004 Rpm sensor
    B1004 Pump motor temperature
    B1004 Rear LH wind. DOWN comm.
    B1004 Seat back button
    B1004 Seat height button down
    B1004 SIM card
    B1004 System activation button
    B1004 System blocked
    B1004 TEG presence congruent
    B1004 Up button
    B1004 Headlamp pos. corr. command
    B1004 Volumetric sensors
    B1004 Window riser down actuator
    B1004 Traction Control warning light (TCS)
    B1004 Alarm serial line
    B1004 LH vent air temp. sens.
    B1004 A-Bus serial line
    B1004 Paseng. side front wind. lift. butt.
    B1004 Alternator D+ signal
    B1004 ASR key warning lamp
    B1004 Battery voltage
    B1004 Connec. to ECU container ground
    B1004 Control unit stopped
    B1004 Front w. riser button pass. side
    B1004 Cooling sensor
    B1004 Internal error
    B1004 Front rh window riser
    B1004 Front LH valve
    B1004 ESP w. lamp
    B1004 ESP
    B1004 Eng. Startup switch line
    B1004 Electric Parking Brake warning light
    B1005 TEG Transponder
    B1005 Rear lh anti-trap sens.
    B1005 Outside temperature
    B1005 Overtemperature sensor
    B1005 Parking brake warning lamp
    B1005 Passenger airbag exclusion w. lamp
    B1005 LH rear elect. window button
    B1005 Rear RH wind. UP comm.
    B1005 Rear RH window up button
    B1005 RH vent air temp. sens.
    B1005 Steering Lock lock enable
    B1005 Steering lock enable from NPE
    B1005 VDC lamp
    B1005 Le power supply
    B1005 Slide forwards button
    B1005 Anti-trap sensor
    B1005 Internal error
    B1005 Tilt sensor
    B1005 Battery voltage
    B1005 Control unit faulty: flash memory write fault
    B1005 EBD w. lamp
    B1005 EEPROM memory
    B1005 Electronic Coupling/ELD System failure
    B1005 Front pass. elec. wind. button from driver
    B1005 Front RH valve
    B1005 Fuel level sensor
    B1005 GPS aerial
    B1005 Handbrake warning light (CAN)
    B1005 Head restraint button
    B1005 Front left anti-trap sensor
    B1005 ABS w. lamp
    B1006 VDC/ASR/TC warning lamp
    B1006 LH rear elect. window button
    B1006 Protected ground faulty
    B1006 Rear LH valve
    B1006 Rear rh anti-trap sensor
    B1006 Rear RH wind. DOWN comm.
    B1006 Rear RH window down button
    B1006 RH rear elect. window button
    B1006 SIM card
    B1006 Slide backwards button
    B1006 Teg Reader Control Unit
    B1006 Vehicle speed sensor
    B1006 LH footwell air temp. sens.
    B1006 LH direct. indicators
    B1006 Steering column longitudinal button
    B1006 Battery voltage out of range
    B1006 LH map light drive
    B1006 ABS w. lamp
    B1006 AM/FM aerial
    B1006 Automatic transm. serial line
    B1006 Clutch switch
    B1006 Control unit faulty
    B1006 Internal error: Bluetooth module
    B1006 Flame sensor
    B1006 Front pass. elec. wind. button from driver
    B1006 Front right anti-trap sensor
    B1006 Fuel level sensor
    B1006 Engine oil level low w. lamp
    B1006 Antenna 1
    B1007 RH direct. indicators
    B1007 Rear RH valve
    B1007 Rear or side LH direction indicators
    B1007 Power ground faulty
    B1007 Lumbar inflation button
    B1007 Lumbar key forward
    B1007 RH footwell air temp. sens.
