Page 2 with 11 The firstThe first 1234567891011 LastLast
Show results from 11 to 20 with 107
    The user Maniac resoraków Avatar radzik2908
    He joined the
    03 2011
    Lives in
    Siemiatycze, Podlaskie
    Posts
    648
    Quotation Wrote BURATINO Zobacz post
    But a 100% sure way to check the condition maglownica ?
    ---------- Post added at 21:21 ---------- Previous post was at 21:18 ----------
    But, probably, the Polish road helped me.Kohl 19,255,35,only prekosc patrolto do this, stand...Tarka
    Not really, but I'm not sure, as I already wrote, at me after 3 years she started tapping maglownica at work in the Parking lot wheels at a speed of 150-it is the pulse felt on the steering wheel. Also checked suspension in all possible ways, I was even on szarpakach for buses in diagnostic station, there is only rubber on the rear beam, slightly cracked,I replaced for peace of mind and continue the same thing, but after 3 years was winowajczyni is it maglownica to be funny and does not have repair sets, all new only 1000 coins or regeneration pićset.
    Best regards
    Radek
    › Więcej...: the camber angle is adjustable
    The user Fachowiec Avatar Tomek_KRK
    He joined the
    05 2011
    Lives in
    Kraków, Poland
    AR 159
    Posts
    2,706
    Don't remember,I don't mechanictin,only the driver.Well, if you're a connoisseur zawiechy...I have a question.Yesterday I lost a whole day to establish...tarabanienia from the right front wheel.I want to mention, and I was in ASO Fiat,Alfa has been tested,everything is TIP-TOP.Shock absorbers,zbieznosc,wachacze.So ???????
    Remaining in a straight line, especially on the block is the odczowalne,as if the right front podskakiwalo Colo.There is also at a speed of 160 km / h in the mountains ,230.- We will argue ???\
    Maybe the shock knock. Will work, but will be knocked. To do so is to swing the car from side to side. One person sits "on channel" and listens, and looks, and the second alone at the car from side to side, standing sideways and pushing the car near the roof (for example, you can open the Windows to capture beyond the door). So often checks the status of the stabilizer and just knock on amorach.
    ---------- Post added at 20:37 ---------- Previous post was at 20:29 ----------
    Forgot to add, the wheels also swiezutko we are waiting for difficult in the wheels Nitrogen to better pracowaly.Unfortunately, the availability of the Q4 release is not possible dowazania number on the car.[/QUOTE]
    WWW.AUTKA.PL - comprehensive car service
    BURATINO
    A guest
    At first me too sent me to the diagnostics station.Diagnostician he only looked at the car ...Mr. bear,or equipment, Kolya,and how there to put a hand
    ---------- Post added at 21:38 ---------- Previous post was at 21:37 ----------
    My car is not alone, we tomaszku
    He joined the
    03 2011
    Lives in
    Posts
    648
    My Stilo is lowered so that the geometry on disks, because "lasers" do not see me, gave advice, well, this colleague from primary school is a diagnostician, and a liter swojskiej. Gave advice, and those other needs tightening. I think for a good car for big wheels. You have to throw them at a bottle of something alcoholic, it will help You and it's probably still like.
    BURATINO
    A guest
    In Fiat gave advice, and didn't even want pieniedza,great guest...respectful.Pogledzialismy yourself.Tells me ,Mr Lord loves this car and everything has to be 200 per cent from the norm,since I-I can wziazc money from you.And I'm like-Oh,I can't help it that I have such a small family, just me and my car.In General, positive comments oddnosnie car, I got quite a lot.Even yesterday, sitting himself and Hanna, and szaszlyka,the guy walks and -And this is your so beautiful, Alfa Romeo, and I-well I like it too
    The user Quadrifoglio Verde Avatar alces1
    He joined the
    07 2007
    Lives in
    Żegocina
    Posts
    6,673
    No, well, Lord...
    I'm here, I believe, that the issue about the angle of camber of the wheel, and I want to know what could be the reason that it is wrong and how to install it, it's possible to replace, and You're right about relingach...
    Maybe someone at the same time in this corner said something?
    Best regards.
