Show results from 1 to 8 with 8
    The user Cyclist
    He joined the
    04 2010
    Lives in
    krzepice
    166 2.5 v6 2000
    Posts
    71
    Domyślnie Fuel consumption in the Parking lot - indications ICS
    hi..today took the battery to charge. then, when I put one in it and I'm looking at ics and after 300metrow on cpn spojrzalem on the flow rate of fuel and at idle stilo non-stop rated is growing ..
    after 10 minutes roslo and adds the value on the display has reached 48litrów ... then choked engine and I went home to write a post..what to do I don't know yet...
    › Więcej...: Fuel consumption in the Parking lot - indications ICS
    piter1984
    A guest
    better not to write anything... albonajpierwzacznij pisaćspójnie...
    PS. what do you expect to engine there were even in the Parking lot for free ? this is not an electrician. you have a burning served at 100km, so it does not burn going and growing... sometimes a song written in the Parking lot on the value of hourly and often it is more than 2l/h
    The user Cyclist
    He joined the
    04 2010
    Lives in
    krzepice
    166 2.5 v6 2000
    Posts
    71
    Domyślnie well, 48litrów
    well, 48 liters? I wrote a post with one finger because I umorusane hands and irritation with hot head ordered me immediately to describe the problem you're seeing, so don't czepiajcie..piter 1984, but rightly noted that it could be a intake expressed in other dimensions ..but on the display as before..nothing has changed..
    for me, on the screen, in the Parking lot burning should vary between 1.8 and 2.9 liters per 100..and takbyło yesterday, and today I value on the display is constantly growing and engine has 800obrotów for a minute..engine 2.5 v6, not sure if it will affect the fuel consumption..for protection I filled the tank under the tube, because tomorrow I will not have time to grzebnięcie..only on Monday..
    The user Romeo Avatar yoozef
    He joined the
    04 2009
    Lives in
    Warsaw / Płock
    Was: Alfa Romeo 166 v6 3.0 Super '98
    Posts
    1,098
    Omg, motomycha what action, after all computer shows the fuel consumption of liters of fuel on 100 km of run. As you don't go, it's not you're joking kilometers, and gasoline burns, right? That is, the fuel consumption increases. In the Parking lot the fuel consumption tends to infinity. Just.
    To make it even easier to draw - as you stand on the spot, how much time you will need to travel 100km? And how much did you sleep during this tour?
    As zresetowałeś a computer is all you wyzerowało and now just very spectacular it looks. Do a couple of km and then look at the readings.
    The user Expert Avatar Dawid_Zielu
    He joined the
    08 2010
    FL Alfa Romeo 166 2,4 JTD 20V Sportronic '03
    Posts
    1,277
    run mate, at least 20 km is incineration should You start to fall.
    Alfa Romeo - "without heart we would be only machines"
    The user Stallion Avatar kaczo
    He joined the
    02 2010
    Lives in
    New On End / Krakow
    was a 1.8 156 Ts 166 V6 2.5
    Posts
    198
    full standard... me in the same enginethe burning grows, so do not have what to worry... be able to ride the moments and the memory is constant combustion on the website is not normal :]
    what Miscavige??????? :-/
    The user Fachowiec Avatar QBA
    He joined the
    03 2007
    Lives in
    Czestochowa
    Posts
    2,633
    A colleague made a mistake, burning in average short-term of which in 166 ni has (at least in my)
    http://www.flar-ital.pl/ - SPARE PARTS - SERVICE: Lancia, Fiat, Alfa Romeo
    AUTHORIZATION SERVICES - ROAD ASSISTANCE
    The user Romeo Avatar żuwik
    He joined the
    07 2010
    Lives in
    Bielsko-Biala
    166 2,4 JTD CF2 '00 ` ` ` ` ` ` ` ` ` 166 3,0 CF3 V6 '03
    Posts
    925
    If you drove 300 km, and then 10 minutes of standing, we now imagine that the same style will move 100km - after 300 meters, Parking and 10 minutes. 100% will leave You with this drive 48l/100km or even more.
    The question of the correct interpretation of the parameter, what is the average fuel consumption.
Similar threads
  1. [159] Fuel consumption / combustion 159, Brera, Spider
    Created by alces1 in section 159/Brera/Brera Spider
    Response: 3228
    Last post/author: 23-05-2025, 23:23
  2. [159] Fuel consumption BENZYNA
    Created by dziodek in section 159/Brera/Brera Spider
    Response: 15
    Last post/author: 19-04-2019, 11:09
  3. [159] engine braking and fuel consumption 2.0 l/100 km
    Created by tojatajanka in section 159/Brera/Brera Spider
    Response: 14
    Last post/author: 17-02-2019, 20:34
  4. Fuel consumption and lambda probe
    Created by knapsu in section 147
    Response: 4
    Last post/author: 08-01-2016, 15:14
  5. [159] engine braking and fuel consumption 2.0 l/100 km
    Response: 15
    Last post/author: 16-03-2011, 15:21
fuel consumption in the Parking lot
the burning of gasoline in the Parking lot
the consumption of gasoline in the Parking lot
how much fuel burn of 1.8 in the Parking lot
zuzycie na postoju
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
