Sprężyny montuje się w tarczach sprzęgła do silników benzynowych nie wyposażonych w dwumas - przeważnie.
AR 156 2,4JTD 136KM '99 Blue Cosmo met.
Nissan Navara 4x4 D22 DoubleCab 2,5TD 103KM '01
Polcomtex.pl - usługi brukarskie
Nie, nie jestem.
PS. już jestem prawie pewien, że w środku znajdują się sprężyny:
http://e-autoparts.pl/kolo-dwumasowe-art-7.html
Ostatnio edytowane przez Lucas ; 13-06-2014 o 20:17
Tak mi się też wydawało. Pamiętam jak podziwiałem swoje zdemontowane![]()
na forum alfaowner znalazłem gościa który miał taki same objawy tylko że w dieslu i faktycznie był to dwumas
http://www.alfaowner.com/Forum/alfa-...ml#post2827759
http://www.alfaowner.com/Forum/alfa-...x-clunk-2.html
co najmniej dwóch userów wymieniało dwumas w 2.2 jtsMine is now clunking if i say lift off the gas in 2nd or 3rd below 30mph and the re-apply the gas.
The only time I have ever heard a sound like it ony previous car I owned it was a lose engine mounting but that then caused it to happen at any speed.
Once over 40mph it virtually disappears.
Hi, went in this morning. They did not want to book it in took them out for a test drive and they said they could not ear anything out of place.
Could be just that I am hearing the dual mass fly wheel slapping back.
I must admit after a 4 modern diesels before I have never heard a clunk but after seeing how one work it could be possible.
I suppose it could explain the cluck on changing up also.
Anyway a year of warranty remaining if it gets worse I will take it to another Alfa garage for a second opinion.
Can anyone recomend a good one for shropshire or west mids
Did Shrewsbury it was a case of carry on until it gets worse.
Spoken to a techy at guest willenhall as I wanted a 2nd opinion.
He said sounds the same as one they done last week. Dual mass fly wheel.
It was not the clunk in changing gear that was the problem but the delay and clunk when coming off power and reapplying power when the transmition had warmed up.
They sound really helpfull book in for 3 days for full diag on the problem.
I was relived to hear it was not right more than anything else. I was begining to feel fussy even though I knew it did not seem right.
Mines going in for what should be a Dual Mass Flywheel replacement next week for the same problem.
See if you can replicate it by taking your foot of the gas and putting it on again in say 2nd or 3rd at around 1500rpm.
Wait until next friday and I should have a answer on this, as that is when I pick my car up again.
OK picked it up tonight.
New DMF and Clutch (they said in the end the clutch did not need doing but one of the spings was begining to loosen so they did it.)
There is still a slight clunk going 2nd - 3rd so I think that can now be confirmed as a charecteristic. Also when you take your foot of the gas in say 2nd etc you will hear the flywheel slap back a tiny tiny bit (hardly audioable in standard driving)
But the play in the gear changes and easing of and reapplying the gas as gone. In the past it could only be described as a slight pause then it would engage (almost like really dropping the clutch at low speed)
So I still have a slight clunk which seems to be normal but gear changes are like a normal car not like a learner driver.
So I would say if it is a noise only it is OK. If you are getting a "shunt" on changing or when easing off and reapplying the gas your DMF is slacking/faulty.
But saying that I do not think the DMF was about to fail they do seem to be a bit noisier on the ALFA as on other disels I have never heared them.
But I can tell the difference, so I think it is a case of you are lucky if a dealer acknowledges it.
jeden podawał objawy
http://www.alfaowner.com/Forum/repub...-my-brera.htmlThe symptoms are a clunky knocking in the Engine, lots of vibration, and the odd kick from the clutch when changing gears
Ostatnio edytowane przez Alabaster ; 14-06-2014 o 10:31
U mnie dwumas potrafił dzwonić na zimnym silniku na biegu jałowym. Ponadto przy gaszeniu bez wciśniętego pedału sprzęgła słychać było charakterystyczne klepnięcie. Ale wymiana nie miała wpływu na "klikanie" po zmianie biegu, to prędzej jest przegub albo dyfer.
Weź auto na lewarek i kręć przednimi kołami w prawo i lewo - powinieneś wyczuć luz.
Dobrze pamiętam, pisałeś że zamówiłeś półosie po regeneracji. Wymieniłeś już?
zastanawiałem się nad kupnem kielichów przegubów wewnętrznych we włoszech, wychodzi około 1100 zł z przesyłką za obydwa
regenerowane półosie wyszłyby dwa razy drożej, bodajże 1025 zł za sztukę, nic narazie nie zrobiłem w tym kierunku, szukałem też używek ale pewnie wszystkie mają luz
narazie zamówiłem poduszki silnika i skrzyni bo taniej wychodzą niż te kielichy czy dwumas a może pomogą
stuki mi aż tak bardzo nie przeszkadzają tylko szarpnięcie przy puszczeniu i dodaniu gazu i "kangur"
szarpnięcie oczywiście jest leciutkie ale mnie przeszkadza
co do mechanizmu też miałem taką teorie nawet nagrałem filmik, ale SARAHZ mi pisał że po wymianie mechanizmu na nowy nie zauważył różnicy mimo że stary miał luzy
http://www.forum.alfaholicy.org/159_brera_brera_spider/110642-lozyska_skrzynia_m32-14.html#post1437011
Ostatnio edytowane przez Alabaster ; 14-06-2014 o 12:10
nagrałem te stuki/grzechotanie
przedtem pisałem że dźwięk jest tak cichy że słychać go tylko na kanale, jednak doopa, po prostu raz się pojawia raz nie, wydaje mi się że bardzo cichnie po wduszeniu sprzęgła ale będę musiał to jeszcze sprawdzić
Stawiam na dwumas, nie ma co się oszukiwać. Jak przy ruszaniu i zmianie biegów nie ma dudnienia, szarpania czy zwiększonych wibracji można powoli planować jego wymianę; jeśli doszły już jakieś dodatkowe wyraźne objawy to natychmiast do wymiany.
