Show results from 1 to 10 with 12
Subject: What kind of light bulbs !!!
15-02-2009, 20:08 #1Bronx18A guest
I need to replace the bulb in the alfie 33 clearer, since the current poorly lit (almost yellow) if anyone can exchange and possibly on the what.
› Więcej...: What kind of light bulbs !!!
15-02-2009, 20:12 #2siwy144A guest
insert any Philips but before shoot new installations on przekaznikach
I did see 100-0001. jpg-original size-Fotosik.pl left normally installation original and right is bezprosredni with aku
16-02-2009, 10:01 #3Bronx18A guest
16-02-2009, 10:06 #4siwy144A guest
16-02-2009, 10:50 #5Bronx18A guest
16-02-2009, 11:22 #6
16-02-2009, 18:41 #7
If you have installations, the wymina zarówek does not help. In my opinion, worth it to look around somewhere for new headlights, because a minimum of 15 years are already probably in bad shape.
Once zanabylem the Allegro (with the logo of the AR) for $100, and the second Carello logo AR deliberately zfrezowanym for 50 PLN. Candle great on almost any zarowkach.
And how to add still installations on przekaznikach ... This Xenon hid will be with them bladly
16-02-2009, 18:52 #8siwy144A guest
16-02-2009, 18:58 #9
You did this inst. pull from the syndication switch or something simpler, for example. use the seed already in the Chamber engineand?
Although none of me an electrician, but already one "pretty" in its 33 I did on przekaznikach and I'm damn proud of myself, so pociagnalbym yet these headlights
But I'm afraid to bury these thin and fragile kabelkach in the cab.
16-02-2009, 19:11 #10siwy144A guest
Similar threads
[156] what lamp
Created by G9 in section 156Response: 32Last post/author: 20-10-2023, 10:17 -
What kind of lamp???
Created by bombel_pmr in section 156Response: 7Last post/author: 15-02-2014, 16:48 -
What bulbs??!
Created by Junka in section 156Response: 17Last post/author: 10-02-2013, 12:19 -
[155] what lamp
Created by NERO2287 in the section 145/146/155Response: 5Last post/author: 13-01-2010, 20:17 -
What kind of lamp ?
Created by KornelPL in section 156Response: 3Last post/author: 27-11-2009, 21:44
