Show results from 21 to 30 with 55
Subject: Potentiometer the gas pedal?
31-08-2012, 16:57 #21
Attaches to questions, where alfie after lifcie the inside look for cubes and potentiometer?
Sent from my HTC Flyer P512
› Więcej...: Potentiometer for the gas pedal?
01-09-2012, 13:03 #22syfonA guest
In 156 z engineAmi TS after lifting do not look for a cube behind the storage compartment. She's not there. A potentiometer is on the gas pot and the installation goes directly to the controller. And do not believe in these versions in the gas pedal error message, the gas potentiometer malfunction. The cause for 99% lies in candles, high voltage cables or pipes. Alternatively, the coil is punctured. Two electricians in me could not fault me with this advice. One was even praised here on the forum as spec ao alf. Unfortunately the cost of theIt took me a lot of money, time and ner to finally self-diagnosis and aut repair. Why do not I know that? But that's some information.
01-09-2012, 13:42 #23
01-09-2012, 17:02 #24The user Romeo
- He joined the
- 03 2010
- Lives in
- Glatz
- Auto
- AR 159 1.9 JTD M-Jet 16V 150KM & AR 156 1.9 JTD M-Jet 16V 140KM
- Posts
- 699
And in the enginech JTDM After lifcie? For me this error P0226 unless ... but definitely described was in connection with a potentiometer pedalu accelerate ...Last edited by peenbe ; 01-09-2012 about 17:22
01-09-2012, 18:39 #25syfonA guest
I have no idea. I only know my case with 1.6 TS 2004, because no electrician is not advised and i had to take myself to work. Before that I exchanged twice the gas pedal, even new original unnecessarily bought, then I exchanged the throttle, the ankle with the accelerator pedal, clicked to clear the driver and finally told buy the new driver. So now that I have two pedals, throttles and drivers. Even I prefer not to think as me the cost of theowało.
01-09-2012, 21:08 #26
02-09-2012, 05:33 #27syfonA guest
02-09-2012, 06:59 #28The user The alpha and the Omega
- He joined the
- 04 2009
- Lives in
- Bolesławiec
- Auto
- 2002 156 2.4 JTD CF3 150KM
- Posts
- 469
DolnySlask - Boleslawiec. Zgorzelec. Jelenia Gora
With pleasure I Can help in the field:
AlfaDiag FiatEcuScan MultiEcuScan diagnosis
MP KWP2000 Galletto - up fuel cards
STAG KME - equipment LPG
02-09-2012, 07:32 #29The user Cyclist
- He joined the
- 05 2007
- Lives in
- Starogard Gdański / Gdansk
- Auto
- Giulietta 2014 2,0 JTD
- Posts
- 69
in JTD After lifcie the cube and the potentiometer is also directly on the accelerator pedal.
I had problems with the same error. For me to appear on average every two weeks.
Start service mode and claimed the idle to 1, 5 k.
I pulled the whole thing, from what I remember screwed is the two or three screws or nuts.
Cleared, popryskałem contact and at the time probably discovered the cause of the error.
Well, for me the two terminals push-on with plug-ins were wypięte, i.e. they were not pressed to secure and by connecting the plug slightly groups.
I shoved them and so by 1.5 year error.
He returned about a month ago, but so far only it skASOthe shaft and nothing more I did.
02-09-2012, 09:39 #30
Similar threads
The pedal potentiometer needs a gas pedal
Created by Peterxxx Lublin DepartmentResponse: 0Last post/author: 21-05-2015, 21:34 -
[156] Potentiometer / pedal gas sensor 2,4 jtd 136km
Created by NightDay in the section Buy partsResponse: 0Last post/author: 08-01-2015, 09:19 -
V6 gas pedal potentiometer. What to buy
Created by Miriaczi in section 166Response: 2Last post/author: 04-05-2013, 21:22 -
How to remove the JTD gas pedal potentiometer
Created by Alfista in section 166Response: 6Last post/author: 30-05-2012, 22:28 -
How to replace the pedal potentiometer at 166 V6?
Created by Zonkil in section 166Response: 5Last post/author: 23-09-2011, 20:38
