Show results from 1 to 10 with 10
Subject: ABS Error C1360 and C1522
29-06-2011, 07:30 #1
Hello, yesterday driving drove into a small pit and burned light is ABS. When connecting with a computer, I read two mistakes:
-C1360 sensor care? The bug was active.
-C1522 This error, the description says that it concerns the connection of ABS. Were only remember.
Where to find this sensor yaw? What can you do?
› Więcej...: ABS Error C1360 and C1522
29-06-2011, 12:23 #2The user Quadrifoglio Verde
- He joined the
- 09 2007
- Lives in
- Wrocław
- Auto
- G 1.4 is 170CV ECU Nexus 8GMF
- Posts
- 6,112
-AR 156 TS 2.0 ecu M 1.5.5
-147 1.6 16v 105CV ecu ME 7.3.1.
29-06-2011, 13:39 #3
29-06-2011, 17:46 #4
30-06-2011, 16:28 #5
Sensor said "bye-bye" error is returned prześwietliłem all communications all right... now the question is: can I apply with a 156 or 166 such a sensor?
30-06-2011, 17:11 #6The user Quadrifoglio Verde
- He joined the
- 09 2007
- Lives in
- Wrocław
- Auto
- Posts
- 6,112
02-07-2011, 16:02 #7
23-05-2012, 09:13 #8
25-09-2012, 20:38 #9
Hello, to refresh a bit the topic, I have c1522 in error as I show more and c1200 c1205 sensor right and left, posting error.. can someone send the link, what does it look like, if to take for a replacement?
what the cost of they buy?Last edited by wisniashi ; 25-09-2012 about 20:42
04-12-2012, 18:26 #10
I'm in my GT 3.2 dopASOthe shaft from the STILO.The rooms are the same BOSCH 0 265 005 241 so that "no problem". The cost of the 80 forwarding on alledrogo. FES displays an error C1360-YAW SENSOR.
I have the same replacement is not enough. Immediately after the block and clear the error came back. Only when the signal level all you can, and clear the error sensor took. Or is it a normal procedure or just the first vent/run failed. As long as everything works smoothly.
Similar threads
1.9 16V Errors
Created by Keeperek in section 156Response: 18Last post/author: 17-11-2018, 18:21 -
Error ABS C1522
Created by misiekmnz in section 147Response: 2Last post/author: 15-09-2015, 17:36 -
What is this error ?
Created by Flaku2012 in section 156Response: 2Last post/author: 24-01-2015, 21:12 -
[146] What's wrong? Encoding error codes when connected to a computer ?? 4 BUGS
Created by grzechu220 in the section 145/146/155Response: 2Last post/author: 07-10-2013, 18:52 -
Errors ABS alfa 147 1.6 2001 c1506 c1210 c1522
Created by CARENZO in section 147Response: 7Last post/author: 26-11-2012, 21:25
