Show results from 1 to 4 with 4
Subject: the problem with the clutch
03-01-2009, 14:41 #1BRONKOA guest
Hello, want. Poznan is not klania I Alfe GTV ZAPADL I PEDAL FROM SPRZEGŁA PEDAL FROM CLUTCH HANGING STEEL CABLE was IN SERVICE AND they will NOT be ABLE to HELP ME, PLEASE PDANIE NAME OR PART THAT CAN BE DAMAGED
› Więcej...: the problem with the clutch
04-01-2009, 20:15 #2The user Beginner
- He joined the
- 09 2007
- Lives in
- Wroclaw
- Auto
- 166 2.4 jtd spider 3,2v6
- Posts
- 217
05-01-2009, 23:09 #3The user Maniac resoraków
- He joined the
- 03 2008
- Lives in
- Savina,KRK
- Auto
- GTV 2.0 16V T. S., 1.9 JTD Gt
- Posts
- 48
I had so a few times the first time not crumbled grip 2gim wysprzeglik 3 strip
after replacing all these parts you got
and nieswieciła you do not earlier, sometimes light is from manual?
09-01-2009, 23:51 #4metiudasA guest
me how fell the clutch pedal to the floor, it turned out that Bush rubber-metal bearing, connecting the clutch pedal with silownikiem I contacted and wypadla the cotter pin, which is not the pedal.strange, how I dojezdza to the intersection and gets naked on the floor.the service said that net not, and you can exchange gas and a lot of it the cost of theowalo, so I did it my way
Similar threads
[146] the problem with the clutch
Created by tomas200 in the section 145/146/155Response: 1Last post/author: 02-08-2015, 21:34 -
Created by soplu123 in section 156Response: 8Last post/author: 14-06-2013, 18:23 -
[164] The problem with the clutch ;/
Created by Devil4833 in the section 33/164Response: 7Last post/author: 05-06-2013, 20:10 -
The problem with the clutch...??
Created by gotlibus in the section of the General Forum of the Alfa RomeoResponse: 8Last post/author: 18-03-2013, 22:23 -
Created by kamoo22 in section 147Response: 11Last post/author: 24-11-2010, 09:40