    B1007 Virgin control unit
    B1007 Parking brake/brake fluid level/EBD warning lamp
    B1007 RH front elect. window button
    B1007 RH map light drive
    B1007 RH rear elect. window button
    B1007 Seat lift forward button (rocking)
    B1007 Steering column vertical button
    B1007 Vehicle speed sensor
    B1007 Antenna 2
    B1007 LH side indicators
    B1007 Traction Control warning light (TCS)
    B1007 Engine oil level sensor
    B1007 Brake switch
    B1007 LH mirror
    B1007 Direction indicators
    B1007 EEPROM memory
    B1007 ASR warning lamp
    B1007 Faulty Led
    B1007 Flame extinguished by minimum current
    B1007 Front LH direction indicators
    B1007 Front sens. ref. position
    B1007 Handbrake warning light (CAN)
    B1007 Internal error
    B1007 Internal error: USB malfunction
    B1007 LH and RH power ground
    B1007 LH direct. indicators
    B1007 Direction indicators on LH side or front LH
    B1008 Rear or side RH direction indicators
    B1008 No direct power supply (+30)
    B1008 Outside air temperature sens.
    B1008 Outside temperature
    B1008 Vehicle speed sensor
    B1008 Pass. side rear ceiling lamp input
    B1008 Stop lights
    B1008 RH direct. indicators
    B1008 RH mirror
    B1008 RH rear elect. window button
    B1008 RH side indicators
    B1008 Seat lift backward button (rocking)
    B1008 Side lights
    B1008 Generic error
    B1008 Missing calibration
    B1008 Start enable with lever on Park from Autom. Gearbo
    B1008 1st lev. driver's Airbag resist.
    B1008 Mirror motor connection
    B1008 Keyboard blocked
    B1008 Ceiling light drive
    B1008 Comfort button
    B1008 Connection with Airbag
    B1008 Direction indicators on RH side or front RH
    B1008 Flame extinguished by medium current
    B1008 Front RH direction indicators
    B1008 Hood movement Time out
    B1008 LH rear elect. window button
    B1008 LH sunshine sensor
    B1008 Lumbar deflation button
    B1008 Lumbar key backward
    B1008 Front LH wheel accelerometer
    B1009 RH sunshine sensor
    B1009 GSM aerial
    B1009 LH handle input for Passive Entry
    B1009 LH side lights
    B1009 Memory 1 button
    B1009 Outside air temperature sens.
    B1009 Passenger airbag failure w. lamp
    B1009 Pre-calibration not performed
    B1009 Side lights on LH side or front LH
    B1009 RH rear elect. window button
    B1009 Front RH wheel accelerometer
    B1009 Side lights
    B1009 Rear LH direction indicators
    B1009 1st lev. pass Airbag resist.
    B1009 Start button
    B1009 Flame extinguished by maximum current
    B1009 Air temperature sensor
    B1009 Airbag failure w. lamp
    B1009 Auxiliary instrument cluster
    B1009 Body computer
    B1009 ESP w. lamp
    B1009 Ceiling light button
    B1009 Door lock button
    B1009 Door lock/unlock button
    B1009 Engine oil temperature sensor
    B1009 ESP
    B1009 Button
    B100A VDC lamp
    B100A Side lights on RH side or front RH
    B100A Passenger airbag failure w. lamp
    B100A Airbag failure w. lamp
    B100A 2nd lev. pass. Airbag resist.
    B100A FLH body accelerometer
    B100B Seat belts w. lamp
    B100B Rear foglights
    B100B Driver's pretens. resist.
    B100B FRH body accelerometer
    B100B Fuel gauge
    B100B LH rear foglight
    B100C Water temp. gauge
    B100C RLH body accelerometer
    ---------- Post added at 19:16 ---------- Previous post was at 19:14 ----------
    - cd. listy od B1000 -- B1199
    B100C RH rear foglight
    B100C Passenger pretens. resist.
    B100D Central pretens. resist.
    B100D Foglights relay
    B100D Rear side airbags w. lamp
    B100D Rev counter
    B100E Heated rear window relay
    B100E Speedometer
    B100E Driver's side airbag resist.
    B100F Pass. side airbag resist.
