Pokaż wyniki od 11 do 20 z 22
Temat: Uwaga ryzyko pożaru - akcja serwisowa UA4
    Użytkownik Pasjonat
    RZ
    Stelvio 2018 Sport TI
    no to przeczytaj jeszcze raz co napisałem- przecież konsekwencja wypadania zapłonu jest to co opisałem
    potwierdzam co [MENTION=34131]Dareek[/MENTION] napisał, update po to żeby nie przegrzewało kata + ewentualna naprawa jeśli już doszło do jakiś nadtopieńitp - cytat z dokumentu FCA do kampani UA4 (wklejałem w drugim wątku parę dni temu):
    The engine control software on about 34,300 of the above vehicles may contain
    inadequate catalytic converter overheat protection. Engine misfire conditions can
    lead to elevated catalytic converter temperatures. This may result in localized
    damage to wiring and components in the engine compartment near the catalyst. If
    certain engine compartment wiring or components are damaged, the customer may
    experience an engine stall resulting in a sudden loss of motive power, which can
    cause a vehicle crash without prior warning. In some cases, an engine Malfunction
    Indicator Lamp (“MIL”) may illuminate, the engine may operate roughly, there
    may be temporary loss of engine power, or a burning odor may be noticeable prior
    to an engine stall or engine compartment fire. An engine compartment fire may
    result in an increased risk of injury to motor vehicle occupants or persons outside
    the vehicle.
    Inspect the vehicle for Diagnostic Trouble Codes (DTCs) related to potential
    catalyst function. A scan report must be performed on all vehicles:
     If DTCs P0420, P0171, P2096, P2270 or P0299 are present, a STAR Case
    must be submitted including the scan report and then contact the STAR
    Center.
     If DTCs P0420, P0171, P2096, P2270 or P0299 are not present, update the
    PCM with the latest available software. It is not necessary to submit a STAR
    Case or contact the STAR Center.
    Dealers should attempt to minimize customer inconvenience by placing the owner
    in a loaner vehicle if inspection determines that the vehicle must be held overnight.
    natomiast kampania W05 to już tylko chodzi o chłodzenie turbiny:
    The Powertrain Control Module (PCM) software on about 57,000 of the above vehicles may not allow sufficient cooling time for the turbocharger oil feed. This condition can cause excessive thermal stress on the turbocharger oil feed line and over time develop into an oil weep.
    PS dodam komentarz realisty, żadna alfa nie spłonęła sama z siebie z tego co wiem, więc ten komentarz w opisie UA4 to taki dupochron na rynek amerykański więc też nie należy popadać w panikę IMHO. jak jest możliwość wgrać nowe firmwary żeby "spać spokojnie" (czyt. nie przypalać wiązek w okolicy kata)
    Użytkownik Maniak resoraków Avatar Firste
    Alfa Romeo Stelvio FE 280 KM
    Nowe wieści- akcja UA4 dotyczyła przeprogramowania sterownika silnika z uwagi na zbyt bogatą mieszkankę może dojść do nadmiernego nagrzewania katalizatora i w efekcie zbyt dużego nagrzania sąsiadujących z katalizatorem elementów co może być powozem pożaru.
    Czy w takim razie chipowane auta nie są na to narażone?
    Zwłaszcza te, których może z 280 KM podwyższają do 310-325?
    Użytkownik Pasjonat
    RZ
    powiem tak- patrząc jak ciasno umieszczony jest katalizator to naprawdę materiały w jego otoczeniu muszą być dobre. a co do czispowanych nie wypowiem się.
    Poznań
    ALFY
    zapłon wypada nie tylko z powodu zbyt bogatej mieszanki - więc to twierdzenie jest zbyt daleko posunięte
    Użytkownik Świeżak Avatar Styczek
    Giulia Ti RWD
    Czy ktoś kto ma auto z USA był już w serwisie i usunęli mu usterkę bezpłatnie?
    Moja Ti RWD jest z 2017, ale na stronie Mopara pokazuje mi 2 akcje:
    T57 - complete
    W05 - incomplete (co jest zrozumiałe, skoro akcja zaczęła się w marcu b.r., gdy auto było już rozbite).
    Użytkownik Rowerzysta Avatar woockush
    Giulia Q4ERTY
    Gwarancja oraz akcje serwisowe dla aut z rynku USA nie obowiązują w Europie.
    WL // GA
    Cytat Napisał ciafok Zobacz post
    rzypomnijmy - czymś co samochodem na pewno nie jest i nie ma prawa poruszać się po drogach publicznych)
    a wiesz że istnieje coś takiego jak rebuilt title?
  10. #20
    Alfa Romeo Giulia Veloce 2.0 TBi 280KM Q4 Imola Titanium
    Byłem dzisiaj na zmianie oleju w Giulii, pytałem o akcje serwisowe, ale dla mojej nie było żadnej.
  1. [Brera] Brera TBi - Wielka akcja serwisowa
    Utworzone przez Monkey96PL w dziale 159/Brera/Brera Spider
    Ostatni post / autor: 11-05-2020, 10:21
  2. Akcja serwisowa - hamulce
    Utworzone przez Imć w dziale Giulia/Stelvio
    Odpowiedzi: 14
    Ostatni post / autor: 11-01-2018, 12:40
  3. [Stelvio] Akcja serwisowa- lusterka.
    Utworzone przez Firste w dziale Giulia/Stelvio
    Ostatni post / autor: 30-10-2017, 14:57
  4. [Giulietta] Akcja serwisowa TCT
    Utworzone przez Lemolub w dziale MiTo/Giulietta
    Ostatni post / autor: 22-07-2015, 00:18
  5. zimowa akcja serwisowa 2011
    Utworzone przez mrq w dziale Forum ogólne o Alfa Romeo
    Ostatni post / autor: 24-11-2011, 16:39
