Strona 59 z 59 PierwszyPierwszy ... 94950515253545556575859
Pokaż wyniki od 581 do 582 z 582
Temat: Typy przepływomierzy/wkładek
  1. #581
    Użytkownik Świeżak Avatar kotlin
    Alfa Romeo 156 SW 1.9 JTD 8V 2002r
    Z góry przepraszam za odkop, ale czy któryś z użytkowników posiada może programik udostępniony przez kolegę @sdero w poście #556 (https://www.forum.alfaholicy.org/147...ml#post2055145). Na serwerze nie jest już niestety dostępny a nie mogę ogarnąć wzoru, który podawał w #555.
    Edit:
    Znalazłem na forum MES taką informację:
    "When reading data from the ECU, the mass air flow is not reported in kg per hour but in mg per stroke. Converting one value to the other is quite simple:
    At 900 RPM a 4 cilinder 4 stroke engine makes 900 RPM * 2 strokes/revolution * 60 minutes in one hour = 108,000 strokes. So if the ECU reads 480 mg/stroke at idle, it equals to 108,000 * 480e-6 = 52 kg/hour air flow. 480 mg/stroke is the value you should read with a 1.9L engine during idle when the EGR is closed. One full cilinder filling is 0.48 liter. Air is about 1290 mg per liter. So one could calculate 0.48 * 1290 = 619 mg/stroke. However, the cilinder is not fully filled as it has to suck in the air in a limited amount of time. Therefore the value is a little lower. (If the turbo would be really working at idle, the air flow could be higher than 619 mg/stroke.) The output voltage of a Pierburg MAF during idle and closed EGR is about 1.6V. A Bosch MAF reads about 2.2V in this situation. With a closed EGR you should measure about 480mg/stroke. With a 78% opened EGR you should read about 290 mg/stroke. If the values you find are much lower, something is blocking the air flow or the MAF has gone bad. The air flow can be blocked by a clogged air filter, a clogged intercooler, a (partly) closed anti shudder valve, a clogged intake manifold or bad valves. The intake manifold may clog due to soot/oil as exhaust fumes are fed back into the engine by the EGR and oil is fed into the engine by the CCV. It's also possible that the EGR is stuck open."
    Wykonując przeliczenia wg powyższego wzoru masa zmierzona na wolnych obrotach wychodzi mi większa od oczekiwanej, co zgadzałoby sie z faktem że egr jest zaślepiony.
    Ostatnio edytowane przez kotlin ; 21-09-2022 o 18:30
    Alfa Romeo 156 2001, 1.9 JTD 115@150 KM - była
    Subaru Legacy 2008 2.0 NA - było
    Jeep WJ 2003 4,7 235 KM - był
    Alfa Romeo 156 2002, 1.9 JTD 115 KM - jest
  2. #582
    Fiat Stilo 1.9 JTD 8v 115KM
    Da się jeszcze gdzieś dostać przepływomierz z wkładką F 00C 2G2 044 lub F 00C 2G2 030 za poniżej 300zł?
    Ewentualnie czy ten F 00C 2G8 338 też będzie dobry? Potrzebuję do Stilo 1.9 JTD 115KM
    Ostatnio edytowane przez Dale ; 28-07-2024 o 23:36
    Lepiej być młodym i biednym, niż bogatym i starym.
  1. Wykresy pracy i parametry przepływomierzy
    Utworzone przez Majkel w dziale 147/156/166/GT
    Odpowiedzi: 45
    Ostatni post / autor: 17-09-2022, 06:44
  2. [159] Różnica przepływomierzy 2,4 JTD
    Utworzone przez Smori91 w dziale 159/Brera/Brera Spider
    Ostatni post / autor: 16-02-2015, 17:02
  3. [145] Wymiana wkładek
    Utworzone przez ADI_BoXER w dziale 145/146/155
    Ostatni post / autor: 01-07-2014, 08:30
  4. Typy przepływomierzy/wkładek
    Utworzone przez ap2 w dziale 166
    Odpowiedzi: 76
    Ostatni post / autor: 25-10-2012, 22:26
  5. [155] Rodzaje przepływomierzy 2.0 TS
    Utworzone przez Dawid2605 w dziale 145/146/155
    Odpowiedzi: 16
    Ostatni post / autor: 17-06-2010, 19:59
