Page 1 with 2 12 LastLast
Show results from 1 to 10 with 19
Subject: 1.9 16V Errors
    Keeperek
    A guest
    Domyślnie 1.9 16V Errors and P1213 P1102
    Something again yesterday... a little pogoniłem we're at high revs, but not for long, 10km quietly in the morning before work, after work, all at once popped up the error. I connected fiatecuscan 1.6 and showed the error:
    P1213 like the Boost/Manifold Air temperature , and the description:
    "Air temperature sensor in turbine"
    P1102 /no data/ skASOco., and never came back
    Nothing on the Internet is not found regarding these errors, the first thing I thought it przepływka, but not. The rest look at the pictures fiatecuscana:
    http://img691.imageshack.us/g/bledy0.jpg/
    Strange reading Boost/Manifold temperature : 130stC.
    What is this sensor? Does anyone know?
    In addition błedami any symptoms.
    › Więcej...: 1.9 16V Errors
    The user Expert Avatar sedici
    He joined the
    10 2007
    Lives in
    OPL & (ANsbach) DE
    Bravo1,6Mj , Astra J
    Posts
    1,912
    P1213 - Boost/Manifold Air temperature sensor boost pressure - MAP (measures of deposits and air temperature in the intake manifold) , the manifold he has registered\or erroneously detects a temperature of air;
    P1102 - MAF (Mass Air Flow) sensor , error przepływki probably called him illogical for the ECU the temperature is measured on the map ;
    and the strange thing is that the CARD detects a high temperature , maybe it is very dirty and has poor performance or failed , remove it and RUB gently and again in the comp
    This is my truth tell me yours
    "The policy has been invented to lie sound like the truth." G. Orwell
    http://www.youtube.com/watch?v=liSxjtd16xQ -bastard
    Keeperek
    A guest
    The boost pressure sensor cleaned some 6 thousand ago, but zerkne there yet, maybe just a cleaning will help. But if odepne czujniik on trial, then most likely the car won't start? And another question : the parameter "Boost presure" the pressure from the sensor? What should be at maximum speed? OK 2bar? Or is it some way to check the turbos?
    He joined the
    10 2007
    Lives in
    OPL & (ANsbach) DE
    Posts
    1,912
    rather, will not activate, because only thanks to this sensor the ECU controls the Turbocompressor - boost pressure (at the moment I do not remember whether recovery on the Map );
    Yes , boost pressure is boost pressure measured KART-em as you want to check how the turbo shakes, include graphics : the required pressure and measured pressure ,
    table : desired boost pressure (necessary) and boost pressure (measured) , include in the schedule and in the way : the best of all 3. or 4 . move from 2000rpm the gas to the floor and you will see that the chart is measured the same as that found via the ECU (boost map)
    Keeperek
    A guest
    Took them a boost pressure sensor, and found that all of her burned. http://img638.imageshack.us/i/photo0038u.jpg/
    I'm going to replace it, but a little afraid that the new is also beat. What is the cause of failure of this sensor? Too high of temp. in the intake manifold? black is burning?
    Quickly buy used?
    The user Quadrifoglio Verde Avatar Maciek-156
    He joined the
    05 2007
    Lives in
    Warsaw, Poland
    Posts
    8,623
    Probably not overexposed and killed planted with EGRa - it would not hurt to clean. Przyślep himself EGR dedicated zaslepką.
    Giulietta 1, 4 TB HAS Distinctive 2010
    AR156 1.9 16v JTD M-jet 2004
    AR156 1.6 TS 2000
    Previously, 7 Italian cars F (126, 127, UNO DS, TIPO, PUNTO, BRAVA, MAREA)
    Keeperek
    A guest
    The sensor apparently burned down, sticking only to the remains of the wires from it and this is not a plastic basket. I will add that some 6tys ago sensor cleaned and Yes, he was killed by soot, but this time I got burned:/
    Egr part of theit is blinded from 6tys km
    He joined the
    10 2007
    Lives in
    OPL & (ANsbach) DE
    Posts
    1,912
    it's hard to say what was the cause , Nagar \breakage when cleaning as it is cleared, then write something after it ?;
    the new sensor the cost of theincludes about 150pln , so that the stimulator needs to be a good price to have been worth it , he was once on "Allegro," I sold your used sensor
    Keeperek
    A guest
    For cleaning I used alcohol, gasoline, after cleaning thoroughly osuszyłem and przejechalem 6tys.. I hope the next will survive longer. As for prices, the site nówki OK 280zł, I decided używke (in which case you can give).
    Another question I have , do not want to open a new topic. Rozgladam for the flowmeter, epera must be: 46811312
    but I need room Bosch. Somewhere once saw rozpiske on the forum, but can't find it. I know I can pull out the old meter, but I'm not sure that is correct.. I want to create as it should be.
    He joined the
    05 2007
    Lives in
    Warsaw, Poland
    Posts
    8,623
    Here you have a catalog online
    http://www.bosch.onyx.pl/czesci_samochodowe/
    AR156 1.6 TS 2000
Similar threads
  1. Error AIR-BAG
    Created by Andrzej78500 in section 166
    Response: 27
    Last post/author: 12-05-2015, 20:12
  2. Air-bag errors
    Created by adagio72 in section 156
    Response: 7
    Last post/author: 18-10-2014, 17:23
  3. What is this error
    Created by olaf in section 147
    Response: 1
    Last post/author: 15-07-2014, 21:50
  4. [146] What's wrong? Encoding error codes when connected to a computer ?? 4 BUGS
    Created by grzechu220 in the section 145/146/155
    Response: 2
    Last post/author: 07-10-2013, 18:52
  5. Error ABS
    Created by kaaamilp in section 147
    Response: 1
    Last post/author: 28-03-2012, 17:55
alfa romeo 156 error p1213
p1213 - boostmanifold air temperature
1.9 jtd 16v 140 ps boost pressure
alfa romeo b
desired boost pressure reading
p1213 alpha
alfa 156 blad 1213
blad boost presure sensor alfa 156
p1213 alfa romeo
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
