Pokaż wyniki od 1 do 3 z 3
Temat: Fiatmultiecuscan
    Alfa Romeo 147 1.9jtdm 16v 150km 2008
    Domyślnie Fiatmultiecuscan
    Czy multiecuscan bedzie działał na kablu od delphiego? Jesli nie, jakie potrzebuje kupic kable/kabel zeby obsłuzyc w pełni alfe 147 2008r. bo czytałem ze jeden nie wystarczy?
    ALFA ROMEO 166
    [lang=en]I use MultiEcuScan diagnostics with ELM interface and KKL interface it has a module selection switch on it.
    Adapters are required for the ELM interface so that it can be connected to different modules.
    • KL - KKL/VagCom/OBDKey interface
    • ELM - ELM 327 v1.3+/OBDLink/OBDKey interface
    • A1 - ADAPTER CABLE 1 (green)
    • A2 - ADAPTER CABLE 2 (row)
    • A3 - ADAPTER CABLE 3 (yellow)
    • A4 - ADAPTER CABLE 4 (purple)
    • A5 - ADAPTER CABLE 5 (blue)
    • A6 - ADAPTER CABLE 6 (gray)
    • 3-Pin - 3-PIN ADAPTER CABLE
    • P1 - Pin 1 (for interfaces with pin switch)
    • P3 - Pin 3 (for interfaces with pin switch)
    • P9 - Pin 9 (for interfaces with pin switch)
    • P12 - Pin 12 (for interfaces with pin switch)
    • P13 - Pin 13 (for interfaces with pin switch)
    List of modules to be connected and which interfaces are required.
    • Bosch EDC15C7 CF3/EOBD Diesel Injection (1.9 8V, 2.4 10V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM
    • Bosch EDC16 CF3/EOBD Diesel Injection (1.9 16V, 2.4 20V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM
    • Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9 16V, 2.4 20V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM
    • Bosch ABS 5.7 |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
    • Bosch ABS 5.7 ASR/TC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
    • Bosch ABS 5.7 VDC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
    • Bosch ABS 8 |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
    • Bosch ABS 8 ASR |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
    • Bosch ABS 8 VDC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM A1 P1
    • Allied Airbag MY97 |INFO|DTC|PRM| KL A2 P3
    • Siemens Airbag MY99 |INFO|DTC|PRM|ACT| KL A2 P3
    • Service Interval Reset |INFO|ADJ| ELM
    • Connect (NAV) Marelli |INFO|DTC|PRM|ACT| ELM
    • Convergence Marelli/Microsoft (Blue&Me) |INFO|DTC| ELM
    • Convergence Marelli/Microsoft C3 (Blue&Me Nav) |INFO|DTC| ELM
    • Instrument Panel Mannesman VDO |INFO|DTC|PRM|ACT|ADJ| ELM
    • Body Computer Marelli (937) |INFO|DTC|PRM|ACT|ADJ| ELM
    • CAN Info |INFO| ELM
    • CAN Monitor / Vehicle Settings |DTC|PRM|ADJ|
    • CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELM
    • Delphi climate control (Dual zone) |INFO|DTC|PRM|ACT| ELM
    • Delphi climate control (Single zone) |INFO|DTC|PRM|ACT| ELM
    • Bosch XENON headlamp (left) |INFO|DTC|PRM|ACT|ADJ| KL ELM A1 P12
    • Bosch XENON headlamp (right) |INFO|DTC|PRM| KL ELM A1 P12
    • Valeo XENON headlamp (left) |INFO|DTC|PRM|ACT|ADJ| KL ELM A1 P12
    • Valeo XENON headlamp (right) |INFO|DTC|PRM|ACT|ADJ| KL ELM A1 P12
    • Boot/Rear Doors TRW |INFO|DTC|PRM|ACT| ELM
    • Driver's Door TRW |INFO|DTC|DTC EX|PRM|ACT| ELM
    • Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9 16V, 2.4 20V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM[/lang]
    pomorskie
    Giulietta 1.4 MA Distictive Sport+Premium
    Czy ktoś ma multiecuscan na Windows XP?