    B100F Main-beam headlights relay
    B1010 Button
    B1010 Incorrect date or time
    B1010 RH handle input for Passive Entry
    B1010 Rear RH direction indicators
    B1010 Webasto: PWM signal
    B1010 Rear foglights
    B1010 Memory 2 button
    B1010 Internal error
    B1010 Headlamp washer relay
    B1010 Electric steering warning lamp
    B1010 Control Unit Power Supply
    B1010 Control unit faulty
    B1010 Congruence key +15 from rotary TEG
    B1010 Front LH wheel accelerometer
    B1010 Xenon light-up failure
    B1010 Control unit
    B1010 Doo
    Ostatnio edytowane przez bubu321 ; 21-06-2011 o 07:59
  6. #96
    - cd listy od B1000 -- B1199.
    - lista dla Alfy , Fiata, Lancii i wszystkich instrumentów.
    - listy posortowanej nie znalazłem.
    B1025 Driver's side mirror output1
    B1025 Pass. side mirror output1
    B1025 Air recirculation actuator
    B1025 Automatic Transmission (NCA-NCR)
    B1025 Follow-Me Home relay
    B1025 Lights command analogic input
    B1025 GSM telephone: connections
    B1025 Optional services relay
    B1025 Timed boot lights
    B1025 Rear RH wind. keyboard
    B1025 RH side airbags activation
    B1025 Services relay 2
    B1025 Slide Sensor/Motor forward
    B1025 Steering column vertical actuator
    B1025 Stop lights
    B1025 Mirror motor connection
    B1026 Rear window curtain down
    B1026 Pretensioners triggered
    B1026 Slide Sensor/Motor backward
    B1026 Siren
    B1026 Pollution sensor
    B1026 Pass. side mirror output2
    B1026 Pass. Entry rear LH motor
    B1026 Front ceiling light
    B1026 Driver's side mirror output2
    B1026 Cushion ventilation driver
    B1026 Brake fluid level analogic input
    B1026 Control unit faulty: flash memory write fault
    B1026 Mirror motor connection
    B1027 Dashboard Flap Opening
    B1027 Rear LH Passive Entry circuit enable
    B1027 Pass. side mirror output3
    B1027 Mirror motor connection
    B1027 max n. airbag interventions exceeded
    B1027 LH vent led
    B1027 Control unit faulty: video interface
    B1027 Driver's side lock input
    B1027 Seat back ventilation driver
    B1027 Ultrasound sensor
    B1027 Driver's side mirror output3
    B1027 Ultrasound/hyperfrequency sensor
    B1027 RH rear ceiling light
    B1028 Seat heating ON feedback
    B1028 Tilt sensor
    B1028 RH vent led
    B1028 Puddle lights
    B1028 Pass. side puddle light
    B1028 Outside temperature input
    B1028 LH rear ceiling light
    B1028 Driver's side puddle light
    B1028 Driver/passenger side puddle light
    B1028 Control unit faulty: memory interface
    B1028 Pass. Entry rear RH motor
    B1029 Door lock release relay
    B1029 Serial line W
    B1029 Self-adaptive comfort driver ON
    B1029 Rear RH Passive Entry circuit enable
    B1029 Rear ceiling lights
    B1029 Rear c. lamp output pass. side
    B1029 Rear c. lamp output driver's side
    B1029 Door lock/unlock internal relay
    B1029 Cigar lighter and air cond. light
    B1029 Photosensor
    B102A Door lock lock relay
    B102A Communication line: Clima commands/Clima control unit
    B102B Boot opening relay
    B102B Cargo area lock relay
    B102B Communication line: ICS/Clima commands
    B102B Rear passenger pretensioner explosive charge
    B102B Boot unlock relay
    B102C Super lock relay
    B102C Communication line: ICS/Clima keyboard
    B102C Rear driver's side pretens. explos. charge
    B102D Direction indicators on LH side or front LH
    B102E Rear Passenger side airbag explosive charge
    B102E Direction indicators on RH side or front RH
    B102F Rear driver's side sid airbag explosive charge
    B1030 Master/Slave communication
    B1030 LIN serial line
    B1030 Self-adaptive comfort driver OFF
    B1030 SBMT 2
    B1030 SBMT 1
    B1030 LIN line
    B1030 Brake light fuse
    B1030 Licen.plate lights or LH l.p. light
    B1030 LH number plate light
    B1030 Knee guard (driver's side)
    B1030 Rear LH and RH puddle lights
    B1031 Engine compartment light output
    B1031 Rear c. lamp output pass. side
    B1031 Pass. side rearview mirror defrost
    B1031 Mirror defroster
    B1031 Massage comfort driver ON/OFF
    B1031 LIN serial line
    B1031 LIN line
    B1031 Failure lamp
    B1031 RH number plate light
    B1031 Driver's side rearview mirror defrost
    B1031 Autoclose
    B1031 1st lev. driver's Airbag resist.
