Strona 2 z 7 PierwszyPierwszy 1234567 OstatniOstatni
Pokaż wyniki od 11 do 20 z 70
Temat: Uskok / przeskok przednich kół Stelvio
    Stelvio 2.0/200KM
    No to jak wszystkim stuka, jutro zaczynam z rana mojego katować - dopóki też nie usłyszę stukania...
    A tak na poważnie - może to faktycznie RFy albo 20-ki na żwirze - i ja nie mam tego, bo jeżdżę na porządnych balonach 17"?
    Gdańsk
    Stelvio First Edition
    W Stelvio z oponami 20’’ tez mam to zachowanie. Tak jak w tytule wątka, to jest przeskakiwanie a nie stukanie. Wydaje mi sie normalne. Zdarza sie glownie podczas manewrow w hali garazowej. Mam wrazenie ze wynika to z 4x4
    Mito 1.4TB 155, Giulia 2.0TB 200 Super
    Cytat ponoć z fabrycznej dokumentacji:
    Steering - Ackermann angle
    The particular type of front suspension adopted for the Giulia (Alfa[emoji769] Link) has been studied and developed to obtain the best dynamic performance in every driving condition. In particular, the quadrilateral arrangement with a semi-virtual steering axis with double wishbone allows variation of the Ackermann angle with the variation of the steering angle. The Ackermann angle is given by a different steering angle between the internal and the external wheel. This characteristic, which is normally reserved for the most prestigious sports cars, has been fine-tuned to guarantee the lowest possible understeer in any driving condition and thus allow the Giulia better dynamic driving with greater safety and driving pleasure.
    In particular driving conditions, with fully steered wheels it is nonetheless possible for a slight dragging of the internal wheel to be generated, which may be perceived as skipping of the tyre accompanied by noise.
    This ohenomenon, called chattering, is influenced by the following parameters:
    Characteristics and temperature of the road surface
    Type of tyres
    Tyre pressure
    Steering angle
    Speed of manoeuvre
    The noise that is noticed in the driving condition described above is therefore determined by the parameters listed above and must NOT be considered an anomaly or a fault of the vehicle. This phenomenon is inherent only to specific design choices intended to pursue the maximum result in terms of vehicle safety. lt does not in any way influence the dynamic safety nor even the deterioration of the tyres or of any other mechanical component.
    Stelvio 2.0/200KM
    Ostatnio edytowane przez ciafok ; 04-08-2018 o 08:10
    Stelvio 2.0/200KM
    Bardzo ciekawe. Czyli można to u siebie mieć - i to nie defekt, albo można tego u siebie nie mieć.
    Tym niemniej, pobawię się Stelviuszem i poobserwuję - z ciekawości.
    Rzeczywiście wygląda na "feature":
    https://www.giuliaforums.com/forum/7...html#post93593
    Ostatnio edytowane przez ciafok ; 04-08-2018 o 08:09
    Użytkownik Rowerzysta Avatar sebol75
    Alfa Romeo Giulia Veloce, 159JTDm150@192/405, 147JTD
    Na dużych balonach może to być nie wyczuwalne bo się opona wygina, na niskim profilu lub rf bok opony jest na tyle sztywny ze opona zsuwa się po nawierzchni - normalna rzecz nie ma o czym dyskutować
    To nie jest wada tylko fizyka
    U mnie na kostce na 17 przy skręcie na parkingu czasem jest. Mam rwd
    Nie alfa
    Z tego co wiem (mogę się mylić) stelvio jak i giulia ma inaczej zrobione zawieszenie jak większość aut. W tych autach koła przy skręcie są płasko do podłoża anie przechylone co daje jak największą styczność opony z asfaltem. Może właśnie ten feature powoduje przeskok opon
    było 159 SW 08, 2.4 Jtdm, jest Giulietta 1.4 MA 170 km
    Miałem tak w 159 na oponach 235. Podobno przy wielowahaczowym zawieszeniu i szerokich gumach to norma
  10. #20
    Użytkownik Rowerzysta Avatar Haveblue
    Lublin
    Maserati Ghibli SQ4
    Identycznie jest w Maserati SQ4.
    wcześniej:
    YUGO 65 1.3 (ZASTAVA) '86 - 1994-1997
    AR 146 1,4 boxer '97 - 1997-1999
    AR 156 2,0 TS '98 - 2000-2001
    AR 156 2,5 V6 '99 - 2001-2004
    AR 156 GTA '03 - 2006-2009
    AR 159 3,2V6 Q4 ti '07 - 2009-2014
    teraz:
    Honda CRV (służbowa)
    Maserati Ghibli SQ4 '15
  1. [Stelvio] Opinie użytkowników o Stelvio
    Utworzone przez Firste w dziale Giulia/Stelvio
    Odpowiedzi: 1105
    Ostatni post / autor: 23-03-2022, 19:40
  2. [1.8 TS] słabsza moc... czy to przeskok paska rozrządu...?
    Utworzone przez ziulek61 w dziale 156
    Odpowiedzi: 39
    Ostatni post / autor: 04-12-2012, 09:46
  3. Dziwny przeskok w sprzęgle
    Utworzone przez marcin1234 w dziale 147
    Ostatni post / autor: 12-10-2009, 09:18
  4. [146] Pasek wielorowkowy, a przeskok iskry.
    Utworzone przez dencior w dziale 145/146/155
    Ostatni post / autor: 20-10-2008, 19:46
