Pokaż wyniki od 1 do 8 z 8
Temat: Delay potentiometer accelerator response ....?
    166 2.4 Mjet 2005
    Domyślnie Delay potentiometer accelerator response ....?
    Hello guys, I have a problem with the throttle of my child ..... at least the tachometer marks about 750 rpm, if I press lightly on the accelerator nothing happens until a certain point, then squirts directly to about 1000 rpm! !!
    And 'normal or it could be the potentiometer to clean?
    Saluti a tutti
    Strzelin
    First clear. Connector too.
    166 2.4 Mjet 2005
    I can try to clean the connector with the contact spray but do not know how to get to the connector. I have to remove all the pedals?
    Strzelin
    I cleaned the plug without pulling. I dived
    166 2.4 Mjet 2005
    So too you have had the same problem?
    I dive myself tomorrow morning
    Alfettone: try to connect MES or AlfaOBD to read RPMs - you will know if the problem is tachometer or potentiometer.
    166 2.4 Mjet 2005
    Tomaz, the tachometer is not because the engine revs do not if I press the accelerator slightly ..... also I feel well when I start running only releasing the clutch without accelerating, if I press a little to walk slowly nothing happens, continuous pressing and suddenly the car snaps forward.
    OK, it's clear now
    So as Marek said... first cleaning, then replacing.
  1. Odpowiedzi: 6
    Ostatni post / autor: 21-09-2013, 09:10
  2. no ECU response jak kabel wkoncu kupic??
    Utworzone przez Litrowy w dziale 156
    Ostatni post / autor: 02-01-2013, 11:42
  3. [156] Multiecuscan no ECU response
    Utworzone przez komandos w dziale 156
    Ostatni post / autor: 16-09-2012, 21:49
  4. Odpowiedzi: 2
    Ostatni post / autor: 07-08-2011, 17:27
