Show results from 1 to 4 with 4
    Fury
    A guest
    Domyślnie [156] Disassembly of the rear seat
    Hello
    NIesty utknołem after odkreceniu 2 Allen screws (6 mm) down the couch moves up/down but not desperately wants to get out and let something pluck
    Anyone can tamper with already this problem?
    › Więcej...: [156] Disassembly of the rear seat
    Fury
    A guest
    Partly the problem solved right jumped out of the clip but the left is probably wykrece inches mounting because even accidentally drgnac
    The user Cyclist Avatar DzIdEx7
    He joined the
    09 2007
    Lives in
    Jastrzebie Zdroj
    Alfa Romeo GT 2.0 JTS
    Posts
    97
    Upcycle this yesterday It looks like this: If odkręciłeś these ibusowe 2 screws now slide Paw between the lower and the upper part of the bench and the best knee push to the Max to the rear of the car and tug at the pull up you go out with the ball. Best you will understand how it is mounted after the first part of the that you already went. This can not be the end of put into words but a simple wire is accosted by a sort of hook you lot pomanewrować with your fingers and a little strength
    Thank you !
    Was ----> 156 1.6 16V
    ----> SW 159 2.4 Q-tronic TI
    It ----> gt 2.0 JTS
    Jest ——> Giulietta 1.4 MA
    Fury
    A guest
    Didn't:-) but now odkrecilem 2 bolts that przytrzymywały these hooks but back at the top holds quite firmly, and again utknolem.
    Maybe someone already demontował back child seats in sedan?
Similar threads
  1. [159] Rear seat cushion
    Created by Myszkin in section 159/Brera/Brera Spider
    Response: 125
    Last post/author: 04-03-2022, 21:37
  2. Disassembly of the rear seat
    Created by bartol44 in section 166
    Response: 4
    Last post/author: 07-04-2013, 15:19
  3. Disassembly of the rear seat
    Created by kubicze in section 166
    Response: 6
    Last post/author: 03-12-2011, 22:25
  4. Replacing the rear seat: / ...
    Created by groszek in section 156
    Response: 14
    Last post/author: 08-11-2010, 21:43
dismantling the sofa alfa166
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
