How to do it ?
First download and print the documents.Then:
The pin no.5 on the green 26pin connector must be connected to the ground (ICS chassis) to switch the ICS to TV mode.
Everything you need to do then is to take some SCART to SCART video cable,dissasembly one SCART connector and solder pins on the requested wires (just see the documents). It`s necessary to connect ground signals for red, green and blue to one wire and then to pin 3 on the black connector. Next important wire is wire 20 on scart connector (composite video in), it must be connected to pin no.17 on ICS black connector (to sync the picture). Then just connect other wires for red, green, blue and audio and it`s done.
Be sure to have regular RGB/Scart output on your DVD player, DVD with composite video out with simple reduction to SCART will not work ! Or use some converter.
Green connector pin to Scart pin
5 to switch GND for TV
23 to 3
24 to 4
Black connector pin to Scart pin
3 to 5, 9, 13
4 to 15
5 to 11
17 to 19
18 to 7
Power for player you can get from lighter or ICS euro power connector
GND for switch I got from ICS housing.