    B1031 Rear LH Super Lock disable
    B1031 Inside lighting
    B1032 LIN serial line
    B1032 1st lev. driver's Airbag resist.
    B1032 Stop lights
    B1032 Rear window wiper relay
    B1032 Rear LH Super Lock enable
    B1032 Messages control unit
    B1032 LIN line
    B1032 LH stop light
    B1032 Front seat lift motor DOWN sensor (rocking)
    B1032 Dipped headlights relay
    B1032 Brake lights of LH br. light
    B1032 Air temperature sensor
    B1032 Outside air temperature sens.
    B1033 Rear window washer pump relay
    B1033 RH stop light
    B1033 Sport button input
    B1033 Seat temperature probe
    B1033 Anti-trap sheath/HALL-effect sensor
    B1033 Anti-trap sheath driver's side
    B1033 Anti-trap sensor
    B1033 Airbag, driver's side squib in S.C. to GND.
    B1033 SBMT 2
    B1033 Rear LH safety catch enable
    B1034 GAS level input
    B1034 Rear LH Super Lock/safety catch disable
    B1034 Pass. side keyboard lighting
    B1034 keyboard
    B1034 Front ceiling light
    B1034 Driver's side keyboard lighting
    B1034 Airbag, driver's side squib in S.C. to +Batt.V
    B1034 LH front foglights relay
    B1035 RH spot light / rear ceiling lamp
    B1035 Lock input (pass.)
    B1035 Mirror pos. potentiometer (horizontal)
    B1035 Pass. side mirror output1
    B1035 RH front foglights relay
    B1035 RH Map light
    B1036 Rear LH side lights LED
    B1036 LH Map light
    B1036 LH sidelight / LH day light driver
    B1036 Memory 1 button
    B1036 Mirror pos. potentiometer (vertical)
    B1036 Pass. side mirror output2
    B1036 Rear wind. curtain up
    B1036 Unlock input (pass.)
    B1037 Mirror posit. button
    B1037 Pass. side mirror output3
    B1037 Memory 2 button
    B1037 LH sidelight / LH day light feedback
    B1037 Cigar lighter and air cond. light
    B1037 Rear RH side lights LED
    B1038 Brake light fuse
    B1038 LH Brake light LED
    B1038 Memory 3 button
    B1038 Mirror fold mot. (driver)
    B1038 Mirror fold mot. (pass.)
    B1038 RH sidelight / RH day light driver
    B1039 Passive entry motor driver's side
    B1039 Passive entry motor pass. side
    B1039 RH sidelight / RH day light feedback
    B1039 Dipped headlights relay
    B1039 Lumbar inflation button
    B1039 RH Brake light LED
    B103A Front impact sens.
    B103A Front lamp command
    B103A Lumbar deflation button
    B103B LH sidelight / LH Brake Light
    B103B RH front impact sensor
    B103B Seat height button up
    B103C RH sidelight / RH Brake Light
    B103C Seat height button down
    B103C Rear side airbags exclusion switch
    B103D Seat back forwards button
    B103D Knee guard (pass. side)
    B103E Seat back backwards button
    B103F Rear LH LED direction indic.
