Pokaż wyniki od 1 do 4 z 4
Temat: Strange connector
    166 2.4 Mjet 2005
    Domyślnie Strange connector
    Hello everyone, in the battery compartment I found this connector not connected to any device .... what is it for?
    If you need more photos to understand better, no problem.
    Thanks as always for the collaboration
Nazwa:	20180421_155053.jpg
Rozmiar:	55.9 KB
    166 2.4 Mjet 2005
    Another photo ..... if it can help !!
Nazwa:	20180422_153626.jpg
Rozmiar:	38.0 KB
    Bełchatów
    Hello.
    My english is very bad, so you must forgive me. I understand, but i can not write.
    Thats connector on your photo should by connected in to the SCB module on the fuses plate on the acu in luggage compartment. I show you in to picture below. If Inertia switch I50 is activated, then SCB module is connected in to ground and the Voltage on some module in car i broken.
Nazwa:	scb.jpg
Rozmiar:	75.5 KB
ID:	244413Kliknij obrazek, aby uzyskać większą wersję
Nazwa:	ustrojstwo.jpg
Rozmiar:	145.0 KB
    Pin 30 of A20 , the actual starter motor, is supplied with voltage directly from the battery via terminal unit A5 . this supply is interrupted by the SCB device for MAXIFUSE box B99 if the inertia switch I50 is operated.
    http://chomikuj.pl/danus77
    166 2.4 Mjet 2005
    Thank you so much Danus, but you were very clear in the explanation , then the photos, sometimes much better than a thousand words.
    Now finally I understand perfectly the operation ..... unfortunately, however, on my fuse plate is not present the SBC module, that's why the connector is disconnected!!
