Page 1 with 13 1234567891011 ... LastLast
Show results from 1 to 10 with 126
    The user Cyclist Avatar Myszkin
    He joined the
    01 2010
    Lives in
    Warsaw, Poland
    służbowe
    Posts
    418
    Domyślnie Rear seat cushion
    Hello
    I plan to wear a suit (tailor-made) to my 159 - I wonder if the seat of the rear seat can be raised somehow? There is no problem with the folding of the backrest, but I can not find the bottom of the seat for the bottom of the seat (it is necessary to fit the seat) - does anyone have an idea?
    The instruction on this subject is silent.
    Thanks in advance !
    › Więcej...: Rear seat cushion
    "Alfa Romeo has everything he needs: a lot of emotionally disposed fans ..."
    "From a brand like Alfa Romeo, we expect refined details that turn ordinary car driving into celebration of control of the machine."
    The user Expert Avatar Kali_33
    He joined the
    10 2008
    Lives in
    Warsaw, Poland
    GTV 2.0TS 1997
    Posts
    1,526
    Quotation Wrote Myszkin Zobacz post
    Hello
    Thanks in advance !
    Under the sofa in her front part of the There are 3 plastic latches, you have to push your fingers to squeeze to release the hook and pull the seat lightly up. If you've already jerked off the couch, you probably broke them so the latches might lock up. As you raise the front you have to push the couch back and then release the rear hooks.
    The user Fachowiec
    He joined the
    12 2008
    Lives in
    pinewood
    Posts
    2,093
    And can you know what made you decide at all to cover the covers? What upholstery?
    VIP Maniac resoraków Avatar Mariusz AutoDS
    He joined the
    09 2009
    Lives in
    Minsk Maz.
    147 1.9, 159 SW 2.4, Fiat x1 / 9
    Posts
    884
    Covers? Have you rubbed a hole or a sting can not be removed that you are planning so desperate act ..?
    Regards, Mariusz / AutoDS Team Poland / Alfa 147 1.9 JTD GTA-look, Alfa 159 SW 2,4 JTDm, Fiat X1 / 9
    He joined the
    10 2008
    Lives in
    Warsaw, Poland
    GTV 2.0TS 1997
    Posts
    1,526
    Quotation Wrote Mariusz AutoDS Zobacz post
    Better coverings than pedal lights
    The user Fachowiec
    He joined the
    12 2008
    Lives in
    pinewood
    Posts
    2,093
    Diodes can and do not, but the pedals are illuminated in new cars, and in fact leg room, both driver and passenger. I do not see anything in this stuff.
    He joined the
    10 2008
    Lives in
    Warsaw, Poland
    GTV 2.0TS 1997
    Posts
    1,526
    Quotation Wrote coachu Zobacz post
    If not in violet it's a fact, it can survive
    The user Fachowiec
    He joined the
    12 2008
    Lives in
    pinewood
    Posts
    2,093
    As for me, this is a cool bajer, of course not in the violet but the covers definitely fall off.
    The user The pirate way Avatar sebsob
    He joined the
    08 2010
    Lives in
    DW
    Is: Lancia Ypsilon 1.2 16V, Ford S-Max 2.0 TDCi, was: Alfa Romeo 159 SW 2.4 JTDm
    Posts
    292
    As if you had a dog, which you often bring car often enough to change your mind quickly.
    Simply the practice / convenience of everyday life sometimes wins with aesthetic sophistication.
    The user Romeo Avatar grzdylu
    He joined the
    04 2011
    Lives in
    Warsaw, Poland
    GTV 3.0 V6
    Posts
    1,381
    You have to buy SW and dog in the trunk And not the poor will tire on the couch.
    Born to be wild.
Similar threads
  1. Disassembly of the rear seat
    Created by bartol44 in section 166
    Response: 4
    Last post/author: 07-04-2013, 15:19
  2. Disassembly of the rear seat
    Created by kubicze in section 166
    Response: 6
    Last post/author: 03-12-2011, 22:25
  3. Replacing the rear seat: / ...
    Created by groszek in section 156
    Response: 14
    Last post/author: 08-11-2010, 21:43
  4. [156] Disassembly of the rear seat
    Created by Fury in section 156
    Response: 3
    Last post/author: 08-04-2008, 09:46
How to dismantle the back alpha 159
Rear alfa 159
Seat leon ii and how to put the couch
Alfa 159 demontaz rear couch
How to raise the rear alfa 159 seat
opel astra3 jak zamontowac tylna kanape
Smontare sedile posteriore alfa 159
How to remove alpha 159
Smontaggio sedile posteriore alfa 159
Come smontare sedile posteriore alfa 159
Dismantling rear seat astra 3
sgancio sedile posteriore alfa 159
Smontaggio sedili posteriori alfa 159
Come smontare and sedili posteriori alfa 159
sk
Alpha romeo 159 dismantle
Pull out rear seat 156
Alpha 159 how to remove the back couch
Leon 2 dimensions of the couch
SPINKA ZACZEP ZATRZASK SIEDZISKA KANAPY audi
come si alzano i sedili posteriori alfa 159 sw
Dismantling the rear seat 159
Folding alfa 159 seats
Alfa 159 couch
How to remove the rear canal in ALFA ROMEO 159
Alfa 159 smontaggio sedile posteriore
mounting
fermi sedile posteriore alfa 159
Seat leon 2005 or rear seat is folded
Alpha romeo 159 sw folding rear seat
Youtube come smontare cuscino posteriore alfa 159
Alfa 159 clips of the couch
Smontare sedili posteriori alfa 159
Smontare sedili alfa 159
Sedili posteriori alfa 159
sedili posteriori alfa romeo sportwagon
demontaz tylnego oparcia w oplu astra j sedan
achterbank verwijderen alfa 159
How to download alpha 159
Come smontare sedili posteriori alfa 159
Come smontare and sedili posteriori alfa 159 sw
Smontare la poltrona posteriore alfa 159 sw
vyjmuti zadnich sedacek alfa 159
Marrone Luci Di Bosco 2007 159
alfa 159 siedzisko kanapy
How to remove the back seat of alfa 147 forum
Lifting alfa couch 159
rabattre siege arriere alfa 159alfa romeo 159 zdjecie kabapy tylnej
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