    B103F Slide forwards button
    B1040 Driver's abdominal pretensioner
    B1040 Passive entry driv. circuit driver's side
    B1040 Slide backwards button
    B1040 Rear RH LED direction indic.
    B1040 Passive entry driv. circuit pass. side
    B1040 Headlamp pos. correct.
    B1040 Headlamp actuators
    B1040 Front LH window up
    B1040 Dusk sensor
    B1040 Headlight position corrector LH motor
    B1041 Headlight position corrector RH motor
    B1041 Sensor power supply
    B1041 Rain Sensor
    B1041 Passenger's abdominal pretensioner
    B1041 Height sensor (Hall)
    B1041 Front LH window down
    B1041 1st lev. pass Airbag resist.
    B1041 LH sidelight / LH Brake lamp
    B1042 Seat back sensor (Hall)
    B1042 Tachimetric sensor
    B1042 Vehicle speed
    B1042 Front RH window up
    B1042 1st lev. pass Airbag resist.
    B1042 RH sidelight / RH Brake lamp
    B1043 Airbag, passenger's side squib in S.C. to GND.
    B1043 Front RH window down
    B1043 High beam lights relay
    B1043 RH front foglights relay
    B1043 Slide sensor (Hall)
    B1044 LH front foglights relay
    B1044 Rear LH window up
    B1044 Airbag, passenger's side squib in S.C. to +Batt.V
    B1045 Rear LH window down
    B1045 Inertia switch command airbag node (FIS)
    B1046 Inertia switch command Engine Control Node (FIS)
    B1046 Rear RH window up
    B1047 Inertia switch
    B1047 LIN line
    B1047 Rear RH window down
    B1048 LIN line
    B104A Proxi Alignment Procedure
    B104B System calibration
    B1050 Anti-trap sheath/HALL-effect sensor
    B1050 Control Unit Power Supply
    B1050 Driver's door aerial
    B1050 Power supply wiring resistance
    B1051 Front sensor
    B1051 Passeng. door aerial
    B1051 Driver's pretens. resist.
    B1051 Control Unit Power Supply
    B1051 Battery voltage out of range
    B1051 Anti-trap sheath/HALL-effect sensor
    B1052 Rear LH anti-trap sheath
    B1052 Rear LH door aerial
    B1052 Driver's pretens. resist.
    B1053 Driver's pretensioner, explosive charge in S.C. to
    B1053 Rear RH anti-trap sheath
    B1053 Rear RH door aerial
    B1054 Boot aerial
    B1054 Driver's pretensioner, explosive charge in S.C. to
    B1055 Internal aerial 1
    B1055 Passenger pretens. resist.
    B1056 Internal aerial 2
    B1056 Passenger pretens. resist.
    B1057 Internal aerial 3
    B1057 Passenger pretensioner, explosive charge in S.C. t
    B1058 Aerial inside boot
    B1058 Passenger pretensioner, explosive charge in S.C. t
    B1060 Discharge headlamp actuator
    B1060 Garage posit. aerial
    B1061 Battery voltage
    B1061 Driver's side airbag resist.
    B1061 Rear sensor
    B1062 Driver's side airbag resist.
    B1062 Passive Entry control unit
    B1063 Left side airbag, explosive charge in S.C. to Grou
    B1063 Steering Lock lock enable control input
    B1064 Left side airbag, explosive charge in S.C. to +Vba
    B1065 Pass. side airbag resist.
    B1066 Pass. side airbag resist.
    B1067 Right side airbag, explosive charge in S.C. to Gro
    B1068 Right side airbag, explosive charge in S.C. to +Vb
    B1070 LH Headlamps Posit. Correct.
    B1071 Front impact sens. (driver)
    B1071 LH headlamp horizontal angular position
    B1071 Vehicle speed
    B1072 Front impact sens. (driver)
    B1072 RH Headlamps Posit. Correct.
