Pokaż wyniki od 1 do 2 z 2
Temat: (Power Train Contol) Post Flash Reprogramming Procedures, do czego jest ta procedura
    Użytkownik Romeo Avatar euroscan
    Katy Wroclawskie/ Wrocław/ Legnica
    147 TS 1.6, bez wariatora
    Domyślnie (Power Train Contol) Post Flash Reprogramming Procedures, do czego jest ta procedura
    2013 PF (Dart) PCM (Power Train Contol Module) Post Flash Reprogramming Procedures Article ID: 322 Last updated: 04 Nov, 2013 VEHICLE: * 2013 - 2014 PF (Dart) 1.4L Turbo ECU: * 8GMW PCM * 8GMK PCM ISSUE: * Certain procedures must be performed on an 8GMW and 8GMK PCM for PF 1.4L after flash reprogramming update or PCM replacement. PROCEDURES: Transmission Learn Manual Transmission Vehicle: 1. Depress the clutch fully and release, cycle ignition OFF for 10 seconds, then cycle ignition ON. 2. The "P1302 - Transmission Self Learning" DTC will become a stored fault. 3. Once the "P1302 - Transmission Self Learning" DTC is stored, you may clear the fault by selecting Clear All DTCs in the wiTECH application. Automatic Transmission Vehicle: 1. The Transmission Self Learning happens at first key ON after flash reprogramming and the "P1302 – Transmission Self Learning" DTC will be a stored fault. 2. Once the "P1302 - Transmission Self Learning" DTC has become stored, you may clear the fault by selecting Clear All DTCs in the wiTECH application. Cruise Control Learn 1. Press and release the cruise control ON/OFF button on the steering wheel until the cruise indicator illuminates on the instrument panel. TLC Relearn Once the PCM has been flash reprogrammed for an update or PCM replacement a Target Linear Coefficient (TLC) relearn process must be completed as follows: 1. Sart engine with no DTCs and let it run until coolant temp reaches 60°C (140°F). 2. After reaching 60°C, sharply press and release the throttle pedal to obtain an RPM of greater than 6,000 RPMs. * This procedure must be performed to allow PCM to monitor cylinder misfires.
    ktoś się orientuje w jakim przypadku robimy tę procedurę ? link: http://kb.dcctools.com/index.php?View=entry&EntryID=322
    mazowieckie
    Giulietta 1.4 MA
    Cytat Napisał euroscan Zobacz post
    Przecież masz tam jak byk napisane, że to procedura po wymianie ECU lub flashowaniu oprogramowania ECU.
    To inicjacja podstawowych czujników napędu zależnych od użytkownika - sprawdzenie poprawności działania czujnika sprzegła lub inicjacja sterowania skrzyni w przypadku TCT.
  1. Do czego jest ta rurka?
    Utworzone przez turek77 w dziale 147
    Ostatni post / autor: 03-10-2012, 15:06
  2. Od czego jest ta wtyczka ?
    Utworzone przez FifthGear w dziale 166
    Ostatni post / autor: 23-09-2012, 10:47
  3. 156 FL - od czego jest ta kostka?
    Utworzone przez Czarnecki w dziale 156
    Ostatni post / autor: 01-07-2012, 07:41
  4. Od czego to jest?
    Utworzone przez fackamaka w dziale 166
    Ostatni post / autor: 31-03-2012, 09:24
  5. Co to jest i do czego służy ? ;)
    Utworzone przez mike w dziale 147
    Ostatni post / autor: 08-09-2011, 18:39
