nie pamiętam czy 156 ts 1.6 miała przełącznik poduszki pasażera, jesli tak to wyłącz poduszke.
chyba powinna się zaświecić kontrolka, tak wychodzi z listy blędów.
---- 5 Display for deactivation of airbag, passenger side ----
- albo program KWP71 i połaczyć sie z poduszkami, powinno pokazac błędy.
Kod:
1 Airbag control unit
2 Airbag control unit supply voltage
3 Control light for airbag system
4 Earth connection to control unit housing
6 Crash Signal
7 Crash Signal
8 Airbag ignition circuit, driver side
9 Airbag ignition circuit, passenger side
0B Seat belt tension ignition circuit, driver side
0C Seat belt tension ignition circuit, passenger side
0E Sidebag ignition circuit, driver side
0F Sidebag ignition circuit, passenger side
12 Resistance seat-occupied sensor, passenger side
14 Keylock switch for disabling passenger airbag
15 Driver side front side impact sensor
17 Passenger side front side impact sensor
19 Cable configuration
21 Ignition circuit, window bag, driver side
22 Ignition circuit, window bag, passenger side
28 Power supply
1A Warning lamp circuit
