CONNECTED TO:
ALFA 156 '02 JTS 2.0
Bosch Motronic MED7.11 EOBD Injection U MNIE TO WYGLADA TAK:TAM GDZIE NIE MA LAMANEJ KRESKI PARAMETRY SA TAKIE SAME
READ PARAMETERS:
Odometer: 43231,1 km /118335.54
Overrev count: 31/15
Max. engine speed time: 21,9 sec/21,2
Maximum RPM operation: 7160 rpm/7100
Number of rewrites: 1 /0
Odometer at last programming: 0,0 km
Engine speed: 854 rpm/815
Engine temperature: 91,5 °C
Air temperature: 30,8 °C /27
Spark advance: 0,0 deg.
Injection time: 0,998 ms /0.941
Engine load: 33,56 % /29.86
Throttle angle: 2,64 deg. /1.85 STOPNI
Air quantity: 17,2 Kg/h /15 KG
Mass air flow (throttle closed): 5,8 Kg/h /8.1 KG/H
Battery voltage: 13,55 V /13.78
Vehicle speed: 0,0 km/h
Lambda 1 signal (Pre-Cat.): 2,183 V/2.153
Lambda signal 2 (Pre-Cat.): 2,251 V/2.217
Lambda 1 signal (After-Cat.): 0,025 V/0.025
Lambda signal 2 (After-Cat.): 0,021 V/0.025
Idle RPM desired: 850 rpm
Canister purge valve: 22,66 % /21.09%
Lambda sensor 1 integrator: 1,00000
Lambda sensor 2 integrator: 1,00000
Adaptation bank 1 (mul) (FRA Factor 1): 0,99478 /0.98483
Adaptation bank 2 (mul) (FRA Factor 2): 0,99365 /0.95828
Adaptation bank 1 (add) (DTV Factor 1): -0,70 /1.54
Adaptation bank 2 (add) (DTV Factor 2): -0,84 /0.56
Throttle learn status: 11 /0
Baro pressure: 1057,27 mBar /998.91
Fuel pressure (Measured): 49,455 Bar /49.985
Fuel pressure (Calculated): 50,015 Bar /50.000
Fuel pressure signal: 1,8930 V /1.9104
Fuel pressure regulator: 34,366 % /33.139
Universal code:
Engine startup:
Dedicated line:
Clutch pedal: Released
Fan 1st speed: Not active
Fan 2nd speed: Not active
Brake pedal position: Pressed /REALESED
A/C Request: OFF
A/C Compressor: OFF
Key position: MAR
Engine status: Idle
Engine warmed up: DONE
Knock control: OFF
Deceleration cut-off: OFF
Variable cam timing control: OFF
V.I.S. Control: ON
V.I.S. Status: Long
Catalytic converter: Present
Catalytic converter heating: Not active
Canister purge valve: Active
Lambda 1 status (Pre-Cat.): Open loop
Lambda 1 status (After-Cat.): Open loop
Lambda 2 Status (Pre-Cat.): Open loop
Lambda 2 status (After-Cat.): Open loop
Anti-slip (ASR) management: Present
Automatic transmission: MANUAL
Gear engaged: None/Neutral
Throttle position learning: In progress
Throttle learn results: Correct
Warning lamp: OFF[/QUOTE]
---------- Post added at 16:24 ---------- Previous post was at 16:22 ----------
PARAMETRY SA POROWNYWANE DO PARAMETROW cuoreventi
---------- Post added at 16:47 ---------- Previous post was at 16:24 ----------
niektore sie znacznie roznia... jaka diagnoze stawiacie? dodam , ze autko stracilo moc na wysokich obrotach