    B1073 Front impact sens. (driver)
    B1073 RH headlamp horizontal angular position
    B1074 Front impact sens. (driver)
    B1080 Stop&Start function request
    B1081 Low-beam headlight signal
    B1081 Stop&Start relay
    B1081 Side impact sensor (driver's)
    B1082 Voltage stabilizer
    B1082 Side impact sensor (driver's)
    B1083 Side impact sensor (driver's)
    B1083 Stop&Start relay feedback (from NCM)
    B1084 Battery sensor (IBS)
    B1084 Side impact sensor (driver's)
    B1085 Side impact sensor (driver's)
    B1090 Steering lock error
    B1091 Side impact senor (passenger)
    B1091 Battery voltage
    B1092 Side impact senor (passenger)
    B1093 Side impact senor (passenger)
    B1094 Side impact senor (passenger)
    B1095 Side impact senor (passenger)
    B10AA PROXI configuration control
    B10F1 Pretensioners impact data
    B10F2 Airbag and pretens. impact data
    B10F3 Driver's side airbag impact data
    B10F4 Passeng. side airbag impact data
    B10F5 Rear impact detected
    B1100 Control unit internal voltage
    B1133 Battery error
    B1141 Outside air temperature sens.
    B1142 Outside air temperature sens.
    B1150 No communication with Airbag control unit
    B1157 Airbag exploded signal
    B1170 EEPROM Memory function.
    Ostatnio edytowane przez bubu321 ; 07-06-2011 o 06:38
  7. #97
    Użytkownik Maniak resoraków Avatar plnuker
    Katowice
    Alfa Romeo GT 1.9 JTD
    Cytat Napisał kamien007 Zobacz post
    hm a aby te błędy odczytać trzeba alfę pod kompa podłączyć?
    mam problem z poduszka powietrzna nie gaśnie kontrolka
    Mi się paliła kontrolka - poprawiłem kostkę pod siedzeniem kierowcy i jest ok
  8. #98
    Użytkownik Rowerzysta Avatar Annik
    Łomża
    Giulia VELOCE Q4 MY20
    pojawił mi sie poniższy błąd:
    "1: P1619Powodem tego błędu jest to, że ECU otrzymał bardzo niski sygnał z czujnika.Usterka nie zostanie wykryta teraz, ale jest przechowywana w pamięci.
    Wyczyść kody błędów i obserwuj przyszłe wystąpienie tego błędu.Lampka na desce została aktywowana przez ten błąd. "
    Kontrolka "skasowała się" sama po 2-3 uruchonieniach ale mnie to zaniepokoiło. Jestem przed totalnym czyszczeniem dolotu(przepływka,EGR, przepustnica)
    Czy na cos powinienem zwrócić szczególną uwagę?
    Jestem nowy w temacie Alf. Poproszę znawców tematu o interpretację poniższych log-ów:
    READ PARAMETERS:
    Obroty silnika: 845 rpm
    Temperatura wody: 87,7 °C
    Otwarcie regul. cisnienia: 16,28 %
    Prad regulac. wysok.cisn.: 639 mA
    Docel. masa powietrza: 314,0 mg/i
    Mierzona masa powiet.: 544,0 mg/i
    Otwarcie zaworu EGR: 1,00 %
    Cisnienie atmosferyczne: 1 021 mBar
    Temperatura powietrza: 32,2 °C
    Napiecie akumulatora: 13,99780 V
    Temperatura wody AD/C: 1,241 V
    Docel. cisnienie doladowania: 1 000 mBar
    Mierzone cisnienie doladow.: 1 034 mBar
    Otwarcie zaworu overboost: 75,00 %
    Czas wtrysku glownego: 737 ms
    Korekta paliwa Cyl.1: 1,06 mmł/i
    Korekta paliwa Cyl.2: -0,63 mmł/i
    Korekta paliwa Cyl.3: 0,20 mmł/i
    Korekta paliwa Cyl.4: -0,68 mmł/i
    Cisnienie klimatyzatora: bar
    Temperat. powietrza (turbo): 55,3 °C
    Ilosc Ogolna Gazolu: 6,34 mmł/i
    Temperatura gazolu AD/C: 3,211 V
    Temperatura gazolu: 23,5 °C
    Poczat.wtrysk.glownego: 0,00 stopni.
