Show results from 1 to 10 with 16
11-03-2011, 19:46 #1tojatajankaA guest
engine braking and fuel consumption 2.0 l/100 km
When braking engineiem (full release gas) in all other cars computer shows instant fuel consumption 0, but my 159 1.9JTDM always shows a minimum of 2.0 liters. Or do you also so that you have whether it is normal or something wrong?
› Więcej...: engine braking and fuel consumption 2.0 l/100 km
12-03-2011, 09:18 #2
12-03-2011, 09:30 #3
Alfa Brera 1.75 TBi 200 HP, 2009 January 2010 - October 2012
Alfa GT Distinctive 1.9 JTD 150 HP, 2005 August 2014 - ...
Alfa GT Quadrifoglio Verde 1.9 JTD 170 HP, 2008 October 2016 - ...
12-03-2011, 10:12 #4Bruce WillisA guest
12-03-2011, 21:08 #5The user Dwusuwowiec
- He joined the
- 03 2010
- Lives in
- Luban
- Auto
- AR 159 1,9 jtdm 175 km
- Posts
- 137
15-03-2011, 14:47 #6lukburyA guest
you're sure, "roasting" injectors, in my opinion, if the fuel is not (or would not be) supplied to the combustion chamber, it will not blow up and is replaced by kinetic energy and heat, as will not the temperature is below "pozapiekac" wtyrskiwacze in a situation when the furniture is a tributary of the fuel will be cut off? ..... but somehow now I still nasunelo myself... and how is the process of blocking and fixing this enginehuh? in my humble opinion, probably also through odciecia fuel to the cylinders... but I could be wrong:-)
15-03-2011, 20:13 #7The user Maniac resoraków
- He joined the
- 09 2010
- Lives in
- green Mountain
- Auto
- Alfa Romeo 159 1.9 JTDM 16 V Distinctive
- Posts
- 652
if you take your foot off the gas, the instantaneous fuel consumption is zero liters per 100 kilometers. In alfach on computerwith shown always 2 liters. Just as in other fiat models. Sometimes I have the opportunity to ride on the renault clio - where the computer shows after you take your foot off the gas, four horizontal lines
16-03-2011, 10:45 #8The user Quadrifoglio Verde
- He joined the
- 05 2007
- Lives in
- Warsaw, Poland
- Auto
- AR Stelvio 2.0 Turbo 280KM Veloce 2021
- Posts
- 8,623
Full off fuel after removing foot from gas, just above 3000obr/min, below those revs engineand the fuel is
Giulietta 1, 4 TB HAS Distinctive 2010
AR156 1.9 16v JTD M-jet 2004
AR156 1.6 TS 2000
Previously, 7 Italian cars F (126, 127, UNO DS, TIPO, PUNTO, BRAVA, MAREA)
16-03-2011, 10:48 #9
16-03-2011, 10:56 #10
Similar threads
[159] Fuel consumption BENZYNA
Created by dziodek in section 159/Brera/Brera SpiderResponse: 15Last post/author: 19-04-2019, 11:09 -
[159] engine braking and fuel consumption 2.0 l/100 km
Created by tojatajanka in section 159/Brera/Brera SpiderResponse: 14Last post/author: 17-02-2019, 20:34 -
Fuel consumption in the Parking lot - indications ICS
Created by motomycha in section 166Response: 7Last post/author: 11-04-2011, 06:51 -
the V6 engine braking?
Created by watra24 in the section 145/146/155Response: 10Last post/author: 08-06-2007, 21:04