    - Rafal
    The user Expert Avatar Kali_33
    He joined the
    10 2008
    Lives in
    Warsaw, Poland
    GTV 2.0TS 1997
    Posts
    1,526
    Quotation Wrote alces1 Zobacz post
    No, well, Lord...
    Best regards.
    - Rafal
    what are your values for these angles?
    if the deviation is small, but yet it bothers You, then for peace of mind check the other mechanicbut, from experience I know that the differences can be significant. Besides that the car was actually encumbered prior to the measurement?
    He joined the
    07 2007
    Lives in
    Żegocina
    Posts
    6,673
    Quotation Wrote Kali_33 Zobacz post
    Don't remember the exact values, but the right wheel slightly sloping. The geometry was checked without the load of the vehicle. I was in a proven workshop, so it is a fact. In addition, unfortunately, you see that on the tires...
    I know that in the case of MacPherson struts, you can "adjust" through rozwiercenie shock absorber mounting type... However, if the 159 does not have a Stand, so you need to look for another solution, but at least confirm that it's broken crossover, not in vain to change half the suspension, the cause...
    I will be very grateful for all the tips regarding this problem.
    He joined the
    05 2011
    Lives in
    Kraków, Poland
    AR 159
    Posts
    2,706
    I will say this - in most 159-ek after 4-5 years of operation comes to exceeding of the norms of the gradients of the front wheels. This is due to the wear and tear associated upper pillow romantic. And the woman,part of theHey, this deviation is so slightly behind the norm, what can this fact be ignored.
  10. #20
    He joined the
    07 2007
    Lives in
    Żegocina
    Posts
    6,673
    Quotation Wrote Tomek_KRK Zobacz post
    Hmm... I guess I would have ignored him, but, unfortunately, if the left wheel keeps "vertical" so the right is higher than the norm, which is manifested, unfortunately, uneven tire wear...
    Are you implying that this may be a pillow? I wonder where to start to solve the problem, and after going through half the suspension...
    Best regards.
    - Rafal
Similar threads
  1. Response: 54
    Last post/author: 19-03-2018, 19:28
  2. Tilt adjustment, rear
    Created by sobiibos in section 166
    Response: 127
    Last post/author: 16-06-2015, 12:36
  3. Setting the inclination angles of the wheels
    Created by stembalski17 in section 156
    Response: 12
    Last post/author: 28-08-2011, 18:25
  4. Wheel - tilt /--\
    Created by bella-hella in section 166
    Response: 0
    Last post/author: 08-06-2010, 15:42
  5. [GTV Spider] The geometry of the wheels, rear - tilt wheel?
    Created by aniol_jojo in the section of the Gtv/Gtv Spider
    Response: 7
    Last post/author: 02-04-2010, 19:59
the angle adjustment wheel
cat tilt front black Alfa 159does alfie romeo set the front wheels katowoAlfa 147 bad kat zbierznosci kolasturz einstellen alfa 159czy kat pochylenia w alfie 159 jest ustawialnyalfa 159 ustawianie konta zwrotnicysppsob regulaxji kata tilt the front wheeltilt wheel front. alfathe angle of inclination of front number. alfa 166 alfa 159 pochylone przednie koloalfa 166 - jak ustawic nachylenie kol przodkat pochylenia kola alfa159 2.4 accord vi what sets in geometryAlfa 159 katow adjustmentalfa 159 pochylone koloadjustment of the kata kola alphakat pochylenia alfa 159 regulacjamade the sleeves dyfra e46ustawienie konta pochylenia kola celica t18does alfie romeo set the front wheels Katowicethe angle of inclination of the front black alfie romeo 159ADJUSTMENT OF TIRESthe wheel alignment honda accord backthe angle of the wheel alphainstalling the cat back alfa romeohonda accord-set of wheelsmeasurement of the camber angle of the wheelaccount setup tilt wheelthe lack of kata tilt wheelthe camber angle adjustmentalfa 159 how to install a cat tilt wheelalfa 159 kat tilt wheel159n tilt wheelalfa 159 tilt wheelgeometry setup alfa 159installation zbiethe angle of the wheel as wyregulowac fiat159 the geometry of katyhow to install cat wheel alfa 159adjusting camber
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