    oraz przy wyższych obrotach:
    READ PARAMETERS:
    Obroty silnika: 2 222 rpm
    Temperatura wody: 82,4 °C
    Otwarcie regul. cisnienia: 21,56 %
    Prad regulac. wysok.cisn.: 874 mA
    Docel. masa powietrza: 345,7 mg/i
    Mierzona masa powiet.: 601,5 mg/i
    Otwarcie zaworu EGR: 18,84 %
    Temperatura powietrza: 29,1 °C
    Napiecie akumulatora: 14,09555 V
    Temperatura wody AD/C: 1,388 V
    Docel. cisnienie doladowania: 1 003 mBar
    Mierzone cisnienie doladow.: 1 092 mBar
    Otwarcie zaworu overboost: 70,37 %
    Czas wtrysku glownego: 527 ms
    Korekta paliwa Cyl.1: 1,01 mmł/i
    Korekta paliwa Cyl.2: -0,61 mmł/i
    Korekta paliwa Cyl.3: 0,06 mmł/i
    Korekta paliwa Cyl.4: -0,39 mmł/i
    Temperat. powietrza (turbo): 54,8 °C
    Ilosc Ogolna Gazolu: 0,00 mmł/i
    Rozruch silnika: Allowed
    Cisnienie oleju: OK
    Przekaznik pompy paliwa: ON
    ˙ţ"Czas" Obroty silnika Korekta paliwa Cyl.1 Korekta paliwa Cyl.2 Korekta paliwa Cyl.3 Korekta paliwa Cyl.4
    rpm mmł/i mmł/i mmł/i mmł/i
    0,0 824 0,6600 -0,5300 0,5200 -0,6400
    1,0 845 0,6700 -0,4700 0,4200 -0,6800
    2,0 994 0,7600 -0,5300 0,3800 -0,6100
    3,0 1 514 0,5400 -0,6000 0,4000 -0,2100
    4,0 1 668 0,4500 -0,5600 0,1800 -0,1000
    5,1 1 736 0,4700 -0,2900 -0,1000 -0,0800
    6,0 0 0,3900 -0,1900 -0,1800 -0,0200
    7,1 1 756 0,3400 -0,1200 -0,2500 0,0300
    8,2 1 763 0,3000 -0,0600 -0,3600 0,1000
    9,2 1 763 0,3100 -0,0800 -0,3400 0,1300
    10,2 1 765 0,3200 -0,1300 -0,3200 0,1100
    11,2 1 765 0,3300 -0,1300 -0,3200 0,1200
    12,3 1 762 0,3300 -0,1400 -0,3000 0,1300
    13,3 1 766 0,3100 -0,1100 -0,3200 0,1200
    14,3 1 764 0,3100 -0,0900 -0,3300 0,1300
    15,4 1 771 0,3100 -0,0700 -0,3500 0,1000
    16,4 1 770 0,3200 -0,1400 -0,2800 0,1100
    17,4 1 788 0,3100 -0,1700 -0,2800 0,1500
    18,4 1 928 0,3200 -0,1600 -0,3600 0,2300
    19,5 1 939 0,3100 -0,1900 -0,3700 0,2000
    20,5 1 944 0,3900 -0,2000 -0,3600 0,1400
    21,5 1 944 0,4400 -0,2100 -0,3600 0,1500
    22,6 2 020 0,4500 -0,2400 -0,3500 0,1400
    23,6 2 042 0,4300 -0,2800 -0,3300 0,2200
    24,6 2 048 0,3800 -0,2400 -0,3800 0,2500
    25,6 2 052 0,3600 -0,2700 -0,3400 0,2600
    26,6 2 052 0,3400 -0,3000 -0,3200 0,2800
    27,6 2 055 0,3300 -0,3000 -0,2800 0,2400
    28,7 2 052 0,3000 -0,2700 -0,3200 0,2800
    29,7 2 059 0,3000 -0,2900 -0,2900 0,3000
    30,7 2 058 0,2800 -0,3300 -0,2800 0,3300
    31,8 2 059 0,3100 -0,3500 -0,3200 0,3200
    32,8 2 060 0,3500 -0,3300 -0,3200 0,3100
    33,9 2 057 0,3100 -0,2700 -0,3800 0,3400
    34,9 2 053 0,3000 -0,2100 -0,4000 0,3000
    35,9 2 059 0,3000 -0,2800 -0,3400 0,3300
    36,9 2 056 0,3000 -0,3000 -0,3100 0,3400
    38,0 2 064 0,2800 -0,3400 -0,3100 0,3400
    39,0 2 055 0,3000 -0,2700 -0,3100 0,3000
    40,0 2 056 0,2700 -0,2600 -0,3400 0,2900
    41,0 2 055 0,3200 -0,2700 -0,3100 0,3000
    42,0 2 056 0,2800 -0,3300 -0,2200 0,2900
    43,1 2 063 0,2600 -0,3400 -0,2300 0,2900
    44,1 2 065 0,2600 -0,2900 -0,2700 0,3000
    45,2 2 069 0,2900 -0,2600 -0,3200 0,3100
    46,2 2 063 0,2600 -0,2900 -0,3300 0,3500
    47,2 2 059 0,2600 -0,2400 -0,3300 0,3500
    48,2 2 064 0,2100 -0,3000 -0,3200 0,3700
    49,2 2 065 0,2400 -0,3300 -0,2700 0,3700
    50,3 2 063 0,2400 -0,2800 -0,3100 0,3400
    51,3 2 066 0,2300 -0,2300 -0,3600 0,3200
    52,4 2 064 0,2800 -0,2600 -0,3400 0,3600
    53,4 2 064 0,2800 -0,2800 -0,3100 0,3400
    54,4 2 063 0,2600 -0,2700 -0,3100 0,3500
    55,4 2 062 0,2700 -0,2900 -0,3200 0,3100
    56,5 2 059 0,2800 -0,2700 -0,3300 0,2800
    57,5 2 058 0,2900 -0,2900 -0,2600 0,3000
    58,5 2 060 0,2700 -0,2900 -0,3000 0,3200
    59,6 2 060 0,2700 -0,2500 -0,3300 0,3100
    60,6 2 067 0,2700 -0,2700 -0,3300 0,3300
    61,6 2 061 0,2800 -0,2700 -0,3300 0,3400
    62,7 1 575 0,2900 -0,3100 -0,3100 0,3400
    Z góry wielkie dzięki
  9. #99
    Użytkownik Alfista
    Same ALFICE
    Najlepiej przeprowadzic test drogowy, bo gazowanie na postoju to mało miarodajny test. Tak na szybko to, przepływka Ci cos przekłamuje, oraz masz dziwne korekty wtryskiwaczy. Trzeba chyba bedzie sie im przyjrzec.
  10. #100
    Łomża
    Przyjrzeć się im .....tzn? Coś programowego czy może zużyte/zabrudzone? Auto zaczęło jeździć po 5-cio miesięcznej przerwie stłuczka/import/naprawa itd.
    dzięki za odp.
    df
  1. Kody błędów
    Utworzone przez JacekCZ w dziale GT
    Ostatni post / autor: 13-08-2017, 16:35
  2. [GTV] Kody błędów GTV
    Utworzone przez PrzemonZly w dziale Gtv/Gtv Spider
    Ostatni post / autor: 17-12-2014, 07:34
  3. kody błędów
    Utworzone przez aikwaw w dziale 156
    Ostatni post / autor: 29-11-2014, 14:40
  4. Kody błędów [156]
    Utworzone przez gacek600 w dziale 156
    Ostatni post / autor: 08-01-2012, 19:45
  5. Kody Błędów 1.9 JTD
    Utworzone przez sobi112 w dziale 156
    Odpowiedzi: 17
    Ostatni post / autor: 10-11-2011, 21:28
